    MMM-CalendarExt3
    689 Posts 82 Posters 3.3m Views 86 Watching
      MMRIZE @zelmo
      @zelmo
      It is intentionally designed so. Not enough width to display endTime together. Use MMM-CalendarExt3Agenda together to see details.
        MMRIZE @zelmo
        1.3.1 (2023-05-02)
        • CHANGED: Refactoring some codes, the structure of the events, CSS.
        • ADDED: displayEndTime: true => Show end time of the event. (hidden by default) (Requested from @zelmo)
        • ADDED: displayWeatherTemp: true => Show max/min temperature of the forecasted days.
          CX3_1 3 1
          MMRIZE @zelmo
          @zelmo updated for you.
          Z 1 Reply Last reply
          • Z
            zelmo @MMRIZE
            @MMRIZE Thanks a lot! Was about to suggest it just in case someone would run it horizontal. Then it might be useful and enough space. I’ll test out at least. Thanks again.
              Studio472
              I added an mlb team calendar. The little baseball symbol shows up on my google calendar on the web browser. In this module, the icon isn’t coming through. Is there a module or font-pack I need to install on my raspbizzle?
              M 1 Reply Last reply
                MMRIZE @Studio472
                @Studio472
                Maybe emoji font should be installed to use/display emojis.
                https://raspberrypi.stackexchange.com/questions/104181/colored-emojis-in-chromium
                • W
                  whimsicality
                  Hi, thanks for the work on this module. I am struggling to get it to load. I finally ran the npm dev through terminal and it is coming up with a number of errors… “failed to retrieve device information”, “failed to open kms_swrast”, “failed to open swrast”, “gpu process exited unexpectedly” exit_code=11", “failed to send GpuControl.createcommandbuffer” and then it looks like electron exited with signal “SIGINT”.
                  Is this something I need to troubleshoot with the module itself or does this mean I need to fix something elsewhere? thanks!
                    sdetweil @whimsicality
                    @whimsicality
                    for the mesa errors this is an electron/graphics engine problem. but you can turn off gpu use.
                    in the script that starts mm, ~/MagicMirror/installers/mm.sh if you used my install script, add
                    export ELECTRON_DISABLE_GPU=1
                    above the line that does npm start
                    • K
                      kasperinline @fedale
                      @fedale
                      I’m not able to get rid of the text “CW”. Can you help me, by sharing your lines.
                      Regards
                      K 1 Reply Last reply
                      • K
                        kasperinline @kasperinline
                        @kasperinline said in MMM-CalendarExt3:
                        @fedale
                        Regards
                        Got i’t by myself, and learned a little more :-)
                        .CX3 .cw::before {
                        content: "CW ";
                        display: none;
                          MMRIZE @kasperinline
                          @kasperinline
                          Do that in your ‘custom.css’ not in the ‘MMM-CalendarExt3.css’
                          • K
                            kasperinline @MMRIZE
                            @MMRIZE said in MMM-CalendarExt3:
                            @kasperinline
                            Yes of course :-)
                            Always in the ‘custom.css’
                              Studio472
                              I have an MLB calendar displaying my favorite team. West coast evening games span 2 days in my calendar (which looks goofy).
                              Is there a way to transform an event to only run 1 hour so it displays in a single day?
                              M 2 Replies Last reply
                                MMRIZE @Studio472
                                @Studio472
                                I think it could be possible with preProcessor, but I’m not in front of my computer, so cannot show example at this moment.
                                  MMRIZE @Studio472
                                  @Studio472
                                  Config:
                                  eventTransformer: (event) => {
                                    if (event.calendarName === 'MLB') { // I assume you assigned 'MLB' as a calendar name.
                                      event.endDate = event.startDate + 1000 // I think 1000ms is safer than 1 hour
                                    return event
                                  Before:
                                  After:
                                  • F
                                    Fjerdrumsmoen
                                    Hi
                                    Need some help here.
                                    Trying to get this module to work, but only the “header” of the month is showing. No events is listing, and no dates are showing. In the GoogleCalender module I can see the events, so I know that the GoogleCalender is working.
                                    Do someone know what is wrong? My config file is like this:
                                    			module: 'MMM-GoogleCalendar',
                                    			header: "Familie Kalender",
                                    						color: "red",
                                    						broadcastPastEvents: true, // <= IMPORTANT to see past events
                                    						calendarID: "GOOGLE ID_ deleted from the code"
                                    						// add another calendar HERE if needed
                                    			 module: "MMM-CalendarExt3",
                                    			 position: "bottom_center",
                                    			 title: "Familie kalenderen",
                                    				mode: "month",
                                    				instanceId: "basicCalendar",
                                    				locale: 'de-DE',
                                    				maxEventLines: 5,
                                    				firstDayOfWeek: 1,
                                    				calendarSet: ['FK']
                                    S M 3 Replies Last reply
                                      sdetweil @Fjerdrumsmoen
                                      @Fjerdrumsmoen calendarExt3 gets its data from the default calendar module…
                                      so you have to configure it, and just comment out the position: setting…
                                        @Fjerdrumsmoen said in MMM-CalendarExt3:
                                        module: ‘MMM-GoogleCalendar’,
                                        no, use
                                        module: "calendar"
                                        • F
                                          Fjerdrumsmoen
                                          Hmm. All empty when I use the calendar module, also. Tested with the US holidays, and everything stays blank. (Without the heading)
                                          Any other tips?
                                            @Fjerdrumsmoen 1st
                                            w default cal module, does the calendar display?
                                            (before u comment out position)
                                            did u try the default ext3 config?
                                            I used the default ext3 config from doc, with the holidays
                                            commented out calendarSet, and locale…
                                              position: "bottom_bar",
                                              title: "",
                                                mode: "month",
                                               // locale: 'de-DE',
                                                maxEventLines: 5,
                                                firstDayOfWeek: 1,
                                                //calendarSet: ['us_holiday', 'abfall', 'mytest'],
                                            got
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 34
                                            • 35
                                            • 13 / 35
