    MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast
    259 Posts 55 Posters 713.6k Views 57 Watching
      sil3ntstorm
      Like now?
      I did it but the clouds or rain are still displayed to me, no change from before. The 3 apps on the mobile all show sun most of the time and at least 10 hours of sun (just like in the past, always sunny and dry in the app and in real but always cloudy and rainy in the MM module)
          module: "MMM-OpenWeatherForecast",
          header: "Wettervorschau Schama",
            apikey: "XYXYXYXY", //SUPER SECRET
            latitude: 49.039349,
            longitude: 11.847070,
            units: "metric",
            iconset: "4c",
            colored: true,
            concise: true,
      			 label_high: "max",
      			 label_low: "min",
      			 label_days: ["So", "Mo", "Di", "Mi", "Do", "Fr", "Sa"],
      			 label_sunriseTimeFormat: "k:mm",
      			 label_hourlyTimeFormat: "k[h]",
      			 label_hourlyTimeFormat: "k[ Uhr]",
            requestDelay: 2000,
            showFeelsLikeTemp: true,
            displayKmhForWind: true,
            showCurrentConditions: true,
            showSummary: false,
            showExtraCurrentConditions: true,
            extraCurrentConditions: {
              highLowTemp: true,
              precipitation: true,
              sunrise: true,
              sunset: true,
              wind: true,
              barometricPressure: false,
              humidity: true,
              dewPoint: false,
              uvIndex: true,
              visibility: false
            forecastLayout: "table",
            forecastHeaderText: "",
            hourlyForecastTableHeaderText: "Stundenvorschau",
            showHourlyForecast: true,
            showHourlyTableHeaderRow: true,
            hourlyForecastInterval: 3,
            maxHourliesToShow: 5,
            hourlyExtras: {
              wind: true,
              humidity: false,
              dewPoint: false,
              uvIndex: false,
              visibility: false
            dailyForecastTableHeaderText: "Wochenvorschau",
            showDailyForecast: true,
            showDailyTableHeaderRow: true,
            maxDailiesToShow: 10,
            dailyExtras: {
              sunrise: false,
              sunset: false,
              wind: true,
              humidity: false,
              dewPoint: false,
              uvIndex: false
        sdetweil @sil3ntstorm
        @sil3ntstorm thats what the web site shows too
        accuweather shows similar
          sil3ntstorm
          The data is read from https://home.openweathermap.org and displayed on the MM, right?
          Since these often do not match for my area, I want to know whether it is possible to store another provider? For example
          https://www.wetteronline.de/wettertrend/hemau
            @sil3ntstorm
            correct. the module takes info from the openweathermap api (and the data appears valid from the api and web page)
            but the MMM-OpenWeatherMap module only works with OpenWeather as far as I know.
            I am not aware of the quality of other modules
              bassin12
              I’m having some problems and do not know exactly what is wrong, got this error:
              [29.08.2022 09:51.32.701] [LOG] [MMM-OpenWeatherForecast] 29-Aug-22 09:51 ** ERROR ** Error: Request failed with status code 401
              I get this on my screen
              I did not do any configuration just using this as a Code:
                                      module: "weather",
                                      header: "Weather Forecast",
                                              type: "forecast",
                                              locationID: "4225309",
                                              apiKey: "MYKEY"
                                  header: "Forecast",
                                    apikey: "MYKEY", //only string here
                                    latitude: 51.490230,            //number works here
                                    longitude: -0.258810,          //so does a string
                sdetweil @bassin12
                @bassin12 said in MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast:
                that is configuration (editing config.js)
                I do not know… the error says the source returned a 401 error code
                not my module… open an issue on the module github page…
                  sdetweil @bassin12
                  @bassin12 also the code block start (the 3 backtics) must be on the start of the line
                  I edited your post to fix that
                    @bassin12
                    my config , both work (and the default weather module in both current and forecast mode)
                    			apikey: "xxxx",
                    			units:"metric",
                    			iconset: "4c",
                    			colored: true,
                    			concise: true
                    			module: "MMM-OpenWeatherMapForecast",
                    			header: "Weather",
                    			classes: "default everyone",
                    			disabled: false,
                    				apikey: "..",
                    				latitude: "51.506130",
                    				longitude: "-0.090270",
                    				iconset: "4c",
                    				concise: false,
                      bassin12 @sdetweil
                      When I try the code in the config.js I get this in the logs
                      [29.08.2022 10:22.03.630] [LOG] [MMM-OpenWeatherMapForecast] 29-Aug-22 10:22 ** ERROR ** null
                      [29.08.2022 10:22.03.639] [LOG] [MMM-OpenWeatherForecast] 29-Aug-22 10:22 ** ERROR ** Error: Request failed with status code 401
                        sdetweil @bassin12
                        yes, bug in his code…
                        use the code I posted on page one to extend the error reporting
                        but it returns 401 as well…
                          DDE12
                          Is there a solution for this error? Is it something I’ve done or something in the module code?
                          [MMM-OpenWeatherForecast] 12-Nov-22 23:49 ** ERROR ** Error: Request failed with status code 401
                            sdetweil @DDE12
                            @DDE12 401 eror is unauthorized
                            so the apikey you are using has expired
                              DDE12 @sdetweil
                              I setup the default weather module with OpenWeather and it is working with the key I have. I obtained the key a few days ago. Is it the same key for MMM-OpenWeatherForecast?
                                sdetweil @DDE12
                                @DDE12 no idea
                                the module says go here
                                https://home.openweathermap.org/users/sign_up
                                the default weather openWeathermap provide says
                                https://home.openweathermap.org/users/sign_in
                                so it would seem the same key
                                the module uses this path
                                https://api.openweathermap.org/data/2.5/onecall?"
                                the default module uses this
                                		apiVersion: "2.5",
                                		apiBase: "https://api.openweathermap.org/data/"
                                                        +apiVersion+"onecall?"
                                so, they appear the same
                                  DDE12 @sdetweil
                                  I put in a new key just to see but still have the same 401 error. When I installed the module I got
                                  npm WARN old lockfile
                                  npm WARN old lockfile The package-lock.json file was created with an old version of npm,
                                  npm WARN old lockfile so supplemental metadata must be fetched from the registry.
                                  npm WARN old lockfile This is a one-time fix-up, please be patient...
                                  added 4 packages, and audited 391 packages in 50s
                                  1 package is looking for funding
                                    run `npm fund` for details
                                  39 vulnerabilities (2 low, 15 moderate, 19 high, 3 critical)
                                  To address all issues, run:
                                    npm audit fix
                                  Run `npm audit` for details.
                                  I did not run audit fix. Is there something that I need to do with the install?
                                    sdetweil @DDE12
                                    @DDE12 NEVER run audit fix…
                                    i don’t know why the MMM-OpenWeatherForecast is failing ,
                                    other than it says unauthorized. i would open an issue for the author.
                                      @DDE12 Could you share your config? Also be sure put your API key in quotes in the configuration. If you aren’t using quotes, this could be a reason why the module is giving you the 401 error
                                        DDE12
                                        @j-e-f-f
                                        I can, but I think I figured it out last night without changing anything in MM or the module. I initially signed up for the free account on OpenWeatherMap. Last night I signed up for the One Call by Call https://openweathermap.org/api and MMM-OpenWeatherForecast starting working. Before signing up, I tested my API in a browser at https://api.openweathermap.org/data/2.5/onecall?lat=someLatitude&lon=someLongitude&appid=secretAPI
                                        and at https://api.openweathermap.org/data/3.0/onecall?lat=someLatitude&lon=someLongitude&appid=secretAPI
                                        and both reported 401 error. After signing up, the module began working in MM. This does require a credit card and subscribers get 1000 free calls per day. Subscribers can set the maximum number of calls in their dashboard to prevent going over and getting charged. This doesn’t seem like it would be too much of a problem if users set the module’s config appropriately.
                                        I’m guessing that the module is trying to get data that is no longer free and some API’s are grandfathered ?? Or I misunderstood what type of account I needed from the start.
                                        Where is the API address in the module’s code?
                                        Let me know if I can provide further information.
                                        T S 2 Replies Last reply Reply Quote 0
                                        • T
                                          trividar @DDE12
                                          If the Module doesn’t load the informations change ```
                                          “https://api.openweathermap.org/data/3.0/onecall”
                                          to
                                          “https://api.openweathermap.org/data/3.0/onecall?”
                                          an it should work!
                                            sdetweil @DDE12
                                            @DDE12 the API url is in the node_helper.js
                                            we recently add a Parm to enable picking v3 of the API vs 2.5 (old free).
                                            the add on modules need to do the same
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 8 / 13
