    MMM-PGA
    48 Posts 7 Posters 57.4k Views 7 Watching
      sdetweil @swvalenti
      @swvalenti as I said, u can use some tools in the coding to get the json data structure printed out so you can examine it
      or, use the url in a browser to collect the info.
      once u have that you can attempt to find the info the module needed
      and maybe change the code to match
      I use this site for validating json documents
      https://codebeautify.org/jsonvalidator?/jsonvalidate
      but it also allows you to format the data in a more readable fashion
      the code is trying to extract the player from the data returned
      Cannot read property ‘athlete’ of undefined
      0|MagicMirror | at Request._callback (/home/pi/MagicMirror/modules/MMM-PGA/ESPN.js:49:65)
      the code is the ESPN.js line 45, column 65
      u also may get noting back from the api at all…
      swvalentiS 1 Reply Last reply Reply Quote 0
      • swvalentiS Offline
        swvalenti Project Sponsor @sdetweil
        @sdetweil Ok but which url do I use to check the json?
        swvalentiS S 2 Replies Last reply Reply Quote 0
          swvalenti Project Sponsor @swvalenti
          I just commented that line out and now it works! HA
            sdetweil @swvalenti
            @swvalenti the url used by the code to get the data from the api…
            I don’t know the module at all, just trying to give some help.
            Someone (You) will have to become the programmer.
            learn how the module works in enough detail to :
              1. find where the error occurs (this is given to you)
              1. develop some mechanism to capture the data that results in the failure
              1. analyze the data to determine the cause
              1. develop a strategy for fixing the ‘problem’
              1. apply the strategy to the existing code
              repeat 1-5 til you have resolved the problem(s) successfully, or abandon the task
            S mumblebajM 2 Replies Last reply Reply Quote 0
              @swvalenti you could also open an issue on the module github page and hope the author might look at it… has updates from about 9 months ago…
              • mumblebajM Offline
                @sdetweil It is a screen scraper. I see he says he commented some line and it is working again for him.
                  sdetweil @mumblebaj
                  @mumblebaj cool. but doesn’t change the work
                    @sdetweil I tried pulling an issue ticket on github to no avail. @mumblebaj what is a screen scraper and can you assist in fixing?
                      sdetweil @swvalenti
                      @swvalenti remember this is volunteer work… we have other things in our lives…
                      many developers do this in the winter when they are stuck in the house. and when they can go outside, they do…
                        @sdetweil said in MMM-PGA:
                        completely understand sir
                          mumblebaj Module Developer @swvalenti
                          @swvalenti The issue is in the ESPN.js at line 49 or so. It is looking for defendingChampion.athlete but there isn’t one and it fails. I see you have created an issue on GitHub but sometimes the guys abandon their modules. Maybe the developer responds to you issue. You could change line 49 to the below and it should work.
                          I would have done it this way:
                          tournament.defendingChamp = event.defendingChampion ? event.defendingChampion.athlete.displayName : ""
                          swvalentiS 1 Reply Last reply Reply Quote 1
                            swvalenti Project Sponsor @mumblebaj
                            @mumblebaj said in MMM-PGA:
                            tournament.defendingChamp = event.defendingChampion ? event.defendingChampion.athlete.displayName : “”
                            @mumblebaj you are the man that worked thank you! I am going to do a PR and change
                              I forked and made changes so module is now working again. @mumblebaj thanks for the help.
                              https://github.com/swvalenti194/MMM-PGA
                                @swvalenti Awesome. Glad it is working.
                                  @mumblebaj module is stuck on loading but no errors in dev console?
                                    @swvalenti Are you using the original module? Is this happening after upgrade to MM2.19? Did you do the normal git pull && npm install in the module folder? Is there any errors in the pm2 logs if you are using pm2 or in the console if you are using npm start?
                                      @mumblebaj I am using your fork and it worked fine for 2.19 for couple weeks just stopped the other day.
                                        @swvalenti I will have a look in the morning. It is almost midnight where I am. :-(
                                          @swvalenti Seems like there was a major upgrade in the JSON return data. Loads of changes. Not going to be an easy task to work through them all. I do not have easy fixes for it. I will see if I have time to work through them.
                                            @mumblebaj any easy way for me to figure this out, if I comment out that line it works.
                                            [18.04.2023 11:31.09.632] [LOG]   MMM-PGA retrieving Tournament Data
                                            [18.04.2023 11:31.09.633] [ERROR] Whoops! There was an uncaught exception...
                                            [18.04.2023 11:31.09.633] [ERROR] TypeError: Cannot read properties of undefined (reading 'displayName')
                                                at Request._callback (C:\Users\CCU Forensic Machine\MagicMirror\modules\MMM-PGA\ESPN.js:49:99)
                                                at self.callback (C:\Users\CCU Forensic Machine\MagicMirror\modules\MMM-PGA\node_modules\request\request.js:185:22)
                                                at Request.emit (node:events:513:28)
                                            [18.04.2023 11:38.48.117] [LOG]   MMM-PGA retrieving FedEx Cup Standings
                                            [18.04.2023 11:38.48.185] [ERROR] Whoops! There was an uncaught exception...
                                            [18.04.2023 11:38.48.185] [ERROR] TypeError: Cannot read properties of undefined (reading 'querySelectorAll')
                                                at Request._callback (C:\Users\CCU Forensic Machine\MagicMirror\modules\MMM-PGA\FEDEXCUP.js:33:38)
                                            • 2 / 3
