    MMM-CalendarExt3
    689 Posts 82 Posters 3.1m Views 86 Watching
      MMRIZE @Studio472
      @Studio472
      Maybe emoji font should be installed to use/display emojis.
      https://raspberrypi.stackexchange.com/questions/104181/colored-emojis-in-chromium
      • W Offline
        whimsicality
        Hi, thanks for the work on this module. I am struggling to get it to load. I finally ran the npm dev through terminal and it is coming up with a number of errors… “failed to retrieve device information”, “failed to open kms_swrast”, “failed to open swrast”, “gpu process exited unexpectedly” exit_code=11", “failed to send GpuControl.createcommandbuffer” and then it looks like electron exited with signal “SIGINT”.
        Is this something I need to troubleshoot with the module itself or does this mean I need to fix something elsewhere? thanks!
          sdetweil @whimsicality
          @whimsicality
          for the mesa errors this is an electron/graphics engine problem. but you can turn off gpu use.
          in the script that starts mm, ~/MagicMirror/installers/mm.sh if you used my install script, add
          export ELECTRON_DISABLE_GPU=1
          above the line that does npm start
          • K Offline
            kasperinline @fedale
            @fedale
            I’m not able to get rid of the text “CW”. Can you help me, by sharing your lines.
            Regards
            • K Offline
              kasperinline @kasperinline
              @kasperinline said in MMM-CalendarExt3:
              @fedale
              Regards
              Got i’t by myself, and learned a little more :-)
              .CX3 .cw::before {
              content: "CW ";
              display: none;
                MMRIZE @kasperinline
                @kasperinline
                Do that in your ‘custom.css’ not in the ‘MMM-CalendarExt3.css’
                • K Offline
                  kasperinline @MMRIZE
                  @MMRIZE said in MMM-CalendarExt3:
                  @kasperinline
                  Yes of course :-)
                  Always in the ‘custom.css’
                    Studio472
                    I have an MLB calendar displaying my favorite team. West coast evening games span 2 days in my calendar (which looks goofy).
                    Is there a way to transform an event to only run 1 hour so it displays in a single day?
                      MMRIZE @Studio472
                      @Studio472
                      I think it could be possible with preProcessor, but I’m not in front of my computer, so cannot show example at this moment.
                        MMRIZE @Studio472
                        @Studio472
                        Config:
                        eventTransformer: (event) => {
                          if (event.calendarName === 'MLB') { // I assume you assigned 'MLB' as a calendar name.
                            event.endDate = event.startDate + 1000 // I think 1000ms is safer than 1 hour
                          return event
                        Before:
                        After:
                        • F Offline
                          Fjerdrumsmoen
                          Hi
                          Need some help here.
                          Trying to get this module to work, but only the “header” of the month is showing. No events is listing, and no dates are showing. In the GoogleCalender module I can see the events, so I know that the GoogleCalender is working.
                          Do someone know what is wrong? My config file is like this:
                          			module: 'MMM-GoogleCalendar',
                          			header: "Familie Kalender",
                          						color: "red",
                          						broadcastPastEvents: true, // <= IMPORTANT to see past events
                          						calendarID: "GOOGLE ID_ deleted from the code"
                          						// add another calendar HERE if needed
                          			 module: "MMM-CalendarExt3",
                          			 position: "bottom_center",
                          			 title: "Familie kalenderen",
                          				mode: "month",
                          				instanceId: "basicCalendar",
                          				locale: 'de-DE',
                          				maxEventLines: 5,
                          				firstDayOfWeek: 1,
                          				calendarSet: ['FK']
                          S M 3 Replies Last reply Reply Quote 0
                            sdetweil @Fjerdrumsmoen
                            @Fjerdrumsmoen calendarExt3 gets its data from the default calendar module…
                            so you have to configure it, and just comment out the position: setting…
                              @Fjerdrumsmoen said in MMM-CalendarExt3:
                              module: ‘MMM-GoogleCalendar’,
                              no, use
                              module: "calendar"
                              • F Offline
                                Fjerdrumsmoen
                                Hmm. All empty when I use the calendar module, also. Tested with the US holidays, and everything stays blank. (Without the heading)
                                Any other tips?
                                  @Fjerdrumsmoen 1st
                                  w default cal module, does the calendar display?
                                  (before u comment out position)
                                  did u try the default ext3 config?
                                  I used the default ext3 config from doc, with the holidays
                                  commented out calendarSet, and locale…
                                    position: "bottom_bar",
                                    title: "",
                                      mode: "month",
                                     // locale: 'de-DE',
                                      maxEventLines: 5,
                                      firstDayOfWeek: 1,
                                      //calendarSet: ['us_holiday', 'abfall', 'mytest'],
                                  got
                                    MMRIZE @Fjerdrumsmoen
                                    @Fjerdrumsmoen
                                    For google calendar you need some additional config. See the readme.md more.
                                    • F Offline
                                      Fjerdrumsmoen
                                      Thanks. Now it shows :-)
                                      But not with Google account.
                                      Should i put in this code in the config.js?
                                      preProcessor: (e) => {
                                        e.startDate = new Date(e.start?.date || e.start?.dateTime).valueOf()
                                        e.endDate = new Date(e.end?.date || e.end?.dateTime).valueOf()
                                        e.title = e.summary
                                        e.fullDayEvent = (e.start?.date) ? true : false
                                        return e
                                        @Fjerdrumsmoen just use the Google url instead of the holidays… does it show in default calendar?
                                        no… fix that
                                          @Fjerdrumsmoen
                                          In CX3 module config not global or calendar module.
                                            MMRIZE
                                            1.4.0 (2023-06-04)
                                            popover
                                            • ADDED (Experimental) Show popover of event details on click/touch (Chrome 114 or Electron 25 needed)
                                            See https://github.com/MMRIZE/MMM-CalendarExt3/discussions/80
                                            • FIXED Clarify code for using MMM-GoogleCalendar module #78 (Thanks to @jcherniak)
                                            • UPDATED Updated CX3_Shared submodule #76 / More robust oppositeColor calculation. (Thanks to @btastic)
                                            Preview video is here: https://github.com/MMRIZE/public_ext_storage/issues/1
                                            luisestradaL 1 Reply Last reply Reply Quote 0
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 34
                                            • 35
                                            • 14 / 35
