    MM as rolling picture frame
    21 Posts 8 Posters 11.5k Views 9 Watching
      sdetweil @ankonaskiff17
      @ankonaskiff17 here is my fork
      https://github.com/sdetweil/MMM-ImagesPhotos
      I always search
      GitHub module-name
      and never have trouble finding things
      it uses a naned folder. uploads, and you can link that anywhere
      on Linux the link command is ln
      ankonaskiff17A 1 Reply Last reply Reply Quote 0
        @ankonaskiff17 I have an older HP desktop that runs as a server, running Ubuntu Linux
        • ankonaskiff17A Offline
          ankonaskiff17 @sdetweil
          @sdetweil LOOL You’ve got the secret MMM stash.
            @sdetweil Also, good point to be aware of is that Github may have modules too.
              rts58
              I use MMM-BackgroundSlideshow for this. I like that it can display picture info. It also has the ability to move forward and back through the pictures, although it seems to have a problem with that in the latest version. I use it to randomly access thousand of images across many folders.
                @ankonaskiff17 the module I referenced came from GitHub, I made a fork (linked copy), says so right under mine if you look.
                I wanted more features. so I added them.
                the original has not been updated in a long time.
                I don’t have experience with any others. I was just talking about 1. you are welcome to ignore anything I say.
                  @sdetweil I take advice anywhere I can find it. I just meant that I don’t need to just search on the MM 3rd Party module page that Github is also fertile ground.
                    @ankonaskiff17 yes, 3rd party modules are on GitHub… it’s just another list
                      MMRIZE @ankonaskiff17
                      @ankonaskiff17
                      https://github.com/MichMich/MagicMirror/wiki/3rd-party-modules
                        ankonaskiff17 @MMRIZE
                        @MMRIZE I know all about 3rd party modules, some of which are well built, some others, not so much.
                        Just reaching out to people who may have already done same sort of project to avoid picking one of the not so good modules.
                        Kind of like Amazon, I don’t want to find 3 pieces of inferior product before stumbling on the quality module.
                        • I Offline
                          Inferhide
                          I see it’s been a while since you’ve posted, but I just wanted to ask if anyone has managed to mix in random folder sorting like “shuffle” for photos instead of date order. Also curious if newer versions of the MMM-BackgroundSlideshow module handle transitions better—mine sometimes skips or freezes with larger image sets. Would love to hear how others have fine-tuned theirs lately.
                            sdetweil @Inferhide
                            @Inferhide I use MMM-ImagesPhotos and don’t see those issued
                            What is a large image set?
                              RonR
                              Posting pictures on MM was something I am doing also. I’m using sdetweil
                              MMM-ImagesPhotos from third party modules. It was easy to setup and works well. You have to store your images in a local directory inside the module. It has several options available which I have not looked into yet. Just set it up yesterday.
                                sdetweil @RonR
                                @RonR the local folder can be linked(see the ln command) to a share mounted from another server source(in /etc/fstab)
                                  @RonR
                                  make the mount point
                                  sudo mkdir /media/fileserver
                                  in fstab, change username and password to the server folder
                                  and the path to the server , this is my synology NAS
                                  //192.168.2.32/media
                                  //192.168.2.32/media /media/fileserver cifs username=xxxxx,password=yyyyyyyy,iocharset=utf8,file_mode=0777,dir_mode=0777
                                  before reboot
                                  sudo mount -a
                                  now
                                  ls /media/fileserver
                                  should show files
                                  on reboot it will auto mount
                                  now in the MMM-ImagesPhotos folder, move the uploads folder out of the way
                                  mv uploads  o-uploads
                                  now link the mount point there
                                  sudo ln -s  /media/fileserver uploads
                                  now
                                  ls uploads
                                  should show the files from the server
                                  the ln command could link a subdirectory of the mount point too
                                  in the MMM-ImagePhotos folder
                                  ls -laF
                                  should show
                                  uploads --> /media/fileserver
                                  • UncleRogerU Offline
                                    UncleRoger
                                    I use MMM-BackgroundSlideshow to display random paintings from over 200 images. It seems to work pretty well.
                                    All of the paintings are stored locally on the Pi, in a subdirectory of the module directory: ~/MagicMirror/modules/MMM-BackgroundSlideshow/Paintings
                                      sdetweil @UncleRoger
                                      @UncleRoger you could move them to a server too
                                      • BKeyportB Offline
                                        BKeyport Module Developer
                                        here’s how I did it.
                                        1. Set up SAMBA on the pi, and include a mapping to your photos drive (I wouldn’t recommend keeping them locally)
                                        2. magic mirror’s config, using MMM-Backgroundslideshow
                                        /* Magic Mirror Config by Brendan Keyport. */
                                        /* Office - Certificate Display */
                                        var config = {
                                        	address: "0.0.0.0",
                                        	port: 8082,  // port is 8082 as I use a server/client style setup.
                                        	ipWhitelist: [],
                                        	language: "en",
                                        	timeFormat: 12,
                                        	units: "imperial",
                                        	//logLevel: ["INFO", "LOG", "WARN", "ERROR", "DEBUG"],
                                        	customCss: "css/custom3.css",
                                        	modules:
                                            		module: 'MMM-BackgroundSlideshow',
                                            		position: 'fullscreen_below',
                                              			imagePaths: ['<path to shared folder>'],
                                              			transitionImages: true,
                                              			randomizeImageOrder: true,
                                              			showAllImagesBeforeRestart: true,
                                              			//transitionSpeed: 0,
                                              			gradient: [0],
                                              			horizontalGradient: [0],
                                              			backgroundSize: "contain"
                                        /*************** DO NOT EDIT BELOW ***************/
                                        if (typeof module !== "undefined") {
                                        	module.exports = config;
                                        Easy as Pi.
