    After update 2.23.0 crash
    56 Posts 9 Posters 31.9k Views 8 Watching
      sdetweil @JoeFranz
      @JoeFranz
      the script does a new npm install in modules that have a package.json
      but I know the post install process is wrong for this module
      my fork fixes that
      https://github.com/sdetweil/MMM-PIR-Sensor
      • W Offline
        Wenike @sdetweil
        @sdetweil Perfect, fixed it. Thanks!
          sdetweil @JerryP
          @JerryP said in After update 2.23.0 crash:
          sudo git pull
          just one more thing
          NEVER use sudo with MM no need for it.
          all it does is lead to trouble
          • H Offline
            hrjmsh @sdetweil
            @sdetweil Thank you very much. Had the same error (cannot find module envsub) on updating the MagicMirror to the new version and this step (rm -rf node_modules and then npm install again) solved the issue for me.
            S T 2 Replies Last reply Reply Quote 0
              sdetweil @hrjmsh
              @hrjmsh you should use my upgrade script
              • H Offline
                hrjmsh @sdetweil
                @sdetweil I did, both with and without changes applied. Unfortunately, it didn’t work for me. The only thing that worked was the solution you provided by removing the node_modules and then reinstalling npm.
                  sdetweil @hrjmsh
                  @hrjmsh can u send me the MagicMirror/installers/upgrade.log
                  same userid at gmail
                  never seen this problem
                  • T Offline
                    Techneek @hrjmsh
                    @hrjmsh Thank you so much!!! (rm -rf node_modules and then npm install again) worked like a charm!
                      DanClarkCBET3
                      After installing the latest update (04/11/2023 10:00) I can not get Magic Mirror to start on my Windows systems. In this case I’m using the default CSS and config with no added modules. See attached photo. Please help.MM2_23.png
                        sdetweil @DanClarkCBET3
                        @DanClarkCBET3 yes, there is a reported issue on Windows
                        https://github.com/MichMich/MagicMirror/issues/3083
                        I was able to change some code (listed) to resolve it, but so far it only fails on windows. so we are not sure of the cause.
                        no fix currently planned
                          DanClarkCBET3 @sdetweil
                          @sdetweil Thanks for the link. The suggested changes corrected my problem. Now the only problem I have is that the Alt key is not working but that is not a big problem.
                            @DanClarkCBET3 ctrl-m will minimize
                              @DanClarkCBET3 a fix has been pushed to the develop branch for the next release. the code is different
                              to test the develop branch see
                              https://forum.magicmirror.builders/topic/14327/testing-new-fixes-or-solving-current-problems-with-next-release-code
                              • 3 / 3
