    MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast
    259 Posts 55 Posters 721.4k Views 57 Watching
      PH1TCH @karsten13
      @karsten13 & @Biebermann
      Probably not the most elegant solution ever, but I added the following jquery code to the index.html located in the MagicMirror folder which will check every 30 seconds for the text “There” in elements of the class "weather-alert-description " and will hide the parent element (so the whole thing) if found.
      Since the English alerts usually start with “There” I can hide them this way and only leave the German ones
      <script src="https://ajax.googleapis.com/ajax/libs/jquery/2.1.3/jquery.min.js"></script>
      <script>
      	setInterval(function(){
      		$('.weather-alert-description').each(function () {
      			  if ($(this).text().includes('There')) {
      				$(this).parent().hide();
      	}, 30000);
      </script>
      • F
        fillilutten
        I’m sorry if this is stupid - but I’m currently showing extraCurrentConditions - high/low + precipitation. And precipitation shows in “mm” and I’d prefer if it could show in % how likely it is to rain/snow that day. So I know if I should bring an umbrella or not.
        Is this possible? I tried using hourly forecast + extras and set that to 12 hours interval and only show one daily. But it didn’t work.
        Thanks!
          rcberg3
          @j-e-f-f any way to hide the wind units in the hourly and daily forecasts? I’m finding that they’re pushing onto a second line when the wind speed is greater than 2 digits. I’d be happy just to show the number and not the units.
          J 1 Reply Last reply
            j.e.f.f Project Sponsor Module Developer @rcberg3
            @rcberg3 sorry, the code doesn’t currently allow for this, nor do the units have their own CSS class that you can use to hide them.
            You could instead increase the width of the module in order to give the forecast a bit more space to stop the wind units from wrapping to a second line. Instructions to do so are included in the readme.
            R 1 Reply Last reply
              rcberg3 @j.e.f.f
              @j-e-f-f Appreciate it! I added the nowrap to the css for now and it’s better.
                MMuser
                Hi is it possible to swap warnings and extra weather info, like shown below ?
                  cwong79
                  I am a complete newbie. I followed the instructions exactly, I even did it multiple times to ensure it was done correctly. As during installation process, some warnings around vulnerability kicked up and I attempted to resolve. I removed the copy and reinstalled MMM-OpenWeatherForecast. I have the default weather module commented out and just running this module. I cannot get it working, not sure why. I copied the sample configuration and inserted the appropriate API key and Long/Lat. What am I doing wrong?
                  			module: "MMM-OpenWeatherForecast",
                  			header: "Forecast",
                  						apikey: "??????????", //SUPER SECRET
                  						latitude: 26.124161,
                  						longitude: -80.143593,
                  						units: "imperial",
                  						iconset: "3c",
                  						colored: true,
                  						concise: true,
                  						requestDelay: "2000",
                  						showFeelsLikeTemp: true,
                  						showCurrentConditions: true,
                  						showSummary: true,
                  						showExtraCurrentConditions: true,
                  						extraCurrentConditions: {
                  													highLowTemp: true,
                  													precipitation: true,
                  													sunrise: true,
                  													sunset: true,
                  													wind: true,
                  													barometricPressure: false,
                  													humidity: true,
                  													dewPoint: false,
                  													uvIndex: true,
                  													visibility: false
                  						forecastLayout: "table",
                  						forecastHeaderText: "",
                  						hourlyForecastTableHeaderText: "By the hour",
                  						showHourlyForecast: true,
                  						showHourlyTableHeaderRow: true,
                  						hourlyForecastInterval: 1,
                  						maxHourliesToShow: 10,
                  						hourlyExtras: {
                  											wind: true,
                  											humidity: false,
                  											dewPoint: false,
                  											uvIndex: false,
                  											visibility: false
                  						dailyForecastTableHeaderText: "Throughout the week",
                  						showDailyForecast: true,
                  						showDailyTableHeaderRow: true,
                  						maxDailiesToShow: 5,
                  						dailyExtras: {
                  										sunrise: false,
                  										sunset: false,
                  										wind: true,
                  										humidity: false,
                  										dewPoint: false,
                  										uvIndex: false
                    sdetweil @cwong79
                    @cwong79 I added the code wrapper around your config info
                    to do this
                    paste your text.
                    select it
                    then push the button </>
                    above the editor window
                    C 1 Reply Last reply
                      cwong79 @sdetweil
                      @sdetweil thank you. Sorry, its my first post.
                      • N6NGN
                        N6NG
                        Darksky is no longer accepting new signups. Just an FYI
                        Dennis
                        • goldyfruitG
                          goldyfruit Project Sponsor
                          Re: MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast
                          I opened an issue on GitHub about the CPU consumption, anyone else with the same symptom?
                          https://github.com/jclarke0000/MMM-OpenWeatherForecast/issues/14
                          Build smart things with magic and love! | https://smartgic.io
                          • A
                            airclown
                            Love the module, Is there a way to have the module show - Horizontally?
                            Like moving the Hourly and 5/3 day to the right side of the current? so 1 row with 3 columns.
                            Thank You
                              j.e.f.f Project Sponsor Module Developer @airclown
                              @airclown if you know what you’re doing with CSS this is certainly doable in your custom.css file. The module’s HTML is structured in such a way as to not restrict reordering through CSS
                              G 1 Reply Last reply
                              • G
                                gekberlin @j.e.f.f
                                Hi all,
                                has anyone a suggestion how to move the temprature in tiled mode next to the icon in one row?
                                I mean just like in the picture given ?
                                I really don’t understand the syntax of the nunjucks part.
                                  Ray
                                  Hey guys in the alert status. I show the following 3 items
                                  Excessive heat watch
                                  heat advisory
                                  small craft advisory
                                  Is there a way I can eliminate small craft advisory
                                  or just use heat advisory
                                  • plainbrokeP
                                    plainbroke
                                    When will Darksky fail to work anymore.
                                    I have it running now and it works fine.
                                    What am I missing?
                                    BKeyportB J 2 Replies Last reply
                                    • BKeyportB
                                      BKeyport Module Developer @plainbroke
                                      @plainbroke If you have an API key from before Apple bought it up, Darksky still will work. They’re just not issuing new API keys any longer, and Apple seems to be wanting to put all of Darksky’s features into their own app, and use the API for themselves, so I doubt old keys are gonna go away any time soon.
                                      karsten13K 1 Reply Last reply
                                      • karsten13K
                                        karsten13 @BKeyport
                                        see https://blog.darksky.net/
                                        BKeyportB 1 Reply Last reply
                                        • BKeyportB
                                          BKeyport Module Developer @karsten13
                                          @karsten13 Ahh, so rather than doing the API into the weather app, Apple’s decided to rewrite it completely. Good to know.
                                            j.e.f.f Project Sponsor Module Developer @plainbroke
                                            @plainbroke said in MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast:
                                            What am I missing?
                                            I just received an email last week from Apple saying that Dark Sky API will stop working on March 31 2023.
                                            So you have a while yet before it goes belly up. And who knows… Apple might extend this out past the deadline.
                                            plainbrokeP 1 Reply Last reply
                                            • 12
                                            • 13
                                            • 6 / 13
