    After update 2.23.0 crash
    56 Posts 9 Posters 34.2k Views 8 Watching
      sdetweil @JerryP
      @JerryP looks like u got carried away with sudo rm /home/pi/MagicMirror/package-lock.json (notice the -lock)
      and deleted the package.json
      git checkout package.json
      and npm install again
      • swvalentiS
        swvalenti Project Sponsor @JerryP
        @JerryP said in After update 2.23.0 crash:
        pi@raspberrypi:~/MagicMirror $ ls
         CHANGELOG.md   Collaboration.md   core  'DISPLAY=:0'   index.html   jest.config.js   jsconfig.json   magicmirror@2.23.0   module-types.ts   oud         run-start.sh   splashscreen   th.json        vendor
         clientonly     config             css    fonts         installers   js               LICENSE.md      modules              node_modules      README.md   serveronly     tests          translations
        pi@raspberrypi:~/MagicMirror $ npm install
        npm ERR! code ENOTEMPTY
        npm ERR! syscall rename
        npm ERR! path /home/pi/MagicMirror/node_modules/acorn
        npm ERR! dest /home/pi/MagicMirror/node_modules/.acorn-pnTZ3fig
        npm ERR! errno -39
        npm ERR! ENOTEMPTY: directory not empty, rename '/home/pi/MagicMirror/node_modules/acorn' -> '/home/pi/MagicMirror/node_modules/.acorn-pnTZ3fig'
        npm ERR!     /home/pi/.npm/_logs/2023-04-04T20_43_20_803Z-debug-0.log
        That didn’t work, no worries I will revert
        S swvalentiS 2 Replies Last reply
          sdetweil @swvalenti
          @swvalenti what didn’t work?
          u are supposed to be doing the npm install of the missing libs in the module (MMM-PGA) folder
          i don’t think revert will help, the undocumented libraries were deleted by npm… not us
          that .acorn file needs to be deleted
          • swvalentiS
            swvalenti Project Sponsor @swvalenti
            @swvalenti said in After update 2.23.0 crash:
            npm ERR! errno -39
            The package.json showed no issue with that command. It worked when I reverted no issue.
              sdetweil @swvalenti
              @swvalenti how did you revert?
              swvalentiS 1 Reply Last reply
              • swvalentiS
                swvalenti Project Sponsor @sdetweil
                @sdetweil said in After update 2.23.0 crash:
                Copied original file and renamed before using your script.
                  sdetweil @swvalenti
                  @swvalenti got it…
                  • swvalentiS
                    @swvalenti got it…
                    Thought maybe the script would catch it. Ha. Oh well thanks for all your help and work.
                      sdetweil @swvalenti
                      @swvalenti the script DID catch for request, but not jsdom…
                      these are the undocumented libs used
                      OWGR.js:const request = require('request');
                      OWGR.js:const jsdom = require("jsdom");
                      I just added that to the upgrade script list of missing libs
                      • swvalentiS
                        Cool so if I update it will work?
                          sdetweil @swvalenti
                          @swvalenti should…
                          • swvalentiS
                            @swvalenti should…
                            Thanks Sam I’ll report back
                              sdetweil @swvalenti
                              @swvalenti nope it wont work as it is… looks only in the node_helper… oops…
                              working on fix…
                              pushed a fix
                              • swvalentiS
                                working on fix…
                                pushed a fix
                                Ran upgrade script but still didn’t work same error
                                  sdetweil @swvalenti
                                  @swvalenti can u post the ~/MagicMirror/installers/upgrade.log
                                  • swvalentiS
                                    @sdetweil Here ya go
                                    https://drive.google.com/file/d/1L5ORoBJlEV6lYSLzJC7VhHM1S1P-jRWy/view?usp=share_link
                                      sdetweil @swvalenti
                                      @swvalenti ok , because you had already done upgrade on this instance. apply doesnt do anything
                                      do force
                                      at the end instead of apply
                                      • swvalentiS
                                        @sdetweil You are the man worked like a charm. Only thing I noticed when running on windows “alt” does not bring the toolbar up in order to quit MM. Did anything change?
                                          sdetweil @swvalenti
                                          @swvalenti alt-spacebar, or ctrl-m
                                          ctrl-q to quit, if not using pm2.
                                          pm2 will just restart it
                                          • swvalentiS
                                            @sdetweil ctrl m worked thanks Sam!
                                            • 2 / 3
