    MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast
    259 Posts 55 Posters 701.7k Views 57 Watching
      sdetweil @sil3ntstorm
      @sil3ntstorm thats what the web site shows too
      accuweather shows similar
        sil3ntstorm
        The data is read from https://home.openweathermap.org and displayed on the MM, right?
        Since these often do not match for my area, I want to know whether it is possible to store another provider? For example
        https://www.wetteronline.de/wettertrend/hemau
          @sil3ntstorm
          correct. the module takes info from the openweathermap api (and the data appears valid from the api and web page)
          but the MMM-OpenWeatherMap module only works with OpenWeather as far as I know.
          I am not aware of the quality of other modules
            bassin12
            I’m having some problems and do not know exactly what is wrong, got this error:
            [29.08.2022 09:51.32.701] [LOG] [MMM-OpenWeatherForecast] 29-Aug-22 09:51 ** ERROR ** Error: Request failed with status code 401
            I get this on my screen
            I did not do any configuration just using this as a Code:
                                    module: "weather",
                                    header: "Weather Forecast",
                                            type: "forecast",
                                            locationID: "4225309",
                                            apiKey: "MYKEY"
                                module: "MMM-OpenWeatherForecast",
                                header: "Forecast",
                                  apikey: "MYKEY", //only string here
                                  latitude: 51.490230,            //number works here
                                  longitude: -0.258810,          //so does a string
              sdetweil @bassin12
              @bassin12 said in MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast:
              that is configuration (editing config.js)
              I do not know… the error says the source returned a 401 error code
              not my module… open an issue on the module github page…
                sdetweil @bassin12
                @bassin12 also the code block start (the 3 backtics) must be on the start of the line
                I edited your post to fix that
                  @bassin12
                  my config , both work (and the default weather module in both current and forecast mode)
                  		header: "Wettervorschau Schama",
                  			apikey: "xxxx",
                  			latitude: 49.039349,
                  			longitude: 11.847070,
                  			units:"metric",
                  			iconset: "4c",
                  			colored: true,
                  			concise: true
                  			module: "MMM-OpenWeatherMapForecast",
                  			header: "Weather",
                  			classes: "default everyone",
                  			disabled: false,
                  				apikey: "..",
                  				latitude: "51.506130",
                  				longitude: "-0.090270",
                  				iconset: "4c",
                  				concise: false,
                  				forecastLayout: "table"
                    bassin12 @sdetweil
                    When I try the code in the config.js I get this in the logs
                    [29.08.2022 10:22.03.630] [LOG] [MMM-OpenWeatherMapForecast] 29-Aug-22 10:22 ** ERROR ** null
                    [29.08.2022 10:22.03.639] [LOG] [MMM-OpenWeatherForecast] 29-Aug-22 10:22 ** ERROR ** Error: Request failed with status code 401
                      sdetweil @bassin12
                      yes, bug in his code…
                      use the code I posted on page one to extend the error reporting
                      but it returns 401 as well…
                        DDE12
                        Is there a solution for this error? Is it something I’ve done or something in the module code?
                        [MMM-OpenWeatherForecast] 12-Nov-22 23:49 ** ERROR ** Error: Request failed with status code 401
                          sdetweil @DDE12
                          @DDE12 401 eror is unauthorized
                          so the apikey you are using has expired
                            DDE12 @sdetweil
                            I setup the default weather module with OpenWeather and it is working with the key I have. I obtained the key a few days ago. Is it the same key for MMM-OpenWeatherForecast?
                              sdetweil @DDE12
                              @DDE12 no idea
                              the module says go here
                              https://home.openweathermap.org/users/sign_up
                              the default weather openWeathermap provide says
                              https://home.openweathermap.org/users/sign_in
                              so it would seem the same key
                              the module uses this path
                              https://api.openweathermap.org/data/2.5/onecall?"
                              the default module uses this
                              		apiVersion: "2.5",
                              		apiBase: "https://api.openweathermap.org/data/"
                                                      +apiVersion+"onecall?"
                              so, they appear the same
                                DDE12 @sdetweil
                                I put in a new key just to see but still have the same 401 error. When I installed the module I got
                                npm WARN old lockfile
                                npm WARN old lockfile The package-lock.json file was created with an old version of npm,
                                npm WARN old lockfile so supplemental metadata must be fetched from the registry.
                                npm WARN old lockfile This is a one-time fix-up, please be patient...
                                added 4 packages, and audited 391 packages in 50s
                                1 package is looking for funding
                                  run `npm fund` for details
                                39 vulnerabilities (2 low, 15 moderate, 19 high, 3 critical)
                                To address all issues, run:
                                  npm audit fix
                                Run `npm audit` for details.
                                I did not run audit fix. Is there something that I need to do with the install?
                                  sdetweil @DDE12
                                  @DDE12 NEVER run audit fix…
                                  i don’t know why the MMM-OpenWeatherForecast is failing ,
                                  other than it says unauthorized. i would open an issue for the author.
                                    @DDE12 Could you share your config? Also be sure put your API key in quotes in the configuration. If you aren’t using quotes, this could be a reason why the module is giving you the 401 error
                                      DDE12
                                      @j-e-f-f
                                      I can, but I think I figured it out last night without changing anything in MM or the module. I initially signed up for the free account on OpenWeatherMap. Last night I signed up for the One Call by Call https://openweathermap.org/api and MMM-OpenWeatherForecast starting working. Before signing up, I tested my API in a browser at https://api.openweathermap.org/data/2.5/onecall?lat=someLatitude&lon=someLongitude&appid=secretAPI
                                      and at https://api.openweathermap.org/data/3.0/onecall?lat=someLatitude&lon=someLongitude&appid=secretAPI
                                      and both reported 401 error. After signing up, the module began working in MM. This does require a credit card and subscribers get 1000 free calls per day. Subscribers can set the maximum number of calls in their dashboard to prevent going over and getting charged. This doesn’t seem like it would be too much of a problem if users set the module’s config appropriately.
                                      I’m guessing that the module is trying to get data that is no longer free and some API’s are grandfathered ?? Or I misunderstood what type of account I needed from the start.
                                      Where is the API address in the module’s code?
                                      Let me know if I can provide further information.
                                      T S 2 Replies Last reply Reply Quote 0
                                      • T Offline
                                        trividar @DDE12
                                        If the Module doesn’t load the informations change ```
                                        “https://api.openweathermap.org/data/3.0/onecall”
                                        to
                                        “https://api.openweathermap.org/data/3.0/onecall?”
                                        an it should work!
                                          sdetweil @DDE12
                                          @DDE12 the API url is in the node_helper.js
                                          we recently add a Parm to enable picking v3 of the API vs 2.5 (old free).
                                          the add on modules need to do the same
                                          • Y Offline
                                            yk
                                            Fantastic work! I was using the previous DarkSkyForecast version - easy shift to this one.
                                            I’m trying to put the hourly data and daily data in the same “row” across using tiled view instead of 2 rows. I’m happy to edit the njk file (have tweaked a bit haven’t gotten it “just right” yet). Any ideas? I gather it’s something with the hourly and daily divs.
                                            Is data available to get mm of precipitation in the hourly and daily blocks? It shows % chance - keen to add precipitation instead.
                                            Thanks!!
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 8 / 13
