    MMM-Netatmo updated
    56 Posts 15 Posters 44.1k Views 16 Watching
      joffe
      Hello
      Is it possible to remove Air Quality completely?
      • A
        Aardal1
        Thanks for all the great work with this module!
        Is there is a way to add some air between the different elements?
        Its a lot of information in a small space.
        I made this example in ps:
        Also, is there a way to remove the update interval text at the bottom?
        I could not find this in the description.
        Tried the “hideLoadTimer: true,” with no success.
        • K
          kj3rra
          @miller
          Hi, I happen to have 3 base stations (home and two cabins) and I wonder if its possible to differentiate between the base station, so I can choose which one to display? It looks to me as if Netatmo have a “hierarchy” on the base stations, where the station you first added will have priority no.1 and the one showing in this module. Removing all base stations and shuffle the hierarchy isnt an option as I have 3 mirrors where I want to display each of the 3 base stations separately.
          Any thoughts anyone?
          FoziF 1 Reply Last reply
            MajorC Project Sponsor
            @aardal1 is there a good custom-css style available, to get more space between all the data, like shown in the picture?
            • FoziF
              Fozi Project Sponsor @kj3rra
              @kj3rra I’m a bit late to the party but I found a fork of the MMM-Netatmo module which allows to differentiate between several base stations. I recently had the same problem and I solved it that way.
              https://github.com/MariusEng/MMM-Netatmo
              There is an option called
              deviceNumber
              which you can adress in your config. Works flawlessly!
                I think, this will effect the MMM-Netatmo?
                Dear Netatmo developer,
                To improve the security of our products, we inform you that the Client Credentials grant type method will be completely removed. It will no longer be possible to authenticate with the username and password of the user.
                The effective date of this update is October 2022.
                How can you authenticate with Netatmo API ?
                From this date, the OAuth2 authorization code flow must be followed for authentication.
                You can find details on this method on our website:
                Netatmo Connect | Authentication
                For tests, you can also get an Access Token from our developper portal.
                Netatmo Developer Portal
                Log in
                Go on your account
                Select the application for your test
                Click on "Generate a Token"
                You can now use this Access Token for 3 hours.
                • L
                  Laz
                  Good afternoon! I am from Russia, so the translator works.
                  I set up the CFenner author’s Netatmo module. Created an application on the Netatmo website and received an ID and key.
                  Everything works, but the author does not have English everywhere.
                  I liked your module more.
                  I tried to set it up. Unfortunately, I could not get the token through the cURL command line (I inserted my login, password, ID and key into the line. But an error is issued. Then I made a token on the application page. I inserted it into your module, but unfortunately the module does not show anything… ((I have the names of the sensors in the station settings in Russian. I entered them in config.js.
                  L 1 Reply Last reply
                  Reply Quote -1
                  • L
                    Laz @Laz
                    @Laz The module CFenner stopped working, apparently the problem is authorization (Netatmo developers have changed the method of authorization). How to log in now?
                    K 1 Reply Last reply
                    • K
                      kasperinline @Laz
                      @Laz
                      Did you find a solution?
                      I’ve got the same problem :-(
                      T 1 Reply Last reply
                      • T
                        Tribun @kasperinline
                        @kasperinline Have you tried to create new credentials via the Netatmo web portal?
                        https://dev.netatmo.com/ I am using a fork of this module and have clientId,
                        clientSecret, accessToken, new
                        created. With this, the query of the Netatmo data works again.
                        • L
                          Laz @Tribun
                          @Tribun
                          Are you using a module from CFenner?
                          There is no accessToken input in this module. Only clientId and clientSecret are entered.
                          Have you made regenerate your client id and client secret in your application on the Netatmo website?
                          And entered new data into the module settings and everything worked?
                          (In addition to the problem with authorization in the Netatmo module in the Magic mirror, I have the same problem with authorization in the RainMachine auto-watering device. There, too, the login\password and client id and client secret are entered. Creating a new application on the Netatmo website and entering new data in the RainMachine settings did not help with authorization…)
                          • T
                            Tribun @Laz
                            @Laz Sorry, I got the module wrong, I used RaymondMolenaar’s module. There it was enough to recreate the module data on the Netatmo developer homepage and to exchange the data in config.js. A few months ago I recreated the access data because the module was no longer working properly, something was probably wrong with the API at the time Netatmo changed.
                            I have the new data "clientId: "
                            "clientSecret: "
                            “refreshToken:”
                            “accessToken:”
                            inserted into the config and the module works again.
                            • L
                              Laz @Tribun
                              @Tribun
                              Thank you
                              Did you create an app on the https://dev.netatmo.com/apps/ website?
                              I tried to put the RaymondMolenaar module once.
                              Here above (September 27, 2022) I wrote about my problem…
                              How did you get token ?
                              On the Netatmo application page, it is not clear which token should be used… ((Screenshot_19.png
                              • T
                                Tribun @Laz
                                @Laz
                                At choose scopes: select “read station” and press generate token, you will get the “refreshToken:” and
                                “accessToken:”
                                Enter all newly created values ​​in config.js after that it should work again.
                                • L
                                  Laz @Tribun
                                  @Tribun
                                  M 1 Reply Last reply
                                    Mitch_66 @Laz
                                    Hi All, thanks for the support provided in this forum here. Awesome!
                                    I’m following all what is said here: got “refreshToken”, “accessToken” via the Netatmo page, entered it in the config.js exactly as stated here. Nevertheless, the module won’t show up on the mirror - just a small circle beneath the header.
                                    Am I missing “something”, a specific setting for the mirror? The RBpi is not publicly accessible from the internet, no web hook URI, no direct URI configured.
                                    Any help appreciated! The Netatmo module is the feature why we have the MM2!
                                      Mitch_66 @Mitch_66
                                      @Mitch_66 I found the solution to my problem: once I inserted the moduleOrder parameter, the module showed up. As it isn’t marked as “required”, I didn’t put it in the first place.
                                      Maybe helps somebody having the same issue
                                      • L
                                        Laz @Mitch_66
                                        @Mitch_66
                                        Good afternoon!
                                        Please show your config in this module. I also prescribed this parameter, but my Netatmo module does not appear… (((
                                          Mitch_66 @Laz
                                          @Laz
                                          Will do but you’ll need to wait a bit. Currently far away from home, back in a week
                                            Mitch_66 @Mitch_66
                                            @Laz
                                            Here’s my config that works. The name for the rooms in Netatmo are as specified in the Netatmo App. It’s a quite ‘old’ Netatmo module, talking about 8 years or so hence for sure not the latest hardware.
        module: 'MMM-Netatmo',
        disabled: false,
        position: 'bottom_bar', // the location where the module should be displayed
        header: 'Netatmo',
        clientId: 'clientID', // your app id
        clientSecret: 'clientSecret', // your app secret
        refreshToken: 'refresh|token', // your generated refresh token
        accessToken: 'access|token',
        location: "germany/badenwurttemberg/stuttgart-arnulf-klett-platz",  //for AirQuality
        updateIntervalAirQuality: 300, // in secondes = every 30 minutes
        updatesIntervalDisplay: 60, //refresh internal
        lastMessageThreshold: 600, // in seconds (10 minutes)
        horizontal: true,
        horizontalOverflow: false,
        windUnit: "KMH",
        showLastMessage: true,
        showDataIcon: true,
        showDataHeader: true,
        showModuleStatus: true,
        showModuleFirmware: true,
        refreshInterval: 3,
        moduleOrder: ["Wohnzimmer", "Schlafzimmer", "Terrasse" ],
                                            L 2 Replies Last reply
                                            • 2 / 3
