    After update 2.23.0 crash
    56 Posts 9 Posters 34.2k Views 8 Watching
      sdetweil @JoeFranz
      @JoeFranz on what module?
      J W 2 Replies Last reply
        JoeFranz @sdetweil
        @sdetweil MMM-PIR-Sensor
        • W
          Wenike @sdetweil
          @sdetweil By chance, do you know of a command I can run to kill any running Node processes? I’m trying to run your upgrade script and its unable to upgrade Node because a process is already running. Googling gives me code to use within an application but that doesn’t seem like it’ll work from the CLI.
          doing test run = false
          Minimum Node version: v16.13.1
          Installed Node version: v10.24.1
          Node should be upgraded.
          A Node process is currently running. Can't upgrade.
          Please quit all Node processes and restart the update.
          running process(s) are
          pi 881 879 0 09:05 ? 00:00:00 node ./node_modules/.bin/electron js/electron.js
          • mumblebajM
            mumblebaj Module Developer @JerryP
            @JerryP Always use Sam’s update script. I used it last night and updated from 2.21.0 to 2.23.0 no issues. Often modules with a package.json requires an npm install in that folder and the upgrade script takes care of all of that.
              sdetweil @Wenike
              @Wenike do this
              from a terminal window
              ps -ef | grep node
              this will show you the node processes running and parms to what they are running (file path)
              if all looks understandable and u can’t terminate them thru app shutdown (pm2 stop all will stop all.managed apps, mm included), do
              ps -ef | grep node | awk '{ print $2 }' | xargs kill -9
              this will hard kill all the node processes
              W 1 Reply Last reply
                sdetweil @JoeFranz
                @JoeFranz
                the script does a new npm install in modules that have a package.json
                but I know the post install process is wrong for this module
                my fork fixes that
                https://github.com/sdetweil/MMM-PIR-Sensor
                • W
                  Wenike @sdetweil
                  @sdetweil Perfect, fixed it. Thanks!
                    sdetweil @JerryP
                    @JerryP said in After update 2.23.0 crash:
                    sudo git pull
                    just one more thing
                    NEVER use sudo with MM no need for it.
                    all it does is lead to trouble
                    • H
                      hrjmsh @sdetweil
                      @sdetweil Thank you very much. Had the same error (cannot find module envsub) on updating the MagicMirror to the new version and this step (rm -rf node_modules and then npm install again) solved the issue for me.
                      S T 2 Replies Last reply
                        sdetweil @hrjmsh
                        @hrjmsh you should use my upgrade script
                        H 1 Reply Last reply
                        • H
                          hrjmsh @sdetweil
                          @sdetweil I did, both with and without changes applied. Unfortunately, it didn’t work for me. The only thing that worked was the solution you provided by removing the node_modules and then reinstalling npm.
                            sdetweil @hrjmsh
                            @hrjmsh can u send me the MagicMirror/installers/upgrade.log
                            same userid at gmail
                            never seen this problem
                            • T
                              Techneek @hrjmsh
                              @hrjmsh Thank you so much!!! (rm -rf node_modules and then npm install again) worked like a charm!
                                DanClarkCBET3
                                After installing the latest update (04/11/2023 10:00) I can not get Magic Mirror to start on my Windows systems. In this case I’m using the default CSS and config with no added modules. See attached photo. Please help.MM2_23.png
                                S 2 Replies Last reply
                                  sdetweil @DanClarkCBET3
                                  @DanClarkCBET3 yes, there is a reported issue on Windows
                                  https://github.com/MichMich/MagicMirror/issues/3083
                                  I was able to change some code (listed) to resolve it, but so far it only fails on windows. so we are not sure of the cause.
                                  no fix currently planned
                                  D 1 Reply Last reply
                                    DanClarkCBET3 @sdetweil
                                    @sdetweil Thanks for the link. The suggested changes corrected my problem. Now the only problem I have is that the Alt key is not working but that is not a big problem.
                                      @DanClarkCBET3 ctrl-m will minimize
                                        @DanClarkCBET3 a fix has been pushed to the develop branch for the next release. the code is different
                                        to test the develop branch see
                                        https://forum.magicmirror.builders/topic/14327/testing-new-fixes-or-solving-current-problems-with-next-release-code
                                        • 3 / 3
