    MMM-CalendarExt3
    689 Posts 82 Posters 3.0m Views 86 Watching
    • F Offline
      Fjerdrumsmoen
      Hmm. All empty when I use the calendar module, also. Tested with the US holidays, and everything stays blank. (Without the heading)
      Any other tips?
        sdetweil @Fjerdrumsmoen
        @Fjerdrumsmoen 1st
        w default cal module, does the calendar display?
        (before u comment out position)
        did u try the default ext3 config?
        I used the default ext3 config from doc, with the holidays
        commented out calendarSet, and locale…
          module: "MMM-CalendarExt3",
          position: "bottom_bar",
          title: "",
            mode: "month",
            instanceId: "basicCalendar",
           // locale: 'de-DE',
            maxEventLines: 5,
            firstDayOfWeek: 1,
            //calendarSet: ['us_holiday', 'abfall', 'mytest'],
        got
          MMRIZE @Fjerdrumsmoen
          @Fjerdrumsmoen
          For google calendar you need some additional config. See the readme.md more.
          • F Offline
            Fjerdrumsmoen
            Thanks. Now it shows :-)
            But not with Google account.
            Should i put in this code in the config.js?
            preProcessor: (e) => {
              e.startDate = new Date(e.start?.date || e.start?.dateTime).valueOf()
              e.endDate = new Date(e.end?.date || e.end?.dateTime).valueOf()
              e.title = e.summary
              e.fullDayEvent = (e.start?.date) ? true : false
              return e
              @Fjerdrumsmoen just use the Google url instead of the holidays… does it show in default calendar?
              no… fix that
                @Fjerdrumsmoen
                In CX3 module config not global or calendar module.
                  MMRIZE
                  1.4.0 (2023-06-04)
                  popover
                  • ADDED (Experimental) Show popover of event details on click/touch (Chrome 114 or Electron 25 needed)
                  See https://github.com/MMRIZE/MMM-CalendarExt3/discussions/80
                  • FIXED Clarify code for using MMM-GoogleCalendar module #78 (Thanks to @jcherniak)
                  • UPDATED Updated CX3_Shared submodule #76 / More robust oppositeColor calculation. (Thanks to @btastic)
                  Preview video is here: https://github.com/MMRIZE/public_ext_storage/issues/1
                  luisestradaL 1 Reply Last reply Reply Quote 0
                  • luisestradaL Offline
                    luisestrada @MMRIZE
                    @MMRIZE This is awesome!! Congrats!!!
                    Unfortunately I don’t have a touch screen but this opens a new world of possibilities for those who have.
                      MM19198
                      How do I use MMM-CalendarExt3 to show events from MMM-GoogleCalendar? I have MMM-GoogleCalendar setup and it’s displaying events. However, I tried adding MMM-CalendarExt3 to the config and it won’t display anything. Any help is much appreciated.
                      My config file…
                      	module: "MMM-GoogleCalendar",
                      	header: "Family Calendar",
                      	classes: "calendar-agenda",
                      				symbol: "calendar-week",
                      				calendarID: "myemail@gmail.com",
                      		fade: false,
                      		maximumNumberOfDays: 5,
                      		showlocation: true,
                      		tableClass: "medium",
                      		instanceID: "I-calendar-month",
                      		calendarSet: ['mycalendar'],
                      		weeksInView: 3
                      • BKeyportB Offline
                        BKeyport Module Developer @MM19198
                        @MM19198 https://github.com/MMRIZE/MMM-CalendarExt3#compatible-with-randombrainstormermmm-googlecalendar
                        There’s a config snippet there to make it work.
                          MM19198 @BKeyport
                          @BKeyport I appreciate the quick reply. I tried adding that but unfortunately it didn’t change anything.
                          Is there anything I need to do with eventNotification?
                          		fade: false,
                          		showlocation: true,
                          	title: "Family Calendar EXT3",
                          		mode: "week",
                          		weeksInView: 3,
                          			if (e.start?.dateTime) {
                          				  e.startDate = new Date(e.start.dateTime).valueOf()
                          			} else if (e.start?.date) {
                          				  e.startDate = new Date(`${e.start.date}T00:00:00`).valueOf()
                          			if (e.end?.dateTime) {
                          				  e.endDate = new Date(e.end.dateTime).valueOf()
                          			} else if (e.end?.date) {
                          				  e.endDate = new Date(`${e.end.date}T00:00:00`).valueOf()
                          			e.title = e.summary
                          			return e
                            MM19198 @BKeyport
                            @BKeyport In addition to that code you sent, I also had to add “broadcastEvents: true” to the MMM-GoogleCalendar config. Now I’m able to see events on the MMM-CalendarEXT3 module. Thanks!
                            • G Offline
                              gonzonia
                              Working on moving from CX2 to CX3.
                              A few things I’m being challenged by. Some might be limitations but figured I’d ask
                              1. In CX2 there were more icon sets available. Is CX3 limited to Font Awesome because the default calendar is?
                              2. Can CX3 in weekly view start from the current day vs. beginning of the week?
                              3. I can see there’s a module-header. How can I make the CX3 title from the config show there?
                              Possible CSS Questions
                              4) I’m having trouble getting the Day header to show only numeric for the whole week. It shows Month Day (Jul 3) in the first two days and then numeric for the rest. (I tried cellDateOptions: “{day: ‘numeric’}” in the config for the module and it shows “7/3/2023” and “7/4/2023” in the first two days. This is what I had to do to hide it with CSS.
                              .CX3 .week:nth-child(2) .cell:first-child .cellDate *
                                     display: none;
                              .CX3 .week:nth-child(2) .cell:first-child .cellDate .day
                                     display: inline-block;
                              .CX3 .today .cellDate :not(.day)
                                 display: none;
                              1. I had CX2 showing like this with the title on one line and the time on the next. Can that be done?
                              2. How to remove colored dot signifying calendar? I like a border instead?
                              BKeyportB M 3 Replies Last reply Reply Quote 0
                              • BKeyportB Offline
                                BKeyport Module Developer @gonzonia
                                @gonzonia
                                for #6, I’m sure it’s something like this, (I use CalendarExt3Agenda, which uses common code):
                                /* get rid of the icon */
                                .CX3 .event .headline .symbol {
                                  display: none;
                                  MMRIZE @gonzonia
                                  @gonzonia said in MMM-CalendarExt3:
                                  You are right. But I’m planning Iconify integration in the future version soon.
                                  From beginning of the week. (by the locale).
                                  For daily view, use CX3A. I think it could show more data conveniently.
                                    module: 'MMM-CalendarExt3',
                                    header: 'whatever',
                                    position: 'bottom_bar',
                                      mode: 'month',
                                  When you set header in config, the module title will be shown. In mode:'month', It will be changed to the value as headerTitleOptions defined automatically. In mode:'week'. It will remain static as you wrote it.
                                  (Do you need more configurable properties for this?)
                                  1. I’m having trouble getting the Day header to show only numeric for the whole week. It shows Month Day (Jul 3) in the first two days and then numeric for the rest. (I tried cellDateOptions: “{day: ‘numeric’}” in the config for the module and it shows “7/3/2023” and “7/4/2023” in the first two days. This is what I had to do to hide it with CSS.
                                  Weird. cellDateOptions: {day:'numeric'} should show only the number of the day. What is your locale? or check the typo.
                                  May possible, I remember I left the one example in this thread also. But personally I don’t like it because it is not so pretty and somehow wasting the space.
                                  Anyway, It needs heavy CSS tweek, I’ll try to give the example later.
                                    MMRIZE @gonzonia
                                    @gonzonia
                                    This might be what you want.
                                    // config/config.js
                                    	header: "Whatever",
                                    		mode: 'month',
                                    		cellDateOptions: { day: 'numeric' },
                                    		eventHeight: '44px',
                                    		maxEventLines: 3,
                                    		displayEndTime: true,
                                    /* css/custom.css */
                                    .CX3 .event .headline {
                                      flex-flow: row wrap;
                                      justify-content: flex-end;
                                    .CX3 .event .headline.useSymbol .symbol {
                                      display: none;
                                    .CX3 .event .headline .title,
                                    .CX3 .event .headline .time {
                                      height: var(--fontsize);
                                      line-height: 100%;
                                      text-overflow: ellipsis;
                                    .CX3 .event .headline .title {
                                      width: 100%;
                                      text-align: left;
                                      order: 4;
                                      text-align: right;
                                      width: 40%; /* It depends on your timeFormat length */
                                    .CX3 .cellHeader .cellDate {
                                      line-height: 100%;
                                    But this CSS is not configured in detail. It may have some bug or ugly look with some dimensions or environment. I prove the chance only and you can test and adjust it by yourself.
                                    • G Offline
                                      gonzonia @MMRIZE
                                      Thanks for all the help!
                                      Ideally I was hoping for weekly view but where the first day is the current day, so that on Friday I can still see what’s coming up in the next week.
                                      I understand that CX3A shows this information but it’s not in the same format and I prefer the look of the weekly format with CX3
                                      @MMRIZE said in MMM-CalendarExt3:
                                      Weird. cellDateOptions: {day:‘numeric’} should show only the number of the day. What is your locale? or check the typo.
                                      Locale is en-US.
                                      I’m in weekly view.
                                      It’s only on the first of the week and the current day. I’ve worked around it in CSS but I wouldn’t have expected it to show using
                                      This image is without any custom CSS applied
                                      This is the config.
                                      		  position: "lower_third",
                                      		  classes: "SceneFamily",
                                      		  header: 'Family Week',
                                      			mode: "week",
                                      			instanceId: "FamilyCalendar",
                                      			weekIndex: 0,
                                      			firstDayOfWeek: 0,
                                      			weeksInView: 1,
                                      			locale: 'en-US',
                                      			maxEventLines: 5,
                                      			firstDayOfWeek: 1,
                                      			calendarSet: ['us_holiday', '1', '2', '3', '4', '5'],
                                      			useWeather: false,
                                      			displayWeatherTemp: false,
                                      			useSymbol: true,
                                      			fontSize: "16px",
                                      			displayEndTime:true,
                                        MMRIZE @gonzonia
                                        @gonzonia
                                        In your configuration, there is no cellDateOptions.
                                        see my previous post for config.js
                                        • G Offline
                                          gonzonia @MMRIZE
                                          @MMRIZE Ha! I swear I’d tried that! When I did it would just show it as a numeric month and add the year.
                                          Working now though. Thanks
                                          • T Offline
                                            tjat
                                            @MMRIZE first, thank you for your development and continued efforts on this module. It is the centerpiece of my home dashboard. I am interested in incorporating user interaction to my calendar module. For instance,is there capability to display the prior or next month based on a user swiping or hitting an arrow key on an attached keyboard? I know other modules are needed to feature event listeners for those actions but I’m not sure if cx3 can handle the notifications those would pass as is.
                                            Alternatively if this would need serious coding, would running multiple instances of the module work (each for a different month) and showing/hiding as appropriate?
                                            (Long term, My dream state for my dashboard is an applet to popup and let the user add/modify an event directly from the screen and update my Google calendar, but that’ll be the last item in my list!)
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 34
                                            • 35
                                            • 14 / 35
