    MMM-PGA
    48 Posts 7 Posters 57.4k Views 7 Watching
    • swvalentiS Offline
      swvalenti Project Sponsor @swvalenti
      I forked and made changes so module is now working again. @mumblebaj thanks for the help.
      https://github.com/swvalenti194/MMM-PGA
      • mumblebajM Offline
        mumblebaj Module Developer @swvalenti
        @swvalenti Awesome. Glad it is working.
        swvalentiS 1 Reply Last reply Reply Quote 0
          swvalenti Project Sponsor @mumblebaj
          @mumblebaj module is stuck on loading but no errors in dev console?
            @swvalenti Are you using the original module? Is this happening after upgrade to MM2.19? Did you do the normal git pull && npm install in the module folder? Is there any errors in the pm2 logs if you are using pm2 or in the console if you are using npm start?
              @mumblebaj I am using your fork and it worked fine for 2.19 for couple weeks just stopped the other day.
              mumblebajM 2 Replies Last reply Reply Quote 0
                @swvalenti I will have a look in the morning. It is almost midnight where I am. :-(
                  @swvalenti Seems like there was a major upgrade in the JSON return data. Loads of changes. Not going to be an easy task to work through them all. I do not have easy fixes for it. I will see if I have time to work through them.
                    @mumblebaj any easy way for me to figure this out, if I comment out that line it works.
                    [18.04.2023 11:31.09.632] [LOG]   MMM-PGA retrieving Tournament Data
                    [18.04.2023 11:31.09.633] [ERROR] Whoops! There was an uncaught exception...
                    [18.04.2023 11:31.09.633] [ERROR] TypeError: Cannot read properties of undefined (reading 'displayName')
                        at Request._callback (C:\Users\CCU Forensic Machine\MagicMirror\modules\MMM-PGA\ESPN.js:49:99)
                        at self.callback (C:\Users\CCU Forensic Machine\MagicMirror\modules\MMM-PGA\node_modules\request\request.js:185:22)
                        at Request.emit (node:events:513:28)
                    [18.04.2023 11:38.48.117] [LOG]   MMM-PGA retrieving FedEx Cup Standings
                    [18.04.2023 11:38.48.185] [ERROR] Whoops! There was an uncaught exception...
                    [18.04.2023 11:38.48.185] [ERROR] TypeError: Cannot read properties of undefined (reading 'querySelectorAll')
                        at Request._callback (C:\Users\CCU Forensic Machine\MagicMirror\modules\MMM-PGA\FEDEXCUP.js:33:38)
                      @swvalenti Can you show me what you changed? Did you comment out displayName in ESPN.js or the line with querySelectorAll in FEDEXCUP.js?
                        @mumblebaj just the espn.js sir
                          @swvalenti Does you line 49 look like the following? tournament.defendingChamp = event.defendingChampion ? event.defendingChampion.displayName :
                            @mumblebaj said in MMM-PGA:
                            tournament.defendingChamp = event.defendingChampion ? event.defendingChampion.athlete.displayName : ""
                              @swvalenti Thanks for the above. Seem the data has changed. Change it to the following:
                              tournament.defendingChamp = event.defendingChampion ? event.defendingChampion.displayName : ""
                              I will make a change and deploy but there is more data that changed. Need to check the others as well.
                                tournament.defendingChamp = event.defendingChampion ? event.defendingChampion.displayName : “”
                                changed it but still stuck on loading
                                  @swvalenti Yeah, seems like it is a team tournament hence there is no individual athlete information. Busy looking at it.
                                    @mumblebaj No worries bro appreciate the time let me know if I can be of help
                                      @swvalenti OWGR is broken as well. Website changed and the code in there is completely out dated. So much issues I am not sure if I can fix them. It needs a complete re-write.
                                        @mumblebaj oh man that sucks its my favorite module…I can pay ya…ha
                                          @mumblebaj randomly started working again but def missing some stuff
                                            dathbe
                                            Just FYI, I’ve taken over primary maintenance of this module. It is now available at https://github.com/dathbe/MMM-PGA, with a handful of bug fixes.
                                            • 2 / 3
