    MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast
    259 Posts 55 Posters 721.4k Views 57 Watching
      bassin12
      I’m having some problems and do not know exactly what is wrong, got this error:
      [29.08.2022 09:51.32.701] [LOG] [MMM-OpenWeatherForecast] 29-Aug-22 09:51 ** ERROR ** Error: Request failed with status code 401
      I get this on my screen
      I did not do any configuration just using this as a Code:
                              module: "weather",
                              header: "Weather Forecast",
                                      type: "forecast",
                                      locationID: "4225309",
                                      apiKey: "MYKEY"
                          module: "MMM-OpenWeatherForecast",
                          header: "Forecast",
                            apikey: "MYKEY", //only string here
                            latitude: 51.490230,            //number works here
                            longitude: -0.258810,          //so does a string
      S 2 Replies Last reply
        sdetweil @bassin12
        @bassin12 said in MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast:
        that is configuration (editing config.js)
        I do not know… the error says the source returned a 401 error code
        not my module… open an issue on the module github page…
          sdetweil @bassin12
          @bassin12 also the code block start (the 3 backtics) must be on the start of the line
          I edited your post to fix that
            @bassin12
            my config , both work (and the default weather module in both current and forecast mode)
            		header: "Wettervorschau Schama",
            			apikey: "xxxx",
            			latitude: 49.039349,
            			longitude: 11.847070,
            			units:"metric",
            			iconset: "4c",
            			colored: true,
            			concise: true
            			module: "MMM-OpenWeatherMapForecast",
            			header: "Weather",
            			classes: "default everyone",
            			disabled: false,
            				apikey: "..",
            				latitude: "51.506130",
            				longitude: "-0.090270",
            				iconset: "4c",
            				concise: false,
            				forecastLayout: "table"
            B 1 Reply Last reply
              bassin12 @sdetweil
              When I try the code in the config.js I get this in the logs
              [29.08.2022 10:22.03.630] [LOG] [MMM-OpenWeatherMapForecast] 29-Aug-22 10:22 ** ERROR ** null
              [29.08.2022 10:22.03.639] [LOG] [MMM-OpenWeatherForecast] 29-Aug-22 10:22 ** ERROR ** Error: Request failed with status code 401
                sdetweil @bassin12
                yes, bug in his code…
                use the code I posted on page one to extend the error reporting
                but it returns 401 as well…
                  DDE12
                  Is there a solution for this error? Is it something I’ve done or something in the module code?
                  [MMM-OpenWeatherForecast] 12-Nov-22 23:49 ** ERROR ** Error: Request failed with status code 401
                    sdetweil @DDE12
                    @DDE12 401 eror is unauthorized
                    so the apikey you are using has expired
                    D 1 Reply Last reply
                      DDE12 @sdetweil
                      I setup the default weather module with OpenWeather and it is working with the key I have. I obtained the key a few days ago. Is it the same key for MMM-OpenWeatherForecast?
                        sdetweil @DDE12
                        @DDE12 no idea
                        the module says go here
                        https://home.openweathermap.org/users/sign_up
                        the default weather openWeathermap provide says
                        https://home.openweathermap.org/users/sign_in
                        so it would seem the same key
                        the module uses this path
                        https://api.openweathermap.org/data/2.5/onecall?"
                        the default module uses this
                        		apiVersion: "2.5",
                        		apiBase: "https://api.openweathermap.org/data/"
                                                +apiVersion+"onecall?"
                        so, they appear the same
                          DDE12 @sdetweil
                          I put in a new key just to see but still have the same 401 error. When I installed the module I got
                          npm WARN old lockfile
                          npm WARN old lockfile The package-lock.json file was created with an old version of npm,
                          npm WARN old lockfile so supplemental metadata must be fetched from the registry.
                          npm WARN old lockfile This is a one-time fix-up, please be patient...
                          added 4 packages, and audited 391 packages in 50s
                          1 package is looking for funding
                            run `npm fund` for details
                          39 vulnerabilities (2 low, 15 moderate, 19 high, 3 critical)
                          To address all issues, run:
                            npm audit fix
                          Run `npm audit` for details.
                          I did not run audit fix. Is there something that I need to do with the install?
                            sdetweil @DDE12
                            @DDE12 NEVER run audit fix…
                            i don’t know why the MMM-OpenWeatherForecast is failing ,
                            other than it says unauthorized. i would open an issue for the author.
                              @DDE12 Could you share your config? Also be sure put your API key in quotes in the configuration. If you aren’t using quotes, this could be a reason why the module is giving you the 401 error
                                DDE12
                                @j-e-f-f
                                I can, but I think I figured it out last night without changing anything in MM or the module. I initially signed up for the free account on OpenWeatherMap. Last night I signed up for the One Call by Call https://openweathermap.org/api and MMM-OpenWeatherForecast starting working. Before signing up, I tested my API in a browser at https://api.openweathermap.org/data/2.5/onecall?lat=someLatitude&lon=someLongitude&appid=secretAPI
                                and at https://api.openweathermap.org/data/3.0/onecall?lat=someLatitude&lon=someLongitude&appid=secretAPI
                                and both reported 401 error. After signing up, the module began working in MM. This does require a credit card and subscribers get 1000 free calls per day. Subscribers can set the maximum number of calls in their dashboard to prevent going over and getting charged. This doesn’t seem like it would be too much of a problem if users set the module’s config appropriately.
                                I’m guessing that the module is trying to get data that is no longer free and some API’s are grandfathered ?? Or I misunderstood what type of account I needed from the start.
                                Where is the API address in the module’s code?
                                Let me know if I can provide further information.
                                T S 2 Replies Last reply
                                • T
                                  trividar @DDE12
                                  If the Module doesn’t load the informations change ```
                                  “https://api.openweathermap.org/data/3.0/onecall”
                                  to
                                  “https://api.openweathermap.org/data/3.0/onecall?”
                                  an it should work!
                                    sdetweil @DDE12
                                    @DDE12 the API url is in the node_helper.js
                                    we recently add a Parm to enable picking v3 of the API vs 2.5 (old free).
                                    the add on modules need to do the same
                                    • Y
                                      yk
                                      Fantastic work! I was using the previous DarkSkyForecast version - easy shift to this one.
                                      I’m trying to put the hourly data and daily data in the same “row” across using tiled view instead of 2 rows. I’m happy to edit the njk file (have tweaked a bit haven’t gotten it “just right” yet). Any ideas? I gather it’s something with the hourly and daily divs.
                                      Is data available to get mm of precipitation in the hourly and daily blocks? It shows % chance - keen to add precipitation instead.
                                      Thanks!!
                                      Y 1 Reply Last reply
                                      • Y
                                        yk @yk
                                        @yk said in MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast:
                                        Thanks!!
                                        Replying to my own post incase someone else wants a single row for 3 hours and 3 days. You’ll need to comment out lines 191, 309, 315, 318 in the njk file. This results in a single row readable left to right hours then days. It’s a useful view if you’re using a full width view.
                                          justbob
                                          So what’s the solution for the 401 error?
                                          The key works in default weather module, but in this one it’s not.
                                          @sdetweil said in MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast:
                                          Can you elaborate why?
                                          I for one don’t like seeing vulnerabilities and critical messages anywhere, and letting security flaws linger…
                                            sdetweil @justbob
                                            @justbob audit fix forces changes, and many times drags in breaking changes that we can do nothing about.
                                            we are not running a web site w hundreds of random users, and are not dragging in other page content with their scripts. we are calling apis…
                                            so the risks for (y)our site is extremely small…
                                            I don’t know the answer on openweathermap.
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 8 / 13
