    MM as rolling picture frame
    21 Posts 8 Posters 11.8k Views 9 Watching
      sdetweil @ankonaskiff17
      @ankonaskiff17 I use MMM-ImagesPhotos for this…
      I added some features for centering and filling …
      I link to my file server to get the pics
      ankonaskiff17A 1 Reply Last reply Reply Quote 0
      • ankonaskiff17A
        ankonaskiff17 @sdetweil
        @sdetweil I did a search and drew a blank on module you describe MMM-ImagesPhotos. I’ll poke around with some of the others.
        Since my knowledge of servers is minimal at best from hardware side required I sort of understand that but I’ve never set about to create a server I’ll have to figure that out.
        I have several jumbo external hard drives and SSD drives and I was just going to plug one of them into an open USB socket on the Pi.
        Side subject but maybe good use for the lone Raspberry Pi 1? I tried to use it (Pi 1) for a Pi-Hole I just built but was something that was incompatible so it went back on the shelf
          @ankonaskiff17 here is my fork
          https://github.com/sdetweil/MMM-ImagesPhotos
          I always search
          GitHub module-name
          and never have trouble finding things
          it uses a naned folder. uploads, and you can link that anywhere
          on Linux the link command is ln
            @ankonaskiff17 I have an older HP desktop that runs as a server, running Ubuntu Linux
            • ankonaskiff17A
              @sdetweil LOOL You’ve got the secret MMM stash.
              • ankonaskiff17A
                @sdetweil Also, good point to be aware of is that Github may have modules too.
                  rts58
                  I use MMM-BackgroundSlideshow for this. I like that it can display picture info. It also has the ability to move forward and back through the pictures, although it seems to have a problem with that in the latest version. I use it to randomly access thousand of images across many folders.
                    @ankonaskiff17 the module I referenced came from GitHub, I made a fork (linked copy), says so right under mine if you look.
                    I wanted more features. so I added them.
                    the original has not been updated in a long time.
                    I don’t have experience with any others. I was just talking about 1. you are welcome to ignore anything I say.
                    • ankonaskiff17A
                      @sdetweil I take advice anywhere I can find it. I just meant that I don’t need to just search on the MM 3rd Party module page that Github is also fertile ground.
                        @ankonaskiff17 yes, 3rd party modules are on GitHub… it’s just another list
                          MMRIZE @ankonaskiff17
                          @ankonaskiff17
                          https://github.com/MichMich/MagicMirror/wiki/3rd-party-modules
                          • ankonaskiff17A
                            ankonaskiff17 @MMRIZE
                            @MMRIZE I know all about 3rd party modules, some of which are well built, some others, not so much.
                            Just reaching out to people who may have already done same sort of project to avoid picking one of the not so good modules.
                            Kind of like Amazon, I don’t want to find 3 pieces of inferior product before stumbling on the quality module.
                            • I
                              Inferhide
                              I see it’s been a while since you’ve posted, but I just wanted to ask if anyone has managed to mix in random folder sorting like “shuffle” for photos instead of date order. Also curious if newer versions of the MMM-BackgroundSlideshow module handle transitions better—mine sometimes skips or freezes with larger image sets. Would love to hear how others have fine-tuned theirs lately.
                                sdetweil @Inferhide
                                @Inferhide I use MMM-ImagesPhotos and don’t see those issued
                                What is a large image set?
                                  RonR
                                  Posting pictures on MM was something I am doing also. I’m using sdetweil
                                  MMM-ImagesPhotos from third party modules. It was easy to setup and works well. You have to store your images in a local directory inside the module. It has several options available which I have not looked into yet. Just set it up yesterday.
                                    sdetweil @RonR
                                    @RonR the local folder can be linked(see the ln command) to a share mounted from another server source(in /etc/fstab)
                                      @RonR
                                      make the mount point
                                      sudo mkdir /media/fileserver
                                      in fstab, change username and password to the server folder
                                      and the path to the server , this is my synology NAS
                                      //192.168.2.32/media
                                      //192.168.2.32/media /media/fileserver cifs username=xxxxx,password=yyyyyyyy,iocharset=utf8,file_mode=0777,dir_mode=0777
                                      before reboot
                                      sudo mount -a
                                      now
                                      ls /media/fileserver
                                      should show files
                                      on reboot it will auto mount
                                      now in the MMM-ImagesPhotos folder, move the uploads folder out of the way
                                      mv uploads  o-uploads
                                      now link the mount point there
                                      sudo ln -s  /media/fileserver uploads
                                      now
                                      ls uploads
                                      should show the files from the server
                                      the ln command could link a subdirectory of the mount point too
                                      in the MMM-ImagePhotos folder
                                      ls -laF
                                      should show
                                      uploads --> /media/fileserver
                                      • UncleRogerU
                                        UncleRoger
                                        I use MMM-BackgroundSlideshow to display random paintings from over 200 images. It seems to work pretty well.
                                        All of the paintings are stored locally on the Pi, in a subdirectory of the module directory: ~/MagicMirror/modules/MMM-BackgroundSlideshow/Paintings
                                          sdetweil @UncleRoger
                                          @UncleRoger you could move them to a server too
                                          • BKeyportB
                                            BKeyport Module Developer
                                            here’s how I did it.
                                            1. Set up SAMBA on the pi, and include a mapping to your photos drive (I wouldn’t recommend keeping them locally)
                                            2. magic mirror’s config, using MMM-Backgroundslideshow
                                            /* Magic Mirror Config by Brendan Keyport. */
                                            /* Office - Certificate Display */
                                            var config = {
                                            	address: "0.0.0.0",
                                            	port: 8082,  // port is 8082 as I use a server/client style setup.
                                            	ipWhitelist: [],
                                            	language: "en",
                                            	timeFormat: 12,
                                            	units: "imperial",
                                            	//logLevel: ["INFO", "LOG", "WARN", "ERROR", "DEBUG"],
                                            	customCss: "css/custom3.css",
                                            	modules:
                                                		module: 'MMM-BackgroundSlideshow',
                                                		position: 'fullscreen_below',
                                                  			imagePaths: ['<path to shared folder>'],
                                                  			transitionImages: true,
                                                  			randomizeImageOrder: true,
                                                  			showAllImagesBeforeRestart: true,
                                                  			//transitionSpeed: 0,
                                                  			gradient: [0],
                                                  			horizontalGradient: [0],
                                                  			backgroundSize: "contain"
                                            /*************** DO NOT EDIT BELOW ***************/
                                            if (typeof module !== "undefined") {
                                            	module.exports = config;
                                            Easy as Pi.
