    MMM-Netatmo updated
    56 Posts 15 Posters 43.7k Views 16 Watching
      Miller @zdenek
      @zdenek
      The AQI font class is inherited from the default .small class of MM.
      To override this, add the following to the CSS
      .MMM-netatmo .displayAQI .small {
        font-size: 10px;
        line-height: 15px;
      To override all the .small classes in MMM-Netatmo
      .MMM-netatmo .small {
        font-size: 10px;
        line-height: 15px;
      The same goes for the Temperature, this Uses the default .large font class
      to override add:
      .MMM-netatmo .large {
        font-size: 40px;
      The .x-medium is only applied to .secondary.displayWindAngle.WindAgle
      The other icons is the normal .medium which comes from MM
      So you can override
      .x-medium {
        font-size:100%;
      and
      .MMM-netatmo .medium {
        font-size: 70%;
      zdenekZ 1 Reply Last reply
      • zdenekZ
        zdenek @Miller
        @Miller that’s perfect, thanks
        • T
          Tribun
          Hi Miller,
          First of all, I want to tell you that you have built a great module. It looks awesome.
          However, I have a problem with the display of the air quality.
          What do I have to enter if I want to take this place?
          e.g .:
          https://aqicn.org/city/austria/laschoberstrasse--ostlich-kreisverkehr-ruster-strasse/
          I only see “wait”.
            Miller
            I cannot take credit for building the module, I only redesigned it a bit.
            As for the Air Quality, took me some figuring out as well.
            However, as a location, put the string in behind city, so in your case it would be:
            location: "austria/laschoberstrasse--ostlich-kreisverkehr-ruster-strasse",
            T 1 Reply Last reply
            • T
              Tribun @Miller
              @Miller thanks for your help and the great design. ;)
              • FoziF
                Fozi Project Sponsor
                Just came across this post and tried out your fork immediatelly …and it is fantastic. It’s just the way I always wanted! Thanks a lot!
                  joffe
                  Hello
                  Is it possible to remove Air Quality completely?
                  • A
                    Aardal1
                    Thanks for all the great work with this module!
                    Is there is a way to add some air between the different elements?
                    Its a lot of information in a small space.
                    I made this example in ps:
                    Also, is there a way to remove the update interval text at the bottom?
                    I could not find this in the description.
                    Tried the “hideLoadTimer: true,” with no success.
                    • K
                      kj3rra
                      @miller
                      Hi, I happen to have 3 base stations (home and two cabins) and I wonder if its possible to differentiate between the base station, so I can choose which one to display? It looks to me as if Netatmo have a “hierarchy” on the base stations, where the station you first added will have priority no.1 and the one showing in this module. Removing all base stations and shuffle the hierarchy isnt an option as I have 3 mirrors where I want to display each of the 3 base stations separately.
                      Any thoughts anyone?
                      FoziF 1 Reply Last reply
                        MajorC Project Sponsor
                        @aardal1 is there a good custom-css style available, to get more space between all the data, like shown in the picture?
                        • FoziF
                          Fozi Project Sponsor @kj3rra
                          @kj3rra I’m a bit late to the party but I found a fork of the MMM-Netatmo module which allows to differentiate between several base stations. I recently had the same problem and I solved it that way.
                          https://github.com/MariusEng/MMM-Netatmo
                          There is an option called
                          deviceNumber
                          which you can adress in your config. Works flawlessly!
                            I think, this will effect the MMM-Netatmo?
                            Dear Netatmo developer,
                            To improve the security of our products, we inform you that the Client Credentials grant type method will be completely removed. It will no longer be possible to authenticate with the username and password of the user.
                            The effective date of this update is October 2022.
                            How can you authenticate with Netatmo API ?
                            From this date, the OAuth2 authorization code flow must be followed for authentication.
                            You can find details on this method on our website:
                            Netatmo Connect | Authentication
                            For tests, you can also get an Access Token from our developper portal.
                            Netatmo Developer Portal
                            Log in
                            Go on your account
                            Select the application for your test
                            Click on "Generate a Token"
                            You can now use this Access Token for 3 hours.
                            • L
                              Laz
                              Good afternoon! I am from Russia, so the translator works.
                              I set up the CFenner author’s Netatmo module. Created an application on the Netatmo website and received an ID and key.
                              Everything works, but the author does not have English everywhere.
                              I liked your module more.
                              I tried to set it up. Unfortunately, I could not get the token through the cURL command line (I inserted my login, password, ID and key into the line. But an error is issued. Then I made a token on the application page. I inserted it into your module, but unfortunately the module does not show anything… ((I have the names of the sensors in the station settings in Russian. I entered them in config.js.
                              L 1 Reply Last reply
                              Reply Quote -1
                              • L
                                Laz @Laz
                                @Laz The module CFenner stopped working, apparently the problem is authorization (Netatmo developers have changed the method of authorization). How to log in now?
                                K 1 Reply Last reply
                                • K
                                  kasperinline @Laz
                                  @Laz
                                  Did you find a solution?
                                  I’ve got the same problem :-(
                                  • T
                                    Tribun @kasperinline
                                    @kasperinline Have you tried to create new credentials via the Netatmo web portal?
                                    https://dev.netatmo.com/ I am using a fork of this module and have clientId,
                                    clientSecret, accessToken, new
                                    created. With this, the query of the Netatmo data works again.
                                    • L
                                      Laz @Tribun
                                      @Tribun
                                      Are you using a module from CFenner?
                                      There is no accessToken input in this module. Only clientId and clientSecret are entered.
                                      Have you made regenerate your client id and client secret in your application on the Netatmo website?
                                      And entered new data into the module settings and everything worked?
                                      (In addition to the problem with authorization in the Netatmo module in the Magic mirror, I have the same problem with authorization in the RainMachine auto-watering device. There, too, the login\password and client id and client secret are entered. Creating a new application on the Netatmo website and entering new data in the RainMachine settings did not help with authorization…)
                                      • T
                                        Tribun @Laz
                                        @Laz Sorry, I got the module wrong, I used RaymondMolenaar’s module. There it was enough to recreate the module data on the Netatmo developer homepage and to exchange the data in config.js. A few months ago I recreated the access data because the module was no longer working properly, something was probably wrong with the API at the time Netatmo changed.
                                        I have the new data "clientId: "
                                        "clientSecret: "
                                        “refreshToken:”
                                        “accessToken:”
                                        inserted into the config and the module works again.
                                        • L
                                          Laz @Tribun
                                          @Tribun
                                          Thank you
                                          Did you create an app on the https://dev.netatmo.com/apps/ website?
                                          I tried to put the RaymondMolenaar module once.
                                          Here above (September 27, 2022) I wrote about my problem…
                                          How did you get token ?
                                          On the Netatmo application page, it is not clear which token should be used… ((Screenshot_19.png
                                          • T
                                            Tribun @Laz
                                            @Laz
                                            At choose scopes: select “read station” and press generate token, you will get the “refreshToken:” and
                                            “accessToken:”
                                            Enter all newly created values ​​in config.js after that it should work again.
                                            • 2 / 3
