    After update 2.23.0 crash
    56 Posts 9 Posters 34.2k Views 8 Watching
    • swvalentiS
      swvalenti Project Sponsor @sdetweil
      @sdetweil said in After update 2.23.0 crash:
      @swvalenti how did you revert?
      Copied original file and renamed before using your script.
        sdetweil @swvalenti
        @swvalenti got it…
        swvalentiS 1 Reply Last reply
        • swvalentiS
          @swvalenti got it…
          Thought maybe the script would catch it. Ha. Oh well thanks for all your help and work.
            sdetweil @swvalenti
            @swvalenti the script DID catch for request, but not jsdom…
            these are the undocumented libs used
            OWGR.js:const request = require('request');
            OWGR.js:const jsdom = require("jsdom");
            I just added that to the upgrade script list of missing libs
            • swvalentiS
              Cool so if I update it will work?
                sdetweil @swvalenti
                @swvalenti should…
                • swvalentiS
                  @swvalenti should…
                  Thanks Sam I’ll report back
                    sdetweil @swvalenti
                    @swvalenti nope it wont work as it is… looks only in the node_helper… oops…
                    working on fix…
                    pushed a fix
                    • swvalentiS
                      working on fix…
                      pushed a fix
                      Ran upgrade script but still didn’t work same error
                        sdetweil @swvalenti
                        @swvalenti can u post the ~/MagicMirror/installers/upgrade.log
                        • swvalentiS
                          @sdetweil Here ya go
                          https://drive.google.com/file/d/1L5ORoBJlEV6lYSLzJC7VhHM1S1P-jRWy/view?usp=share_link
                            sdetweil @swvalenti
                            @swvalenti ok , because you had already done upgrade on this instance. apply doesnt do anything
                            do force
                            at the end instead of apply
                            • swvalentiS
                              @sdetweil You are the man worked like a charm. Only thing I noticed when running on windows “alt” does not bring the toolbar up in order to quit MM. Did anything change?
                                sdetweil @swvalenti
                                @swvalenti alt-spacebar, or ctrl-m
                                ctrl-q to quit, if not using pm2.
                                pm2 will just restart it
                                • swvalentiS
                                  @sdetweil ctrl m worked thanks Sam!
                                    JoeFranz
                                    Same here, error after Update :-(
                                    @sdetweil Update with your script
                                    (Use electron --trace-warnings ... to show where the warning was created)
                                    [05.04.2023 07:02.12.571] [ERROR] (node:4893) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 2)
                                    [4932:0405/070214.077646:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                                    [4962:0405/070214.418104:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
                                      JoeFranz
                                      I ran “electron-rebuild”, now it works again :-)
                                        sdetweil @JoeFranz
                                        @JoeFranz on what module?
                                        J W 2 Replies Last reply
                                          JoeFranz @sdetweil
                                          @sdetweil MMM-PIR-Sensor
                                          • W
                                            Wenike @sdetweil
                                            @sdetweil By chance, do you know of a command I can run to kill any running Node processes? I’m trying to run your upgrade script and its unable to upgrade Node because a process is already running. Googling gives me code to use within an application but that doesn’t seem like it’ll work from the CLI.
                                            doing test run = false
                                            Minimum Node version: v16.13.1
                                            Installed Node version: v10.24.1
                                            Node should be upgraded.
                                            A Node process is currently running. Can't upgrade.
                                            Please quit all Node processes and restart the update.
                                            running process(s) are
                                            pi 881 879 0 09:05 ? 00:00:00 node ./node_modules/.bin/electron js/electron.js
                                            • 2 / 3
