    MMM-DWD-Pollen
    Scheduled Pinned Locked Moved Health
    healthweather
    32 Posts 10 Posters 20.2k Views 10 Watching
      CarstenD @duxnobis
      @duxnobis In general yes, I think Switzerland gets data from Meteo Schweiz (https://opendata.swiss/de/dataset/messstationen-des-nationalen-pollenmessnetzes)
        CarstenD @TechJak7000
        @TechJak7000 said in MMM-DWD-Pollen:
        Astma-Allergi Denmark
        I found some information here: https://github.com/rugaard/pollen
        Thus it looks like Astma-Allergi Denmark does not offer any official API. Thus you have to use this API here (which I guess takes the data from the website) and renders the data accordingly. There are only two regions as far as I can see (East and West?) and 25 pollen. If the API works it should no big problem.
        TechJak7000T 1 Reply Last reply
        • TechJak7000T
          TechJak7000 @CarstenD
          @CarstenD Thank you very much for your attention and effort. I have contacted the owner of the post to have more in depth information how to go about and use this API.
          As far as my limited knowledge for implementing this, one has to install / use 2 different programs systems to utilize it, and I have sent the guy a message with and example of the “MMM-pollen” to give him and idea of what I am looking for and how can I implement this, I hope I get a useful response.
            CarstenD
            Added the option to select which Pollen to display through config.
            M 1 Reply Last reply
              MajorC Project Sponsor @CarstenD
              I have the DWD-Pollen on the right side of my scree. Unfortunately, there is a gap as you can see in the picture.
              I checked the CSS, but it is a table and I can’t see a good way to get rid of the space on the right.
              Any idea is appreciated.
                Update:
                I now use:
                .MMM-DWD-Pollen table {
                	margin-left: auto;
                	margin-right: -40px;
                Not sure if this is a good way, but it works for me at the moment.
                C 1 Reply Last reply
                  CarstenD @MajorC
                  @majorc Thanks. Somehow this does not really work on mine. Now the text is stretching into the right border.
                  But good that it works for you.
                    @carstend that is strange. This is the only css I use for DWD-Pollen. Do you have something else in your custom css?
                    • K
                      Klinge
                      maybe someone of you could help me, because in my new opened topic I got no answers unfortunately.
                      I try to start the module MMM-DWD-Pollen. But the data will not be loaded. I am living in the region “Östl. Niedersachsen”. On the Github site this region is declared with the number “32”. And on the DWD Site it is declared with the number “5”. But both numbers are not working. And now I don´t know which number I can use for my region.
                      It would be great if someone could help me.
                      Thank you in advance.
                      S F 2 Replies Last reply
                        sdetweil @Klinge
                        @Klinge if someone knows and is willing to help they will.
                        this forum is all volunteer community
                        K 1 Reply Last reply
                        • K
                          Klinge @sdetweil
                          @sdetweil said in MMM-DWD-Pollen:
                          Yes, I know, and that’s absolutely fine, of course. It was just another attempt here.
                          • F
                            fatgrandma @Klinge
                            @Klinge
                            The Number on github is the correct one as statet on the github site
                            “There is a map that sows all part regions (but you have to match it to the numbers shown above)”
                            Dumb take but did you try to just wait one day? DWD pushes the numbers out once a day, if there are no new ones it shows nothing on the module.
                            • K
                              Klinge @fatgrandma
                              @fatgrandma Thank you for your answer.
                              When I take the wrong number from the DWD site I got the message “No values today. No values tomorrow”. But you are right. In this case I have to wait a day more. I guess DWD published his new values at 11 a.m. every day, doesn´t it?
                              But when I take the correct number from the github site(!), I get only the message “Loading”. And this has been the case for several days.
                                CarstenD
                                Apparently DWD had changed its numbering. I updated the Readme.
                                Those are the new regions:
                                10=Schleswig-Holstein und Hamburg
                                11=Inseln und Marschen
                                12=Geest,Schleswig-Holstein und Hamburg
                                20=Mecklenburg-Vorpommern
                                30=Niedersachsen und Bremen
                                31=Westl. Niedersachsen/Bremen
                                32=Östl. Niedersachsen
                                40=Nordrhein-Westfalen
                                41=Rhein.-Westfäl. Tiefland
                                42=Ostwestfalen
                                43=Mittelgebirge NRW
                                50=Brandenburg und Berlin
                                60=Sachsen-Anhalt
                                61=Tiefland Sachsen-Anhalt
                                62=Harz
                                70=Thüringen
                                71=Tiefland Thüringen
                                72=Mittelgebirge Thüringen
                                80=Sachsen
                                81=Tiefland Sachsen
                                82=Mittelgebirge Sachsen
                                90=Hessen
                                91=Nordhessen und hess. Mittelgebirge
                                92=Rhein-Main
                                100=Rheinland-Pfalz und Saarland
                                101=Rhein, Pfalz, Nahe und Mosel
                                102=Mittelgebirgsbereich Rheinland-Pfalz
                                103=Saarland
                                110=Baden-Württemberg
                                111=Oberrhein und unteres Neckartal
                                112=Hohenlohe/mittlerer Neckar/Oberschwaben
                                113=Mittelgebirge Baden-Württemberg
                                120=Bayern
                                121=Allgäu/Oberbayern/Bay. Wald
                                122=Donauniederungen
                                123=Bayern nördl. der Donau, o. Bayr. Wald, o. Mainfranken
                                124=Mainfranken
                                  CarstenD @CarstenD
                                  I checked your region (32) and there is indeed no data from DWD. The only region is 31 with data.
                                  • K
                                    Klinge @Sachse
                                    @Sachse Please excuse me for replying to such an old post. But unfortunately I have the same problem as you had. The module only worked fine for a few days, and now it won’t load the data any more. I have now tried to reproduce your solution. But I unfortunately did not solve it. When I enter “pm2 status” and “netstat -plan|grep 8080”, I get the following output.
                                    pi@raspberrypi:~/MagicMirror/modules $ pm2 status
                                    │ id │ name           │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
                                    │ 0  │ MagicMirror    │ default     │ 2.26.0  │ fork    │ 749      │ 5h     │ 0    │ online    │ 0%       │ 2.6mb    │ pi       │ enabled  │
                                    pi@raspberrypi:~/MagicMirror/modules $ netstat -plan|grep 8080
                                    (Es konnten nicht alle Prozesse identifiziert werden; Informationen über
                                    nicht-eigene Processe werden nicht angezeigt; Root kann sie anzeigen.)
                                    tcp6       0      0 ::1:8080                :::*                    LISTEN      838/electron.js
                                    tcp6       0      0 ::1:8080                ::1:46942               TIME_WAIT   -
                                    tcp6       0      0 ::1:8080                ::1:46944               FIN_WAIT2   -
                                    tcp6       0      0 ::1:8080                ::1:44370               VERBUNDEN   838/electron.js
                                    tcp6       0      0 ::1:44370               ::1:8080                VERBUNDEN   941/Electron --shar
                                    tcp6       1      0 ::1:46944               ::1:8080                CLOSE_WAIT  941/Electron --shar
                                    It would be really nice if you could please give me the crucial hint where the problem is now and how it can be solved? :-)
                                    bheplerB 1 Reply Last reply
                                    • bheplerB
                                      bhepler Module Developer @Klinge
                                      @Klinge - It appears that your problem isn’t the same. @Sachse had two instances of the Magic Mirror framework running at the same time. You probably don’t have that problem.
                                      The DWD site appears to be up and is hosting a json file. So let’s start at the beginning. Please post the relevant portion of your config.js file. We don’t need everything, just the part that configures the MMM-DWD-Pollen module. That will let us try and replicate your problem. Be sure to use the Markdown features when you post your code snippet!
