    MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast
    259 Posts 55 Posters 701.5k Views 57 Watching
    • plainbrokeP Offline
      plainbroke @j.e.f.f
      Thank you all for information. I was upset. I really like the way my Darksky weather module looks on my screen. I guess in march next year I will think about having to change over to something else. Maybe by then someone will make it so the Darksky module works with another weather api…
        sdetweil @plainbroke
        @plainbroke problem is that darksky provided a lot of cool extra data that nobody else provides.
        so all the others will lack something…
        • L Offline
          lxne Project Sponsor
          Hello there,
          We wanted to let you know about a change coming to Dark Sky. Beginning on March 31st, 2023 the Dark Sky API will no longer be available. To prepare, we encourage you to learn more about WeatherKit, a new Apple API available on iOS, iPadOS, macOS, tvOS, and web that provides access to the new Apple Weather forecast data.
          You can learn more here.
          As always, we appreciate your support, and will continue to update you with any future changes.
          Thanks, The Dark Sky Team
          plainbrokeP 1 Reply Last reply Reply Quote 1
            plainbroke @lxne
            @lxne
            So, is that going to be the API for Dark Sky to run on in 2023?
              @plainbroke
              no, it will be a different API
              https://developer.apple.com/documentation/weatherkitrestapi
              darksky API is dead
                sil3ntstorm
                Great job, I like it very much, thanks for that.
                I’ve had it running for about 8 weeks and I’ve noticed that my temperature readings are correct, but my weather is always showing as cloudy or rainy in advance, even though the sun has been shining 90% of the time for weeks and almost never rains
                I checked the latitude and longitude several times and read them out and accepted them either via https://www.latlong.net/ or via google.
                What can be the reason for the fact that I keep getting only clouds and rain, even though the sun is shining most of the time?
                Place of residence is: Germany Hohenschambach
                Width 49.039349
                Longitude 11.847070
                I hope you can help me here 😊
                My English skills are not very good, I translated it with google, I hope you understand what I want to say 😊
                  sdetweil @sil3ntstorm
                  @sil3ntstorm can u show the config.js entry
                    sil3ntstorm
                        module: "MMM-OpenWeatherForecast",
                        header: "Wettervorschau Schama",
                          apikey: "XYXYXY", //SUPER SECRET
                          latitude: "49.039349",     //49.039349 Hemau
                          longitude: "11.847070",    //11.847070 Hemau
                          units: "metric",
                          iconset: "4c",
                          colored: true,
                          concise: true,
                    			 label_high: "max",
                    			 label_low: "min",
                    			 label_days: ["So", "Mo", "Di", "Mi", "Do", "Fr", "Sa"],
                    			 label_sunriseTimeFormat: "k:mm",
                    			 label_hourlyTimeFormat: "k[h]",
                    			 label_hourlyTimeFormat: "k[ Uhr]",
                          requestDelay: "2000",
                          showFeelsLikeTemp: true,
                          displayKmhForWind: true,
                          showCurrentConditions: true,
                          showSummary: false,
                          showExtraCurrentConditions: true,
                          extraCurrentConditions: {
                            highLowTemp: true,
                            precipitation: true,
                            sunrise: true,
                            sunset: true,
                            wind: true,
                            barometricPressure: false,
                            humidity: true,
                            dewPoint: false,
                            uvIndex: true,
                            visibility: false
                          forecastLayout: "table",
                          forecastHeaderText: "",
                          hourlyForecastTableHeaderText: "Stundenvorschau",
                          showHourlyForecast: true,
                          showHourlyTableHeaderRow: true,
                          hourlyForecastInterval: 3,
                          maxHourliesToShow: 5,
                          hourlyExtras: {
                            wind: true,
                            humidity: false,
                            dewPoint: false,
                            uvIndex: false,
                            visibility: false
                          dailyForecastTableHeaderText: "Wochenvorschau",
                          showDailyForecast: true,
                          showDailyTableHeaderRow: true,
                          maxDailiesToShow: 10,
                          dailyExtras: {
                            sunrise: false,
                            sunset: false,
                            wind: true,
                            humidity: false,
                            dewPoint: false,
                            uvIndex: false
                      @sil3ntstorm remove the quotes from around the lat/long… that makes then a string, not a number…
                      most modules cannot handle the difference
                      anyplace just numbers, remove quotes
                        sil3ntstorm
                        Like now?
                        I did it but the clouds or rain are still displayed to me, no change from before. The 3 apps on the mobile all show sun most of the time and at least 10 hours of sun (just like in the past, always sunny and dry in the app and in real but always cloudy and rainy in the MM module)
                              apikey: "XYXYXYXY", //SUPER SECRET
                              latitude: 49.039349,
                              longitude: 11.847070,
                              units: "metric",
                              iconset: "4c",
                              colored: true,
                              concise: true,
                        			 label_high: "max",
                        			 label_low: "min",
                              requestDelay: 2000,
                              showSummary: false,
                                highLowTemp: true,
                                sunrise: true,
                                sunset: true,
                                wind: true,
                                humidity: true,
                                dewPoint: false,
                                uvIndex: true,
                                visibility: false
                              hourlyExtras: {
                                wind: true,
                                humidity: false,
                                dewPoint: false,
                                uvIndex: false,
                                visibility: false
                              dailyExtras: {
                                sunrise: false,
                                sunset: false,
                                wind: true,
                                humidity: false,
                                dewPoint: false,
                                uvIndex: false
                          @sil3ntstorm thats what the web site shows too
                          accuweather shows similar
                            sil3ntstorm
                            The data is read from https://home.openweathermap.org and displayed on the MM, right?
                            Since these often do not match for my area, I want to know whether it is possible to store another provider? For example
                            https://www.wetteronline.de/wettertrend/hemau
                              @sil3ntstorm
                              correct. the module takes info from the openweathermap api (and the data appears valid from the api and web page)
                              but the MMM-OpenWeatherMap module only works with OpenWeather as far as I know.
                              I am not aware of the quality of other modules
                                bassin12
                                I’m having some problems and do not know exactly what is wrong, got this error:
                                [29.08.2022 09:51.32.701] [LOG] [MMM-OpenWeatherForecast] 29-Aug-22 09:51 ** ERROR ** Error: Request failed with status code 401
                                I get this on my screen
                                I did not do any configuration just using this as a Code:
                                                        module: "weather",
                                                        header: "Weather Forecast",
        type: "forecast",
        locationID: "4225309",
        apiKey: "MYKEY"
                                                    header: "Forecast",
                                                      apikey: "MYKEY", //only string here
                                                      latitude: 51.490230,            //number works here
                                                      longitude: -0.258810,          //so does a string
                                  sdetweil @bassin12
                                  @bassin12 said in MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast:
                                  that is configuration (editing config.js)
                                  I do not know… the error says the source returned a 401 error code
                                  not my module… open an issue on the module github page…
                                    sdetweil @bassin12
                                    @bassin12 also the code block start (the 3 backtics) must be on the start of the line
                                    I edited your post to fix that
                                      @bassin12
                                      my config , both work (and the default weather module in both current and forecast mode)
                                      			apikey: "xxxx",
                                      			units:"metric",
                                      			iconset: "4c",
                                      			colored: true,
                                      			concise: true
                                      			module: "MMM-OpenWeatherMapForecast",
                                      			header: "Weather",
                                      			classes: "default everyone",
                                      			disabled: false,
                                      				apikey: "..",
                                      				latitude: "51.506130",
                                      				longitude: "-0.090270",
                                      				iconset: "4c",
                                      				concise: false,
                                        bassin12 @sdetweil
                                        When I try the code in the config.js I get this in the logs
                                        [29.08.2022 10:22.03.630] [LOG] [MMM-OpenWeatherMapForecast] 29-Aug-22 10:22 ** ERROR ** null
                                        [29.08.2022 10:22.03.639] [LOG] [MMM-OpenWeatherForecast] 29-Aug-22 10:22 ** ERROR ** Error: Request failed with status code 401
                                          sdetweil @bassin12
                                          yes, bug in his code…
                                          use the code I posted on page one to extend the error reporting
                                          but it returns 401 as well…
                                            DDE12
                                            Is there a solution for this error? Is it something I’ve done or something in the module code?
                                            [MMM-OpenWeatherForecast] 12-Nov-22 23:49 ** ERROR ** Error: Request failed with status code 401
                                            • 12
                                            • 13
                                            • 7 / 13
