    MM as rolling picture frame
    21 Posts 8 Posters 7.5k Views 9 Watching
      sdetweil @ankonaskiff17
      @ankonaskiff17 I have an older HP desktop that runs as a server, running Ubuntu Linux
      ankonaskiff17A 1 Reply Last reply Reply Quote 0
      • ankonaskiff17A Offline
        ankonaskiff17 @sdetweil
        @sdetweil LOOL You’ve got the secret MMM stash.
          @sdetweil Also, good point to be aware of is that Github may have modules too.
            rts58
            I use MMM-BackgroundSlideshow for this. I like that it can display picture info. It also has the ability to move forward and back through the pictures, although it seems to have a problem with that in the latest version. I use it to randomly access thousand of images across many folders.
              @ankonaskiff17 the module I referenced came from GitHub, I made a fork (linked copy), says so right under mine if you look.
              I wanted more features. so I added them.
              the original has not been updated in a long time.
              I don’t have experience with any others. I was just talking about 1. you are welcome to ignore anything I say.
                @sdetweil I take advice anywhere I can find it. I just meant that I don’t need to just search on the MM 3rd Party module page that Github is also fertile ground.
                  @ankonaskiff17 yes, 3rd party modules are on GitHub… it’s just another list
                    MMRIZE @ankonaskiff17
                    @ankonaskiff17
                    https://github.com/MichMich/MagicMirror/wiki/3rd-party-modules
                      ankonaskiff17 @MMRIZE
                      @MMRIZE I know all about 3rd party modules, some of which are well built, some others, not so much.
                      Just reaching out to people who may have already done same sort of project to avoid picking one of the not so good modules.
                      Kind of like Amazon, I don’t want to find 3 pieces of inferior product before stumbling on the quality module.
                      • I Offline
                        Inferhide
                        I see it’s been a while since you’ve posted, but I just wanted to ask if anyone has managed to mix in random folder sorting like “shuffle” for photos instead of date order. Also curious if newer versions of the MMM-BackgroundSlideshow module handle transitions better—mine sometimes skips or freezes with larger image sets. Would love to hear how others have fine-tuned theirs lately.
                          sdetweil @Inferhide
                          @Inferhide I use MMM-ImagesPhotos and don’t see those issued
                          What is a large image set?
                            RonR
                            Posting pictures on MM was something I am doing also. I’m using sdetweil
                            MMM-ImagesPhotos from third party modules. It was easy to setup and works well. You have to store your images in a local directory inside the module. It has several options available which I have not looked into yet. Just set it up yesterday.
                              sdetweil @RonR
                              @RonR the local folder can be linked(see the ln command) to a share mounted from another server source(in /etc/fstab)
                                @RonR
                                make the mount point
                                sudo mkdir /media/fileserver
                                in fstab, change username and password to the server folder
                                and the path to the server , this is my synology NAS
                                //192.168.2.32/media
                                //192.168.2.32/media /media/fileserver cifs username=xxxxx,password=yyyyyyyy,iocharset=utf8,file_mode=0777,dir_mode=0777
                                before reboot
                                sudo mount -a
                                now
                                ls /media/fileserver
                                should show files
                                on reboot it will auto mount
                                now in the MMM-ImagesPhotos folder, move the uploads folder out of the way
                                mv uploads  o-uploads
                                now link the mount point there
                                sudo ln -s  /media/fileserver uploads
                                now
                                ls uploads
                                should show the files from the server
                                the ln command could link a subdirectory of the mount point too
                                in the MMM-ImagePhotos folder
                                ls -laF
                                should show
                                uploads --> /media/fileserver
                                • UncleRogerU Offline
                                  UncleRoger
                                  I use MMM-BackgroundSlideshow to display random paintings from over 200 images. It seems to work pretty well.
                                  All of the paintings are stored locally on the Pi, in a subdirectory of the module directory: ~/MagicMirror/modules/MMM-BackgroundSlideshow/Paintings
                                    sdetweil @UncleRoger
                                    @UncleRoger you could move them to a server too
                                    • BKeyportB Offline
                                      BKeyport Module Developer
                                      here’s how I did it.
                                      1. Set up SAMBA on the pi, and include a mapping to your photos drive (I wouldn’t recommend keeping them locally)
                                      2. magic mirror’s config, using MMM-Backgroundslideshow
                                      /* Magic Mirror Config by Brendan Keyport. */
                                      /* Office - Certificate Display */
                                      var config = {
                                      	address: "0.0.0.0",
                                      	port: 8082,  // port is 8082 as I use a server/client style setup.
                                      	ipWhitelist: [],
                                      	language: "en",
                                      	timeFormat: 12,
                                      	units: "imperial",
                                      	//logLevel: ["INFO", "LOG", "WARN", "ERROR", "DEBUG"],
                                      	customCss: "css/custom3.css",
                                      	modules:
                                          		module: 'MMM-BackgroundSlideshow',
                                          		position: 'fullscreen_below',
                                            			imagePaths: ['<path to shared folder>'],
                                            			transitionImages: true,
                                            			randomizeImageOrder: true,
                                            			showAllImagesBeforeRestart: true,
                                            			//transitionSpeed: 0,
                                            			gradient: [0],
                                            			horizontalGradient: [0],
                                            			backgroundSize: "contain"
                                      /*************** DO NOT EDIT BELOW ***************/
                                      if (typeof module !== "undefined") {
                                      	module.exports = config;
                                      Easy as Pi.
