    After update 2.23.0 crash
    56 Posts 9 Posters 34.2k Views 8 Watching
      sdetweil @JerryP
      @JerryP said in After update 2.23.0 crash:
      sudo git pull
      just one more thing
      NEVER use sudo with MM no need for it.
      all it does is lead to trouble
      • H
        hrjmsh @sdetweil
        @sdetweil Thank you very much. Had the same error (cannot find module envsub) on updating the MagicMirror to the new version and this step (rm -rf node_modules and then npm install again) solved the issue for me.
        S T 2 Replies Last reply
          sdetweil @hrjmsh
          @hrjmsh you should use my upgrade script
          H 1 Reply Last reply
          • H
            hrjmsh @sdetweil
            @sdetweil I did, both with and without changes applied. Unfortunately, it didn’t work for me. The only thing that worked was the solution you provided by removing the node_modules and then reinstalling npm.
              sdetweil @hrjmsh
              @hrjmsh can u send me the MagicMirror/installers/upgrade.log
              same userid at gmail
              never seen this problem
              • T
                Techneek @hrjmsh
                @hrjmsh Thank you so much!!! (rm -rf node_modules and then npm install again) worked like a charm!
                  DanClarkCBET3
                  After installing the latest update (04/11/2023 10:00) I can not get Magic Mirror to start on my Windows systems. In this case I’m using the default CSS and config with no added modules. See attached photo. Please help.MM2_23.png
                  S 2 Replies Last reply
                    sdetweil @DanClarkCBET3
                    @DanClarkCBET3 yes, there is a reported issue on Windows
                    https://github.com/MichMich/MagicMirror/issues/3083
                    I was able to change some code (listed) to resolve it, but so far it only fails on windows. so we are not sure of the cause.
                    no fix currently planned
                    D 1 Reply Last reply
                      DanClarkCBET3 @sdetweil
                      @sdetweil Thanks for the link. The suggested changes corrected my problem. Now the only problem I have is that the Alt key is not working but that is not a big problem.
                        @DanClarkCBET3 ctrl-m will minimize
                          @DanClarkCBET3 a fix has been pushed to the develop branch for the next release. the code is different
                          to test the develop branch see
                          https://forum.magicmirror.builders/topic/14327/testing-new-fixes-or-solving-current-problems-with-next-release-code
                          • 3 / 3
