    Magicmirror touchscreen tablet dashboard
    18 Posts 8 Posters 10.8k Views 13 Watching
      Axel51 @CobraRL_
      @CobraRL_ hi, i love your timer. Can you show/send me what you’ve changed on the MMM-KitchenTimer module?
      tx
        CobraRL_ @easily
        @easily It was kind of simple. I hid the page indicator’s “::before” and created an “::after” with the content of the page title. Here’s all the code I used for the page indicator:
        .MMM-page-indicator div div {
          display: flex;
          margin: 0px var(--header-horizontal-margin);
          justify-content: space-between;
        .MMM-page-indicator div i::before {
          display: none;
        .MMM-page-indicator .fa-circle::after {
          font-weight: 400 !important;
        .MMM-page-indicator div i::after {
          font-family: var(--font-primary);
          font-size: var(--header-font-size);
          font-weight: 300;
        .MMM-page-indicator div i:nth-child(1)::after {
          content: "Home";
        .MMM-page-indicator div i:nth-child(2)::after {
          content: "Schedule";
        .MMM-page-indicator div i:nth-child(3)::after {
          content: "Tasks";
        .MMM-page-indicator div i:nth-child(4)::after {
          content: "Room";
        .MMM-page-indicator div i:nth-child(5)::after {
          content: "Music";
        .MMM-page-indicator div i:nth-child(6)::after {
          content: "Timer";
        .MMM-page-indicator div i:nth-child(7)::after {
          content: "HomeAssistant";
          CobraRL_ @Axel51
          @Axel51 I did a bunch of small changes to the JS like adding extra class names, adding extra wrappers, and removing the sounds because I found them annoying. The extra class names and wrappers helped me with the css. Hopefully the css variables are self-explanatory that it still makes sense.
          Let me know if you need me to clarify anything!
          Here’s the .css code
          .MMM-KitchenTimer div {
            display: grid;
          .MMM-KitchenTimer .text {
            font-weight: 300;
            font-size: 12rem;
            color: var(--secondary-background-color);
            text-align: center;
            line-height: 1;
          .MMM-KitchenTimer .paused {
            color: rgba(255, 255, 255, 0.6);
          .MMM-KitchenTimer .button {
            font-size: 20px;
            font-weight: 300;
            display: flex;
            align-items: center;
            justify-content: center;
            min-width: 6rem;
            aspect-ratio: 1;
            border-radius: 100px;
            background-color: var(--primary-background-color);
            color: var(--primary-foreground-color);
            backdrop-filter: blur(var(--blur));
            -webkit-backdrop-filter: blur(var(--blur));
          .MMM-KitchenTimer .list-container {
            display: flex !important;
            gap: 1rem;
          Here’s the .js code
          /* global Log, Module, moment, config */
          /* Magic Mirror
           * Module: Kitchen timers
           * By Tom Short
           * MIT Licensed.
          Module.register("MMM-KitchenTimer",{
              // Module config defaults.
              defaults: {
                  timertext: ["1m", "5m", "20m"],
                  timersecs: [60, 300, 1200],
              // Define required scripts.
              getScripts: function() {
                  return [];
              // Define styles.
              getStyles: function() {
                  return ["MMM-KitchenTimer.css"];
              // Define start sequence.
              start: function() {
                  // Schedule update.
                  setTimeout(function() {
                      self.getDom();
                  }, 1000);
              // Override dom generator.
              getDom: function() {
                  var time = 0, startTime, interval, alarm;
                  function start() {
                      if (!interval) {
                          startTime = Date.now();
                          interval = setInterval(update, 1000);
                      display();
                  function pause() {
                      if (interval) {
          		        timerText.className = "text paused";
                          sound.pause();
                          clearInterval(interval);
                          interval = null;
                  function update() {
                      time -= delta();
                      display();
                  function addSeconds(value) {
                      time += value;
                  function delta() {
                      var now = Date.now(),
                          d = now - startTime;
                      startTime = now;
                      return d / 1000;
                  function stop() {
                      pause();
                      time = 0;
                      display();
                  function pad(val) {
                      var str = "00";
                      return str.substring(0, str.length - String(val).length) + val;
                  function display() {
                      var secs = Math.round(Math.abs(time % 60));
                      var mins = Math.abs(Math.trunc(time / 60) % 60);
                      var hours = Math.abs(Math.trunc(time / 3600));
                      var sign = Math.sign(time);
                      if (time > 0) {
                          timerText.className = "text positive";
                      } else if (time < 0) {
          		        timerText.className = "text negative";
                      } else {
          		        timerText.className = "text";
                      timerText.innerHTML =
                          (time < 0 ? "-" : "") +
                          (hours > 0 ? hours+":" : "") +
                          pad(mins,2) + ":" + pad(secs,2);
                  var timerText = document.createElement("span");
                  wrapper.appendChild(timerText);
                  var wrapper2 = document.createElement("section");
                  wrapper2.className = "list-container";
                  // Create buttons
                  for (var i=0; i<this.config.timertext.length; i++) {
                      var el =  document.createElement("div");
                      el.className = "button";
                      el.innerHTML = this.config.timertext[i];
                      el.counter = i;
                      var self = this;
                      el.addEventListener("click", function(event) {
                          addSeconds(self.config.timersecs[this.counter]);
                          start();
                      wrapper2.appendChild(el);
                  const sound = document.createElement('audio');
                  sound.src = this.file("alarm.wav");
                  sound.setAttribute('autoplay', true);
                  sound.setAttribute('loop', true);
                  sound.pause();
                  const beep = document.createElement('audio');
                  beep.src = this.file("beep.wav");
                  beep.volume = 0.2;
                  beep.pause();
                  display();
                  timerText.addEventListener("click", function(event) {
                      if (interval) {
                          pause();
                      } else if (time != 0) {
                          start();
                  var stopButton = document.createElement("div");
                  stopButton.className = "button stop";
                  stopButton.innerHTML = "X";
                  stopButton.addEventListener("click", stop);
                  wrapper2.appendChild(stopButton);
                  wrapper.appendChild(wrapper2);
                  return wrapper;
          • W Offline
            wfsaxton
            Nice job on this. I was also thinking of going the tablet route with MM. I never thought of the server approach, which seems to make it a lot easier. Although I’m guessing streaming video wouldn’t work out so well (if I wanted to implement that).
            Question: How did you set up the client on the tablet? Is it just a full-screen web browser?
              CobraRL_ @wfsaxton
              @wfsaxton Yeah its just a fullscreen browser. I’ve tried doing google cast and a smart assistant on it but neither of them worked for me.
              • F Offline
                frentemorao
                Your project is quite interesting.
                I also have a pizero running MM on server mode and a tablet as a dashboard.
                I would like to know how you manage to move between the different screens as it is a fullscreen browser.
                Thanks in advance
                  sdetweil @frentemorao
                  @frentemorao he uses the MMM-Pages module which creates logical pages by showing and hiding modules in groups.
                  • F Offline
                    frentemorao
                    @sdetweil thanks for the explanation but I am afraid it’s not the answer I was waiting for…
                    I understood he touches the screen to move between pages. Am I right?
                      @frentemorao I doubt it, pages will cycle thru, mmm-carousel can too.
                      I haven’t seen a module that does touch screen swipe. I have seen swipe with additional sensors
                      here’s a talk about mouse gestures in browsers
                      https://gizmodo.com/how-to-use-mouse-gestures-in-chrome-edge-safari-opera-f-1848790869
                      • wishmaster270W Offline
                        wishmaster270 Module Developer @sdetweil
                        you can use MMM-Touch to react to swipes. I am not sure if it works with pages but it does with the MMM-ProfileControl.
                        S F 2 Replies Last reply Reply Quote 0
                          sdetweil @wishmaster270
                          @wishmaster270 very cool…
                          • F Offline
                            frentemorao @wishmaster270
                            @wishmaster270 do you think this solution will work in a tablet considering the server is in an external rpi?
                              wishmaster270 Module Developer @frentemorao
                              @frentemorao Did not test that. I have it running on the same Pi in my case. But as MMM-Touch only sends notifications to other modules I do not see a reason why it shouldn’t.
                              • F Offline
                                @wishmaster270 I can confirm you that it does work in an Android tablet !!!
                                Now I have to figure out how it interacts with Pages (and MMM-Remote-Control)
