    After update 2.23.0 crash
    56 Posts 9 Posters 33.4k Views 8 Watching
    • swvalentiS
      swvalenti Project Sponsor @swvalenti
      @swvalenti said in After update 2.23.0 crash:
      @JerryP said in After update 2.23.0 crash:
      pi@raspberrypi:~/MagicMirror $ ls
       CHANGELOG.md   Collaboration.md   core  'DISPLAY=:0'   index.html   jest.config.js   jsconfig.json   magicmirror@2.23.0   module-types.ts   oud         run-start.sh   splashscreen   th.json        vendor
       clientonly     config             css    fonts         installers   js               LICENSE.md      modules              node_modules      README.md   serveronly     tests          translations
      pi@raspberrypi:~/MagicMirror $ npm install
      npm ERR! code ENOTEMPTY
      npm ERR! syscall rename
      npm ERR! path /home/pi/MagicMirror/node_modules/acorn
      npm ERR! dest /home/pi/MagicMirror/node_modules/.acorn-pnTZ3fig
      npm ERR! errno -39
      npm ERR! ENOTEMPTY: directory not empty, rename '/home/pi/MagicMirror/node_modules/acorn' -> '/home/pi/MagicMirror/node_modules/.acorn-pnTZ3fig'
      npm ERR!     /home/pi/.npm/_logs/2023-04-04T20_43_20_803Z-debug-0.log
      That didn’t work, no worries I will revert
      The package.json showed no issue with that command. It worked when I reverted no issue.
        sdetweil @swvalenti
        @swvalenti how did you revert?
        swvalentiS 1 Reply Last reply Reply Quote 0
        • swvalentiS
          swvalenti Project Sponsor @sdetweil
          @sdetweil said in After update 2.23.0 crash:
          Copied original file and renamed before using your script.
            sdetweil @swvalenti
            @swvalenti got it…
            • swvalentiS
              @swvalenti got it…
              Thought maybe the script would catch it. Ha. Oh well thanks for all your help and work.
                sdetweil @swvalenti
                @swvalenti the script DID catch for request, but not jsdom…
                these are the undocumented libs used
                OWGR.js:const request = require('request');
                OWGR.js:const jsdom = require("jsdom");
                I just added that to the upgrade script list of missing libs
                • swvalentiS
                  Cool so if I update it will work?
                    sdetweil @swvalenti
                    @swvalenti should…
                    • swvalentiS
                      @swvalenti should…
                      Thanks Sam I’ll report back
                        sdetweil @swvalenti
                        @swvalenti nope it wont work as it is… looks only in the node_helper… oops…
                        working on fix…
                        pushed a fix
                        • swvalentiS
                          working on fix…
                          pushed a fix
                          Ran upgrade script but still didn’t work same error
                            sdetweil @swvalenti
                            @swvalenti can u post the ~/MagicMirror/installers/upgrade.log
                            • swvalentiS
                              @sdetweil Here ya go
                              https://drive.google.com/file/d/1L5ORoBJlEV6lYSLzJC7VhHM1S1P-jRWy/view?usp=share_link
                                sdetweil @swvalenti
                                @swvalenti ok , because you had already done upgrade on this instance. apply doesnt do anything
                                do force
                                at the end instead of apply
                                swvalentiS 1 Reply Last reply Reply Quote 1
                                • swvalentiS
                                  @sdetweil You are the man worked like a charm. Only thing I noticed when running on windows “alt” does not bring the toolbar up in order to quit MM. Did anything change?
                                    sdetweil @swvalenti
                                    @swvalenti alt-spacebar, or ctrl-m
                                    ctrl-q to quit, if not using pm2.
                                    pm2 will just restart it
                                    • swvalentiS
                                      @sdetweil ctrl m worked thanks Sam!
                                        JoeFranz
                                        Same here, error after Update :-(
                                        @sdetweil Update with your script
                                        (Use electron --trace-warnings ... to show where the warning was created)
                                        [05.04.2023 07:02.12.571] [ERROR] (node:4893) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 2)
                                        [4932:0405/070214.077646:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                                        [4962:0405/070214.418104:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
                                          JoeFranz
                                          I ran “electron-rebuild”, now it works again :-)
                                            sdetweil @JoeFranz
                                            @JoeFranz on what module?
                                            J W 2 Replies Last reply Reply Quote 0
                                            • 2 / 3
