    MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast
    259 Posts 55 Posters 701.4k Views 57 Watching
      sdetweil @plainbroke
      @plainbroke
      no, it will be a different API
      https://developer.apple.com/documentation/weatherkitrestapi
      darksky API is dead
        sil3ntstorm
        Great job, I like it very much, thanks for that.
        I’ve had it running for about 8 weeks and I’ve noticed that my temperature readings are correct, but my weather is always showing as cloudy or rainy in advance, even though the sun has been shining 90% of the time for weeks and almost never rains
        I checked the latitude and longitude several times and read them out and accepted them either via https://www.latlong.net/ or via google.
        What can be the reason for the fact that I keep getting only clouds and rain, even though the sun is shining most of the time?
        Place of residence is: Germany Hohenschambach
        Width 49.039349
        Longitude 11.847070
        I hope you can help me here 😊
        My English skills are not very good, I translated it with google, I hope you understand what I want to say 😊
          sdetweil @sil3ntstorm
          @sil3ntstorm can u show the config.js entry
            sil3ntstorm
                module: "MMM-OpenWeatherForecast",
                header: "Wettervorschau Schama",
                  apikey: "XYXYXY", //SUPER SECRET
                  latitude: "49.039349",     //49.039349 Hemau
                  longitude: "11.847070",    //11.847070 Hemau
                  units: "metric",
                  iconset: "4c",
                  colored: true,
                  concise: true,
            			 label_high: "max",
            			 label_low: "min",
            			 label_days: ["So", "Mo", "Di", "Mi", "Do", "Fr", "Sa"],
            			 label_sunriseTimeFormat: "k:mm",
            			 label_hourlyTimeFormat: "k[h]",
            			 label_hourlyTimeFormat: "k[ Uhr]",
                  requestDelay: "2000",
                  showFeelsLikeTemp: true,
                  displayKmhForWind: true,
                  showCurrentConditions: true,
                  showSummary: false,
                  showExtraCurrentConditions: true,
                  extraCurrentConditions: {
                    highLowTemp: true,
                    precipitation: true,
                    sunrise: true,
                    sunset: true,
                    wind: true,
                    barometricPressure: false,
                    humidity: true,
                    dewPoint: false,
                    uvIndex: true,
                    visibility: false
                  forecastLayout: "table",
                  forecastHeaderText: "",
                  hourlyForecastTableHeaderText: "Stundenvorschau",
                  showHourlyForecast: true,
                  showHourlyTableHeaderRow: true,
                  hourlyForecastInterval: 3,
                  maxHourliesToShow: 5,
                  hourlyExtras: {
                    wind: true,
                    humidity: false,
                    dewPoint: false,
                    uvIndex: false,
                    visibility: false
                  dailyForecastTableHeaderText: "Wochenvorschau",
                  showDailyForecast: true,
                  showDailyTableHeaderRow: true,
                  maxDailiesToShow: 10,
                  dailyExtras: {
                    sunrise: false,
                    sunset: false,
                    wind: true,
                    humidity: false,
                    dewPoint: false,
                    uvIndex: false
              @sil3ntstorm remove the quotes from around the lat/long… that makes then a string, not a number…
              most modules cannot handle the difference
              anyplace just numbers, remove quotes
                sil3ntstorm
                Like now?
                I did it but the clouds or rain are still displayed to me, no change from before. The 3 apps on the mobile all show sun most of the time and at least 10 hours of sun (just like in the past, always sunny and dry in the app and in real but always cloudy and rainy in the MM module)
                      apikey: "XYXYXYXY", //SUPER SECRET
                      latitude: 49.039349,
                      longitude: 11.847070,
                      units: "metric",
                      iconset: "4c",
                      colored: true,
                      concise: true,
                			 label_high: "max",
                			 label_low: "min",
                      requestDelay: 2000,
                      showSummary: false,
                        highLowTemp: true,
                        sunrise: true,
                        sunset: true,
                        wind: true,
                        humidity: true,
                        dewPoint: false,
                        uvIndex: true,
                        visibility: false
                      hourlyExtras: {
                        wind: true,
                        humidity: false,
                        dewPoint: false,
                        uvIndex: false,
                        visibility: false
                      dailyExtras: {
                        sunrise: false,
                        sunset: false,
                        wind: true,
                        humidity: false,
                        dewPoint: false,
                        uvIndex: false
                  @sil3ntstorm thats what the web site shows too
                  accuweather shows similar
                    sil3ntstorm
                    The data is read from https://home.openweathermap.org and displayed on the MM, right?
                    Since these often do not match for my area, I want to know whether it is possible to store another provider? For example
                    https://www.wetteronline.de/wettertrend/hemau
                      @sil3ntstorm
                      correct. the module takes info from the openweathermap api (and the data appears valid from the api and web page)
                      but the MMM-OpenWeatherMap module only works with OpenWeather as far as I know.
                      I am not aware of the quality of other modules
                        bassin12
                        I’m having some problems and do not know exactly what is wrong, got this error:
                        [29.08.2022 09:51.32.701] [LOG] [MMM-OpenWeatherForecast] 29-Aug-22 09:51 ** ERROR ** Error: Request failed with status code 401
                        I get this on my screen
                        I did not do any configuration just using this as a Code:
                                                module: "weather",
                                                header: "Weather Forecast",
                                                        type: "forecast",
                                                        locationID: "4225309",
                                                        apiKey: "MYKEY"
                                            header: "Forecast",
                                              apikey: "MYKEY", //only string here
                                              latitude: 51.490230,            //number works here
                                              longitude: -0.258810,          //so does a string
                          sdetweil @bassin12
                          @bassin12 said in MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast:
                          that is configuration (editing config.js)
                          I do not know… the error says the source returned a 401 error code
                          not my module… open an issue on the module github page…
                            sdetweil @bassin12
                            @bassin12 also the code block start (the 3 backtics) must be on the start of the line
                            I edited your post to fix that
                              @bassin12
                              my config , both work (and the default weather module in both current and forecast mode)
                              			apikey: "xxxx",
                              			units:"metric",
                              			iconset: "4c",
                              			colored: true,
                              			concise: true
                              			module: "MMM-OpenWeatherMapForecast",
                              			header: "Weather",
                              			classes: "default everyone",
                              			disabled: false,
                              				apikey: "..",
                              				latitude: "51.506130",
                              				longitude: "-0.090270",
                              				iconset: "4c",
                              				concise: false,
                                bassin12 @sdetweil
                                When I try the code in the config.js I get this in the logs
                                [29.08.2022 10:22.03.630] [LOG] [MMM-OpenWeatherMapForecast] 29-Aug-22 10:22 ** ERROR ** null
                                [29.08.2022 10:22.03.639] [LOG] [MMM-OpenWeatherForecast] 29-Aug-22 10:22 ** ERROR ** Error: Request failed with status code 401
                                  sdetweil @bassin12
                                  yes, bug in his code…
                                  use the code I posted on page one to extend the error reporting
                                  but it returns 401 as well…
                                    DDE12
                                    Is there a solution for this error? Is it something I’ve done or something in the module code?
                                    [MMM-OpenWeatherForecast] 12-Nov-22 23:49 ** ERROR ** Error: Request failed with status code 401
                                      sdetweil @DDE12
                                      @DDE12 401 eror is unauthorized
                                      so the apikey you are using has expired
                                        DDE12 @sdetweil
                                        I setup the default weather module with OpenWeather and it is working with the key I have. I obtained the key a few days ago. Is it the same key for MMM-OpenWeatherForecast?
                                          sdetweil @DDE12
                                          @DDE12 no idea
                                          the module says go here
                                          https://home.openweathermap.org/users/sign_up
                                          the default weather openWeathermap provide says
                                          https://home.openweathermap.org/users/sign_in
                                          so it would seem the same key
                                          the module uses this path
                                          https://api.openweathermap.org/data/2.5/onecall?"
                                          the default module uses this
                                          		apiVersion: "2.5",
                                          		apiBase: "https://api.openweathermap.org/data/"
        +apiVersion+"onecall?"
                                          so, they appear the same
                                            DDE12 @sdetweil
                                            I put in a new key just to see but still have the same 401 error. When I installed the module I got
                                            npm WARN old lockfile
                                            npm WARN old lockfile The package-lock.json file was created with an old version of npm,
                                            npm WARN old lockfile so supplemental metadata must be fetched from the registry.
                                            npm WARN old lockfile This is a one-time fix-up, please be patient...
                                            added 4 packages, and audited 391 packages in 50s
                                            1 package is looking for funding
                                              run `npm fund` for details
                                            39 vulnerabilities (2 low, 15 moderate, 19 high, 3 critical)
                                            To address all issues, run:
                                              npm audit fix
                                            Run `npm audit` for details.
                                            I did not run audit fix. Is there something that I need to do with the install?
                                            • 12
                                            • 13
                                            • 7 / 13
