    MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast
    259 Posts 55 Posters 721.5k Views 57 Watching
      cwong79
      I am a complete newbie. I followed the instructions exactly, I even did it multiple times to ensure it was done correctly. As during installation process, some warnings around vulnerability kicked up and I attempted to resolve. I removed the copy and reinstalled MMM-OpenWeatherForecast. I have the default weather module commented out and just running this module. I cannot get it working, not sure why. I copied the sample configuration and inserted the appropriate API key and Long/Lat. What am I doing wrong?
      			module: "MMM-OpenWeatherForecast",
      			header: "Forecast",
      						apikey: "??????????", //SUPER SECRET
      						latitude: 26.124161,
      						longitude: -80.143593,
      						units: "imperial",
      						iconset: "3c",
      						colored: true,
      						concise: true,
      						requestDelay: "2000",
      						showFeelsLikeTemp: true,
      						showCurrentConditions: true,
      						showSummary: true,
      						showExtraCurrentConditions: true,
      						extraCurrentConditions: {
      													highLowTemp: true,
      													precipitation: true,
      													sunrise: true,
      													sunset: true,
      													wind: true,
      													barometricPressure: false,
      													humidity: true,
      													dewPoint: false,
      													uvIndex: true,
      													visibility: false
      						forecastLayout: "table",
      						forecastHeaderText: "",
      						hourlyForecastTableHeaderText: "By the hour",
      						showHourlyForecast: true,
      						showHourlyTableHeaderRow: true,
      						hourlyForecastInterval: 1,
      						maxHourliesToShow: 10,
      						hourlyExtras: {
      											wind: true,
      											humidity: false,
      											dewPoint: false,
      											uvIndex: false,
      											visibility: false
      						dailyForecastTableHeaderText: "Throughout the week",
      						showDailyForecast: true,
      						showDailyTableHeaderRow: true,
      						maxDailiesToShow: 5,
      						dailyExtras: {
      										sunrise: false,
      										sunset: false,
      										wind: true,
      										humidity: false,
      										dewPoint: false,
      										uvIndex: false
        sdetweil @cwong79
        @cwong79 I added the code wrapper around your config info
        to do this
        paste your text.
        select it
        then push the button </>
        above the editor window
        C 1 Reply Last reply
          cwong79 @sdetweil
          @sdetweil thank you. Sorry, its my first post.
          • N6NGN
            N6NG
            Darksky is no longer accepting new signups. Just an FYI
            Dennis
            • goldyfruitG
              goldyfruit Project Sponsor
              Re: MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast
              I opened an issue on GitHub about the CPU consumption, anyone else with the same symptom?
              https://github.com/jclarke0000/MMM-OpenWeatherForecast/issues/14
              Build smart things with magic and love! | https://smartgic.io
              • A
                airclown
                Love the module, Is there a way to have the module show - Horizontally?
                Like moving the Hourly and 5/3 day to the right side of the current? so 1 row with 3 columns.
                Thank You
                J 1 Reply Last reply
                  j.e.f.f Project Sponsor Module Developer @airclown
                  @airclown if you know what you’re doing with CSS this is certainly doable in your custom.css file. The module’s HTML is structured in such a way as to not restrict reordering through CSS
                  G 1 Reply Last reply
                  • G
                    gekberlin @j.e.f.f
                    Hi all,
                    has anyone a suggestion how to move the temprature in tiled mode next to the icon in one row?
                    I mean just like in the picture given ?
                    I really don’t understand the syntax of the nunjucks part.
                      Ray
                      Hey guys in the alert status. I show the following 3 items
                      Excessive heat watch
                      heat advisory
                      small craft advisory
                      Is there a way I can eliminate small craft advisory
                      or just use heat advisory
                      • plainbrokeP
                        plainbroke
                        When will Darksky fail to work anymore.
                        I have it running now and it works fine.
                        What am I missing?
                        BKeyportB J 2 Replies Last reply
                        • BKeyportB
                          BKeyport Module Developer @plainbroke
                          @plainbroke If you have an API key from before Apple bought it up, Darksky still will work. They’re just not issuing new API keys any longer, and Apple seems to be wanting to put all of Darksky’s features into their own app, and use the API for themselves, so I doubt old keys are gonna go away any time soon.
                          karsten13K 1 Reply Last reply
                          • karsten13K
                            karsten13 @BKeyport
                            see https://blog.darksky.net/
                            BKeyportB 1 Reply Last reply
                            • BKeyportB
                              BKeyport Module Developer @karsten13
                              @karsten13 Ahh, so rather than doing the API into the weather app, Apple’s decided to rewrite it completely. Good to know.
                                j.e.f.f Project Sponsor Module Developer @plainbroke
                                @plainbroke said in MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast:
                                What am I missing?
                                I just received an email last week from Apple saying that Dark Sky API will stop working on March 31 2023.
                                So you have a while yet before it goes belly up. And who knows… Apple might extend this out past the deadline.
                                plainbrokeP 1 Reply Last reply
                                • plainbrokeP
                                  plainbroke @j.e.f.f
                                  Thank you all for information. I was upset. I really like the way my Darksky weather module looks on my screen. I guess in march next year I will think about having to change over to something else. Maybe by then someone will make it so the Darksky module works with another weather api…
                                    sdetweil @plainbroke
                                    @plainbroke problem is that darksky provided a lot of cool extra data that nobody else provides.
                                    so all the others will lack something…
                                    • L
                                      lxne Project Sponsor
                                      Hello there,
                                      We wanted to let you know about a change coming to Dark Sky. Beginning on March 31st, 2023 the Dark Sky API will no longer be available. To prepare, we encourage you to learn more about WeatherKit, a new Apple API available on iOS, iPadOS, macOS, tvOS, and web that provides access to the new Apple Weather forecast data.
                                      You can learn more here.
                                      As always, we appreciate your support, and will continue to update you with any future changes.
                                      Thanks, The Dark Sky Team
                                      • plainbrokeP
                                        plainbroke @lxne
                                        @lxne
                                        So, is that going to be the API for Dark Sky to run on in 2023?
                                          @plainbroke
                                          no, it will be a different API
                                          https://developer.apple.com/documentation/weatherkitrestapi
                                          darksky API is dead
                                            sil3ntstorm
                                            Great job, I like it very much, thanks for that.
                                            I’ve had it running for about 8 weeks and I’ve noticed that my temperature readings are correct, but my weather is always showing as cloudy or rainy in advance, even though the sun has been shining 90% of the time for weeks and almost never rains
                                            I checked the latitude and longitude several times and read them out and accepted them either via https://www.latlong.net/ or via google.
                                            What can be the reason for the fact that I keep getting only clouds and rain, even though the sun is shining most of the time?
                                            Place of residence is: Germany Hohenschambach
                                            Width 49.039349
                                            Longitude 11.847070
                                            I hope you can help me here 😊
                                            My English skills are not very good, I translated it with google, I hope you understand what I want to say 😊
                                            • 12
                                            • 13
                                            • 6 / 13
