    After update 2.23.0 crash
    56 Posts 9 Posters 34.2k Views 8 Watching
      JoeFranz
      I ran “electron-rebuild”, now it works again :-)
        sdetweil @JoeFranz
        @JoeFranz on what module?
        J W 2 Replies Last reply
          JoeFranz @sdetweil
          @sdetweil MMM-PIR-Sensor
          • W
            Wenike @sdetweil
            @sdetweil By chance, do you know of a command I can run to kill any running Node processes? I’m trying to run your upgrade script and its unable to upgrade Node because a process is already running. Googling gives me code to use within an application but that doesn’t seem like it’ll work from the CLI.
            doing test run = false
            Minimum Node version: v16.13.1
            Installed Node version: v10.24.1
            Node should be upgraded.
            A Node process is currently running. Can't upgrade.
            Please quit all Node processes and restart the update.
            running process(s) are
            pi 881 879 0 09:05 ? 00:00:00 node ./node_modules/.bin/electron js/electron.js
            • mumblebajM
              mumblebaj Module Developer @JerryP
              @JerryP Always use Sam’s update script. I used it last night and updated from 2.21.0 to 2.23.0 no issues. Often modules with a package.json requires an npm install in that folder and the upgrade script takes care of all of that.
                sdetweil @Wenike
                @Wenike do this
                from a terminal window
                ps -ef | grep node
                this will show you the node processes running and parms to what they are running (file path)
                if all looks understandable and u can’t terminate them thru app shutdown (pm2 stop all will stop all.managed apps, mm included), do
                ps -ef | grep node | awk '{ print $2 }' | xargs kill -9
                this will hard kill all the node processes
                W 1 Reply Last reply
                  sdetweil @JoeFranz
                  @JoeFranz
                  the script does a new npm install in modules that have a package.json
                  but I know the post install process is wrong for this module
                  my fork fixes that
                  https://github.com/sdetweil/MMM-PIR-Sensor
                  • W
                    Wenike @sdetweil
                    @sdetweil Perfect, fixed it. Thanks!
                      sdetweil @JerryP
                      @JerryP said in After update 2.23.0 crash:
                      sudo git pull
                      just one more thing
                      NEVER use sudo with MM no need for it.
                      all it does is lead to trouble
                      • H
                        hrjmsh @sdetweil
                        @sdetweil Thank you very much. Had the same error (cannot find module envsub) on updating the MagicMirror to the new version and this step (rm -rf node_modules and then npm install again) solved the issue for me.
                        S T 2 Replies Last reply
                          sdetweil @hrjmsh
                          @hrjmsh you should use my upgrade script
                          H 1 Reply Last reply
                          • H
                            hrjmsh @sdetweil
                            @sdetweil I did, both with and without changes applied. Unfortunately, it didn’t work for me. The only thing that worked was the solution you provided by removing the node_modules and then reinstalling npm.
                              sdetweil @hrjmsh
                              @hrjmsh can u send me the MagicMirror/installers/upgrade.log
                              same userid at gmail
                              never seen this problem
                              • T
                                Techneek @hrjmsh
                                @hrjmsh Thank you so much!!! (rm -rf node_modules and then npm install again) worked like a charm!
                                  DanClarkCBET3
                                  After installing the latest update (04/11/2023 10:00) I can not get Magic Mirror to start on my Windows systems. In this case I’m using the default CSS and config with no added modules. See attached photo. Please help.MM2_23.png
                                  S 2 Replies Last reply
                                    sdetweil @DanClarkCBET3
                                    @DanClarkCBET3 yes, there is a reported issue on Windows
                                    https://github.com/MichMich/MagicMirror/issues/3083
                                    I was able to change some code (listed) to resolve it, but so far it only fails on windows. so we are not sure of the cause.
                                    no fix currently planned
                                    D 1 Reply Last reply
                                      DanClarkCBET3 @sdetweil
                                      @sdetweil Thanks for the link. The suggested changes corrected my problem. Now the only problem I have is that the Alt key is not working but that is not a big problem.
                                        @DanClarkCBET3 ctrl-m will minimize
                                          @DanClarkCBET3 a fix has been pushed to the develop branch for the next release. the code is different
                                          to test the develop branch see
                                          https://forum.magicmirror.builders/topic/14327/testing-new-fixes-or-solving-current-problems-with-next-release-code
                                          • 3 / 3
