    After update 2.23.0 crash
    56 Posts 9 Posters 33.4k Views 8 Watching
    • swvalentiS
      swvalenti Project Sponsor @sdetweil
      @sdetweil Here ya go
      https://drive.google.com/file/d/1L5ORoBJlEV6lYSLzJC7VhHM1S1P-jRWy/view?usp=share_link
        sdetweil @swvalenti
        @swvalenti ok , because you had already done upgrade on this instance. apply doesnt do anything
        do force
        at the end instead of apply
        swvalentiS 1 Reply Last reply Reply Quote 1
        • swvalentiS
          @sdetweil You are the man worked like a charm. Only thing I noticed when running on windows “alt” does not bring the toolbar up in order to quit MM. Did anything change?
            sdetweil @swvalenti
            @swvalenti alt-spacebar, or ctrl-m
            ctrl-q to quit, if not using pm2.
            pm2 will just restart it
            swvalentiS 1 Reply Last reply Reply Quote 0
            • swvalentiS
              @sdetweil ctrl m worked thanks Sam!
                JoeFranz
                Same here, error after Update :-(
                @sdetweil Update with your script
                (Use electron --trace-warnings ... to show where the warning was created)
                [05.04.2023 07:02.12.571] [ERROR] (node:4893) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 2)
                [4932:0405/070214.077646:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                [4962:0405/070214.418104:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
                  JoeFranz
                  I ran “electron-rebuild”, now it works again :-)
                    sdetweil @JoeFranz
                    @JoeFranz on what module?
                    J W 2 Replies Last reply Reply Quote 0
                      JoeFranz @sdetweil
                      @sdetweil MMM-PIR-Sensor
                      • W
                        Wenike @sdetweil
                        @sdetweil By chance, do you know of a command I can run to kill any running Node processes? I’m trying to run your upgrade script and its unable to upgrade Node because a process is already running. Googling gives me code to use within an application but that doesn’t seem like it’ll work from the CLI.
                        doing test run = false
                        Minimum Node version: v16.13.1
                        Installed Node version: v10.24.1
                        Node should be upgraded.
                        A Node process is currently running. Can't upgrade.
                        Please quit all Node processes and restart the update.
                        running process(s) are
                        pi 881 879 0 09:05 ? 00:00:00 node ./node_modules/.bin/electron js/electron.js
                        • mumblebajM
                          mumblebaj Module Developer @JerryP
                          @JerryP Always use Sam’s update script. I used it last night and updated from 2.21.0 to 2.23.0 no issues. Often modules with a package.json requires an npm install in that folder and the upgrade script takes care of all of that.
                            sdetweil @Wenike
                            @Wenike do this
                            from a terminal window
                            ps -ef | grep node
                            this will show you the node processes running and parms to what they are running (file path)
                            if all looks understandable and u can’t terminate them thru app shutdown (pm2 stop all will stop all.managed apps, mm included), do
                            ps -ef | grep node | awk '{ print $2 }' | xargs kill -9
                            this will hard kill all the node processes
                              sdetweil @JoeFranz
                              @JoeFranz
                              the script does a new npm install in modules that have a package.json
                              but I know the post install process is wrong for this module
                              my fork fixes that
                              https://github.com/sdetweil/MMM-PIR-Sensor
                              • W
                                Wenike @sdetweil
                                @sdetweil Perfect, fixed it. Thanks!
                                  sdetweil @JerryP
                                  @JerryP said in After update 2.23.0 crash:
                                  sudo git pull
                                  just one more thing
                                  NEVER use sudo with MM no need for it.
                                  all it does is lead to trouble
                                  • H
                                    hrjmsh @sdetweil
                                    @sdetweil Thank you very much. Had the same error (cannot find module envsub) on updating the MagicMirror to the new version and this step (rm -rf node_modules and then npm install again) solved the issue for me.
                                    S T 2 Replies Last reply Reply Quote 0
                                      sdetweil @hrjmsh
                                      @hrjmsh you should use my upgrade script
                                      • H
                                        hrjmsh @sdetweil
                                        @sdetweil I did, both with and without changes applied. Unfortunately, it didn’t work for me. The only thing that worked was the solution you provided by removing the node_modules and then reinstalling npm.
                                          sdetweil @hrjmsh
                                          @hrjmsh can u send me the MagicMirror/installers/upgrade.log
                                          same userid at gmail
                                          never seen this problem
                                          • T
                                            Techneek @hrjmsh
                                            @hrjmsh Thank you so much!!! (rm -rf node_modules and then npm install again) worked like a charm!
                                            • 3 / 3
