    After update 2.23.0 crash
    56 Posts 9 Posters 33.4k Views 8 Watching
      sdetweil @swvalenti
      @swvalenti the script DID catch for request, but not jsdom…
      these are the undocumented libs used
      OWGR.js:const request = require('request');
      OWGR.js:const jsdom = require("jsdom");
      I just added that to the upgrade script list of missing libs
      swvalentiS 1 Reply Last reply Reply Quote 0
      • swvalentiS
        swvalenti Project Sponsor @sdetweil
        @sdetweil said in After update 2.23.0 crash:
        Cool so if I update it will work?
          sdetweil @swvalenti
          @swvalenti should…
          • swvalentiS
            @swvalenti should…
            Thanks Sam I’ll report back
              sdetweil @swvalenti
              @swvalenti nope it wont work as it is… looks only in the node_helper… oops…
              working on fix…
              pushed a fix
              • swvalentiS
                working on fix…
                pushed a fix
                Ran upgrade script but still didn’t work same error
                  sdetweil @swvalenti
                  @swvalenti can u post the ~/MagicMirror/installers/upgrade.log
                  • swvalentiS
                    @sdetweil Here ya go
                    https://drive.google.com/file/d/1L5ORoBJlEV6lYSLzJC7VhHM1S1P-jRWy/view?usp=share_link
                      sdetweil @swvalenti
                      @swvalenti ok , because you had already done upgrade on this instance. apply doesnt do anything
                      do force
                      at the end instead of apply
                      swvalentiS 1 Reply Last reply Reply Quote 1
                      • swvalentiS
                        @sdetweil You are the man worked like a charm. Only thing I noticed when running on windows “alt” does not bring the toolbar up in order to quit MM. Did anything change?
                          sdetweil @swvalenti
                          @swvalenti alt-spacebar, or ctrl-m
                          ctrl-q to quit, if not using pm2.
                          pm2 will just restart it
                          • swvalentiS
                            @sdetweil ctrl m worked thanks Sam!
                              JoeFranz
                              Same here, error after Update :-(
                              @sdetweil Update with your script
                              (Use electron --trace-warnings ... to show where the warning was created)
                              [05.04.2023 07:02.12.571] [ERROR] (node:4893) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 2)
                              [4932:0405/070214.077646:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                              [4962:0405/070214.418104:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
                                JoeFranz
                                I ran “electron-rebuild”, now it works again :-)
                                  sdetweil @JoeFranz
                                  @JoeFranz on what module?
                                  J W 2 Replies Last reply Reply Quote 0
                                    JoeFranz @sdetweil
                                    @sdetweil MMM-PIR-Sensor
                                    • W
                                      Wenike @sdetweil
                                      @sdetweil By chance, do you know of a command I can run to kill any running Node processes? I’m trying to run your upgrade script and its unable to upgrade Node because a process is already running. Googling gives me code to use within an application but that doesn’t seem like it’ll work from the CLI.
                                      doing test run = false
                                      Minimum Node version: v16.13.1
                                      Installed Node version: v10.24.1
                                      Node should be upgraded.
                                      A Node process is currently running. Can't upgrade.
                                      Please quit all Node processes and restart the update.
                                      running process(s) are
                                      pi 881 879 0 09:05 ? 00:00:00 node ./node_modules/.bin/electron js/electron.js
                                      • mumblebajM
                                        mumblebaj Module Developer @JerryP
                                        @JerryP Always use Sam’s update script. I used it last night and updated from 2.21.0 to 2.23.0 no issues. Often modules with a package.json requires an npm install in that folder and the upgrade script takes care of all of that.
                                          sdetweil @Wenike
                                          @Wenike do this
                                          from a terminal window
                                          ps -ef | grep node
                                          this will show you the node processes running and parms to what they are running (file path)
                                          if all looks understandable and u can’t terminate them thru app shutdown (pm2 stop all will stop all.managed apps, mm included), do
                                          ps -ef | grep node | awk '{ print $2 }' | xargs kill -9
                                          this will hard kill all the node processes
                                            sdetweil @JoeFranz
                                            @JoeFranz
                                            the script does a new npm install in modules that have a package.json
                                            but I know the post install process is wrong for this module
                                            my fork fixes that
                                            https://github.com/sdetweil/MMM-PIR-Sensor
                                            • 2 / 3
