    After update 2.23.0 crash
    56 Posts 9 Posters 33.4k Views 8 Watching
    • W
      Wenike @sdetweil
      @sdetweil Perfect, fixed it. Thanks!
        sdetweil @JerryP
        @JerryP said in After update 2.23.0 crash:
        sudo git pull
        just one more thing
        NEVER use sudo with MM no need for it.
        all it does is lead to trouble
        • H
          hrjmsh @sdetweil
          @sdetweil Thank you very much. Had the same error (cannot find module envsub) on updating the MagicMirror to the new version and this step (rm -rf node_modules and then npm install again) solved the issue for me.
          S T 2 Replies Last reply
            sdetweil @hrjmsh
            @hrjmsh you should use my upgrade script
            H 1 Reply Last reply
            • H
              hrjmsh @sdetweil
              @sdetweil I did, both with and without changes applied. Unfortunately, it didn’t work for me. The only thing that worked was the solution you provided by removing the node_modules and then reinstalling npm.
                sdetweil @hrjmsh
                @hrjmsh can u send me the MagicMirror/installers/upgrade.log
                same userid at gmail
                never seen this problem
                • T
                  Techneek @hrjmsh
                  @hrjmsh Thank you so much!!! (rm -rf node_modules and then npm install again) worked like a charm!
                    DanClarkCBET3
                    After installing the latest update (04/11/2023 10:00) I can not get Magic Mirror to start on my Windows systems. In this case I’m using the default CSS and config with no added modules. See attached photo. Please help.MM2_23.png
                    S 2 Replies Last reply
                      sdetweil @DanClarkCBET3
                      @DanClarkCBET3 yes, there is a reported issue on Windows
                      https://github.com/MichMich/MagicMirror/issues/3083
                      I was able to change some code (listed) to resolve it, but so far it only fails on windows. so we are not sure of the cause.
                      no fix currently planned
                      D 1 Reply Last reply
                        DanClarkCBET3 @sdetweil
                        @sdetweil Thanks for the link. The suggested changes corrected my problem. Now the only problem I have is that the Alt key is not working but that is not a big problem.
                          @DanClarkCBET3 ctrl-m will minimize
                            @DanClarkCBET3 a fix has been pushed to the develop branch for the next release. the code is different
                            to test the develop branch see
                            https://forum.magicmirror.builders/topic/14327/testing-new-fixes-or-solving-current-problems-with-next-release-code
                            • 3 / 3
