    After update 2.23.0 crash
    56 Posts 9 Posters 32.8k Views 8 Watching
    • swvalentiS
      swvalenti Project Sponsor @sdetweil
      @sdetweil You are the man worked like a charm. Only thing I noticed when running on windows “alt” does not bring the toolbar up in order to quit MM. Did anything change?
        sdetweil @swvalenti
        @swvalenti alt-spacebar, or ctrl-m
        ctrl-q to quit, if not using pm2.
        pm2 will just restart it
        swvalentiS 1 Reply Last reply Reply Quote 0
        • swvalentiS
          @sdetweil ctrl m worked thanks Sam!
            JoeFranz
            Same here, error after Update :-(
            @sdetweil Update with your script
            (Use electron --trace-warnings ... to show where the warning was created)
            [05.04.2023 07:02.12.571] [ERROR] (node:4893) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 2)
            [4932:0405/070214.077646:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
            [4962:0405/070214.418104:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
              JoeFranz
              I ran “electron-rebuild”, now it works again :-)
                sdetweil @JoeFranz
                @JoeFranz on what module?
                J W 2 Replies Last reply Reply Quote 0
                  JoeFranz @sdetweil
                  @sdetweil MMM-PIR-Sensor
                  • W
                    Wenike @sdetweil
                    @sdetweil By chance, do you know of a command I can run to kill any running Node processes? I’m trying to run your upgrade script and its unable to upgrade Node because a process is already running. Googling gives me code to use within an application but that doesn’t seem like it’ll work from the CLI.
                    doing test run = false
                    Minimum Node version: v16.13.1
                    Installed Node version: v10.24.1
                    Node should be upgraded.
                    A Node process is currently running. Can't upgrade.
                    Please quit all Node processes and restart the update.
                    running process(s) are
                    pi 881 879 0 09:05 ? 00:00:00 node ./node_modules/.bin/electron js/electron.js
                    • mumblebajM
                      mumblebaj Module Developer @JerryP
                      @JerryP Always use Sam’s update script. I used it last night and updated from 2.21.0 to 2.23.0 no issues. Often modules with a package.json requires an npm install in that folder and the upgrade script takes care of all of that.
                        sdetweil @Wenike
                        @Wenike do this
                        from a terminal window
                        ps -ef | grep node
                        this will show you the node processes running and parms to what they are running (file path)
                        if all looks understandable and u can’t terminate them thru app shutdown (pm2 stop all will stop all.managed apps, mm included), do
                        ps -ef | grep node | awk '{ print $2 }' | xargs kill -9
                        this will hard kill all the node processes
                          sdetweil @JoeFranz
                          @JoeFranz
                          the script does a new npm install in modules that have a package.json
                          but I know the post install process is wrong for this module
                          my fork fixes that
                          https://github.com/sdetweil/MMM-PIR-Sensor
                          • W
                            Wenike @sdetweil
                            @sdetweil Perfect, fixed it. Thanks!
                              sdetweil @JerryP
                              @JerryP said in After update 2.23.0 crash:
                              sudo git pull
                              just one more thing
                              NEVER use sudo with MM no need for it.
                              all it does is lead to trouble
                              • H
                                hrjmsh @sdetweil
                                @sdetweil Thank you very much. Had the same error (cannot find module envsub) on updating the MagicMirror to the new version and this step (rm -rf node_modules and then npm install again) solved the issue for me.
                                S T 2 Replies Last reply Reply Quote 0
                                  sdetweil @hrjmsh
                                  @hrjmsh you should use my upgrade script
                                  • H
                                    hrjmsh @sdetweil
                                    @sdetweil I did, both with and without changes applied. Unfortunately, it didn’t work for me. The only thing that worked was the solution you provided by removing the node_modules and then reinstalling npm.
                                      sdetweil @hrjmsh
                                      @hrjmsh can u send me the MagicMirror/installers/upgrade.log
                                      same userid at gmail
                                      never seen this problem
                                      • T
                                        Techneek @hrjmsh
                                        @hrjmsh Thank you so much!!! (rm -rf node_modules and then npm install again) worked like a charm!
                                          DanClarkCBET3
                                          After installing the latest update (04/11/2023 10:00) I can not get Magic Mirror to start on my Windows systems. In this case I’m using the default CSS and config with no added modules. See attached photo. Please help.MM2_23.png
                                            sdetweil @DanClarkCBET3
                                            @DanClarkCBET3 yes, there is a reported issue on Windows
                                            https://github.com/MichMich/MagicMirror/issues/3083
                                            I was able to change some code (listed) to resolve it, but so far it only fails on windows. so we are not sure of the cause.
                                            no fix currently planned
                                            • 3 / 3
