    MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast
    259 Posts 55 Posters 713.6k Views 57 Watching
      sil3ntstorm
      Great job, I like it very much, thanks for that.
      I’ve had it running for about 8 weeks and I’ve noticed that my temperature readings are correct, but my weather is always showing as cloudy or rainy in advance, even though the sun has been shining 90% of the time for weeks and almost never rains
      I checked the latitude and longitude several times and read them out and accepted them either via https://www.latlong.net/ or via google.
      What can be the reason for the fact that I keep getting only clouds and rain, even though the sun is shining most of the time?
      Place of residence is: Germany Hohenschambach
      Width 49.039349
      Longitude 11.847070
      I hope you can help me here 😊
      My English skills are not very good, I translated it with google, I hope you understand what I want to say 😊
        sdetweil @sil3ntstorm
        @sil3ntstorm can u show the config.js entry
          sil3ntstorm
              module: "MMM-OpenWeatherForecast",
              header: "Wettervorschau Schama",
                apikey: "XYXYXY", //SUPER SECRET
                latitude: "49.039349",     //49.039349 Hemau
                longitude: "11.847070",    //11.847070 Hemau
                units: "metric",
                iconset: "4c",
                colored: true,
                concise: true,
          			 label_high: "max",
          			 label_low: "min",
          			 label_days: ["So", "Mo", "Di", "Mi", "Do", "Fr", "Sa"],
          			 label_sunriseTimeFormat: "k:mm",
          			 label_hourlyTimeFormat: "k[h]",
          			 label_hourlyTimeFormat: "k[ Uhr]",
                requestDelay: "2000",
                showFeelsLikeTemp: true,
                displayKmhForWind: true,
                showCurrentConditions: true,
                showSummary: false,
                showExtraCurrentConditions: true,
                extraCurrentConditions: {
                  highLowTemp: true,
                  precipitation: true,
                  sunrise: true,
                  sunset: true,
                  wind: true,
                  barometricPressure: false,
                  humidity: true,
                  dewPoint: false,
                  uvIndex: true,
                  visibility: false
                forecastLayout: "table",
                forecastHeaderText: "",
                hourlyForecastTableHeaderText: "Stundenvorschau",
                showHourlyForecast: true,
                showHourlyTableHeaderRow: true,
                hourlyForecastInterval: 3,
                maxHourliesToShow: 5,
                hourlyExtras: {
                  wind: true,
                  humidity: false,
                  dewPoint: false,
                  uvIndex: false,
                  visibility: false
                dailyForecastTableHeaderText: "Wochenvorschau",
                showDailyForecast: true,
                showDailyTableHeaderRow: true,
                maxDailiesToShow: 10,
                dailyExtras: {
                  sunrise: false,
                  sunset: false,
                  wind: true,
                  humidity: false,
                  dewPoint: false,
                  uvIndex: false
            @sil3ntstorm remove the quotes from around the lat/long… that makes then a string, not a number…
            most modules cannot handle the difference
            anyplace just numbers, remove quotes
              sil3ntstorm
              Like now?
              I did it but the clouds or rain are still displayed to me, no change from before. The 3 apps on the mobile all show sun most of the time and at least 10 hours of sun (just like in the past, always sunny and dry in the app and in real but always cloudy and rainy in the MM module)
                    apikey: "XYXYXYXY", //SUPER SECRET
                    latitude: 49.039349,
                    longitude: 11.847070,
                    units: "metric",
                    iconset: "4c",
                    colored: true,
                    concise: true,
              			 label_high: "max",
              			 label_low: "min",
                    requestDelay: 2000,
                    showSummary: false,
                      highLowTemp: true,
                      sunrise: true,
                      sunset: true,
                      wind: true,
                      humidity: true,
                      dewPoint: false,
                      uvIndex: true,
                      visibility: false
                    hourlyExtras: {
                      wind: true,
                      humidity: false,
                      dewPoint: false,
                      uvIndex: false,
                      visibility: false
                    dailyExtras: {
                      sunrise: false,
                      sunset: false,
                      wind: true,
                      humidity: false,
                      dewPoint: false,
                      uvIndex: false
                @sil3ntstorm thats what the web site shows too
                accuweather shows similar
                  sil3ntstorm
                  The data is read from https://home.openweathermap.org and displayed on the MM, right?
                  Since these often do not match for my area, I want to know whether it is possible to store another provider? For example
                  https://www.wetteronline.de/wettertrend/hemau
                    @sil3ntstorm
                    correct. the module takes info from the openweathermap api (and the data appears valid from the api and web page)
                    but the MMM-OpenWeatherMap module only works with OpenWeather as far as I know.
                    I am not aware of the quality of other modules
                      bassin12
                      I’m having some problems and do not know exactly what is wrong, got this error:
                      [29.08.2022 09:51.32.701] [LOG] [MMM-OpenWeatherForecast] 29-Aug-22 09:51 ** ERROR ** Error: Request failed with status code 401
                      I get this on my screen
                      I did not do any configuration just using this as a Code:
                                              module: "weather",
                                              header: "Weather Forecast",
                                                      type: "forecast",
                                                      locationID: "4225309",
                                                      apiKey: "MYKEY"
                                          header: "Forecast",
                                            apikey: "MYKEY", //only string here
                                            latitude: 51.490230,            //number works here
                                            longitude: -0.258810,          //so does a string
                        sdetweil @bassin12
                        @bassin12 said in MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast:
                        that is configuration (editing config.js)
                        I do not know… the error says the source returned a 401 error code
                        not my module… open an issue on the module github page…
                          sdetweil @bassin12
                          @bassin12 also the code block start (the 3 backtics) must be on the start of the line
                          I edited your post to fix that
                            @bassin12
                            my config , both work (and the default weather module in both current and forecast mode)
                            			apikey: "xxxx",
                            			units:"metric",
                            			iconset: "4c",
                            			colored: true,
                            			concise: true
                            			module: "MMM-OpenWeatherMapForecast",
                            			header: "Weather",
                            			classes: "default everyone",
                            			disabled: false,
                            				apikey: "..",
                            				latitude: "51.506130",
                            				longitude: "-0.090270",
                            				iconset: "4c",
                            				concise: false,
                              bassin12 @sdetweil
                              When I try the code in the config.js I get this in the logs
                              [29.08.2022 10:22.03.630] [LOG] [MMM-OpenWeatherMapForecast] 29-Aug-22 10:22 ** ERROR ** null
                              [29.08.2022 10:22.03.639] [LOG] [MMM-OpenWeatherForecast] 29-Aug-22 10:22 ** ERROR ** Error: Request failed with status code 401
                                sdetweil @bassin12
                                yes, bug in his code…
                                use the code I posted on page one to extend the error reporting
                                but it returns 401 as well…
                                  DDE12
                                  Is there a solution for this error? Is it something I’ve done or something in the module code?
                                  [MMM-OpenWeatherForecast] 12-Nov-22 23:49 ** ERROR ** Error: Request failed with status code 401
                                    sdetweil @DDE12
                                    @DDE12 401 eror is unauthorized
                                    so the apikey you are using has expired
                                      DDE12 @sdetweil
                                      I setup the default weather module with OpenWeather and it is working with the key I have. I obtained the key a few days ago. Is it the same key for MMM-OpenWeatherForecast?
                                        sdetweil @DDE12
                                        @DDE12 no idea
                                        the module says go here
                                        https://home.openweathermap.org/users/sign_up
                                        the default weather openWeathermap provide says
                                        https://home.openweathermap.org/users/sign_in
                                        so it would seem the same key
                                        the module uses this path
                                        https://api.openweathermap.org/data/2.5/onecall?"
                                        the default module uses this
                                        		apiVersion: "2.5",
                                        		apiBase: "https://api.openweathermap.org/data/"
        +apiVersion+"onecall?"
                                        so, they appear the same
                                          DDE12 @sdetweil
                                          I put in a new key just to see but still have the same 401 error. When I installed the module I got
                                          npm WARN old lockfile
                                          npm WARN old lockfile The package-lock.json file was created with an old version of npm,
                                          npm WARN old lockfile so supplemental metadata must be fetched from the registry.
                                          npm WARN old lockfile This is a one-time fix-up, please be patient...
                                          added 4 packages, and audited 391 packages in 50s
                                          1 package is looking for funding
                                            run `npm fund` for details
                                          39 vulnerabilities (2 low, 15 moderate, 19 high, 3 critical)
                                          To address all issues, run:
                                            npm audit fix
                                          Run `npm audit` for details.
                                          I did not run audit fix. Is there something that I need to do with the install?
                                            sdetweil @DDE12
                                            @DDE12 NEVER run audit fix…
                                            i don’t know why the MMM-OpenWeatherForecast is failing ,
                                            other than it says unauthorized. i would open an issue for the author.
                                            • 12
                                            • 13
                                            • 7 / 13
