    MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast
    259 Posts 55 Posters 721.4k Views 57 Watching
    • F
      fillilutten
      I’m sorry if this is stupid - but I’m currently showing extraCurrentConditions - high/low + precipitation. And precipitation shows in “mm” and I’d prefer if it could show in % how likely it is to rain/snow that day. So I know if I should bring an umbrella or not.
      Is this possible? I tried using hourly forecast + extras and set that to 12 hours interval and only show one daily. But it didn’t work.
      Thanks!
        rcberg3
        @j-e-f-f any way to hide the wind units in the hourly and daily forecasts? I’m finding that they’re pushing onto a second line when the wind speed is greater than 2 digits. I’d be happy just to show the number and not the units.
        J 1 Reply Last reply
          j.e.f.f Project Sponsor Module Developer @rcberg3
          @rcberg3 sorry, the code doesn’t currently allow for this, nor do the units have their own CSS class that you can use to hide them.
          You could instead increase the width of the module in order to give the forecast a bit more space to stop the wind units from wrapping to a second line. Instructions to do so are included in the readme.
          R 1 Reply Last reply
            rcberg3 @j.e.f.f
            @j-e-f-f Appreciate it! I added the nowrap to the css for now and it’s better.
              MMuser
              Hi is it possible to swap warnings and extra weather info, like shown below ?
                cwong79
                I am a complete newbie. I followed the instructions exactly, I even did it multiple times to ensure it was done correctly. As during installation process, some warnings around vulnerability kicked up and I attempted to resolve. I removed the copy and reinstalled MMM-OpenWeatherForecast. I have the default weather module commented out and just running this module. I cannot get it working, not sure why. I copied the sample configuration and inserted the appropriate API key and Long/Lat. What am I doing wrong?
                			module: "MMM-OpenWeatherForecast",
                			header: "Forecast",
                						apikey: "??????????", //SUPER SECRET
                						latitude: 26.124161,
                						longitude: -80.143593,
                						units: "imperial",
                						iconset: "3c",
                						colored: true,
                						concise: true,
                						requestDelay: "2000",
                						showFeelsLikeTemp: true,
                						showCurrentConditions: true,
                						showSummary: true,
                						showExtraCurrentConditions: true,
                						extraCurrentConditions: {
                													highLowTemp: true,
                													precipitation: true,
                													sunrise: true,
                													sunset: true,
                													wind: true,
                													barometricPressure: false,
                													humidity: true,
                													dewPoint: false,
                													uvIndex: true,
                													visibility: false
                						forecastLayout: "table",
                						forecastHeaderText: "",
                						hourlyForecastTableHeaderText: "By the hour",
                						showHourlyForecast: true,
                						showHourlyTableHeaderRow: true,
                						hourlyForecastInterval: 1,
                						maxHourliesToShow: 10,
                						hourlyExtras: {
                											wind: true,
                											humidity: false,
                											dewPoint: false,
                											uvIndex: false,
                											visibility: false
                						dailyForecastTableHeaderText: "Throughout the week",
                						showDailyForecast: true,
                						showDailyTableHeaderRow: true,
                						maxDailiesToShow: 5,
                						dailyExtras: {
                										sunrise: false,
                										sunset: false,
                										wind: true,
                										humidity: false,
                										dewPoint: false,
                										uvIndex: false
                  sdetweil @cwong79
                  @cwong79 I added the code wrapper around your config info
                  to do this
                  paste your text.
                  select it
                  then push the button </>
                  above the editor window
                  C 1 Reply Last reply
                    cwong79 @sdetweil
                    @sdetweil thank you. Sorry, its my first post.
                    • N6NGN
                      N6NG
                      Darksky is no longer accepting new signups. Just an FYI
                      Dennis
                      • goldyfruitG
                        goldyfruit Project Sponsor
                        Re: MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast
                        I opened an issue on GitHub about the CPU consumption, anyone else with the same symptom?
                        https://github.com/jclarke0000/MMM-OpenWeatherForecast/issues/14
                        Build smart things with magic and love! | https://smartgic.io
                        • A
                          airclown
                          Love the module, Is there a way to have the module show - Horizontally?
                          Like moving the Hourly and 5/3 day to the right side of the current? so 1 row with 3 columns.
                          Thank You
                            j.e.f.f Project Sponsor Module Developer @airclown
                            @airclown if you know what you’re doing with CSS this is certainly doable in your custom.css file. The module’s HTML is structured in such a way as to not restrict reordering through CSS
                            G 1 Reply Last reply
                            • G
                              gekberlin @j.e.f.f
                              Hi all,
                              has anyone a suggestion how to move the temprature in tiled mode next to the icon in one row?
                              I mean just like in the picture given ?
                              I really don’t understand the syntax of the nunjucks part.
                                Ray
                                Hey guys in the alert status. I show the following 3 items
                                Excessive heat watch
                                heat advisory
                                small craft advisory
                                Is there a way I can eliminate small craft advisory
                                or just use heat advisory
                                • plainbrokeP
                                  plainbroke
                                  When will Darksky fail to work anymore.
                                  I have it running now and it works fine.
                                  What am I missing?
                                  BKeyportB J 2 Replies Last reply
                                  • BKeyportB
                                    BKeyport Module Developer @plainbroke
                                    @plainbroke If you have an API key from before Apple bought it up, Darksky still will work. They’re just not issuing new API keys any longer, and Apple seems to be wanting to put all of Darksky’s features into their own app, and use the API for themselves, so I doubt old keys are gonna go away any time soon.
                                    karsten13K 1 Reply Last reply
                                    • karsten13K
                                      karsten13 @BKeyport
                                      see https://blog.darksky.net/
                                      BKeyportB 1 Reply Last reply
                                      • BKeyportB
                                        BKeyport Module Developer @karsten13
                                        @karsten13 Ahh, so rather than doing the API into the weather app, Apple’s decided to rewrite it completely. Good to know.
                                          j.e.f.f Project Sponsor Module Developer @plainbroke
                                          @plainbroke said in MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast:
                                          What am I missing?
                                          I just received an email last week from Apple saying that Dark Sky API will stop working on March 31 2023.
                                          So you have a while yet before it goes belly up. And who knows… Apple might extend this out past the deadline.
                                          plainbrokeP 1 Reply Last reply
                                          • plainbrokeP
                                            plainbroke @j.e.f.f
                                            Thank you all for information. I was upset. I really like the way my Darksky weather module looks on my screen. I guess in march next year I will think about having to change over to something else. Maybe by then someone will make it so the Darksky module works with another weather api…
                                            • 12
                                            • 13
                                            • 6 / 13
