    MMM-Netatmo updated
    56 Posts 15 Posters 42.3k Views 16 Watching
      Miller @frogywill
      @frogywill To show Fahrenheit, change your default settings of MagicMirror units to “imperial”
      Or set units: “imperial” in MMM-Netatmo config
        Miller @zdenek
        @zdenek
        The AQI font class is inherited from the default .small class of MM.
        To override this, add the following to the CSS
        .MMM-netatmo .displayAQI .small {
          font-size: 10px;
          line-height: 15px;
        To override all the .small classes in MMM-Netatmo
        .MMM-netatmo .small {
          font-size: 10px;
          line-height: 15px;
        The same goes for the Temperature, this Uses the default .large font class
        to override add:
        .MMM-netatmo .large {
          font-size: 40px;
        The .x-medium is only applied to .secondary.displayWindAngle.WindAgle
        The other icons is the normal .medium which comes from MM
        So you can override
        .x-medium {
          font-size:100%;
        and
        .MMM-netatmo .medium {
          font-size: 70%;
        zdenekZ 1 Reply Last reply Reply Quote 0
        • zdenekZ Offline
          zdenek @Miller
          @Miller that’s perfect, thanks
          • T Offline
            Tribun
            Hi Miller,
            First of all, I want to tell you that you have built a great module. It looks awesome.
            However, I have a problem with the display of the air quality.
            What do I have to enter if I want to take this place?
            e.g .:
            https://aqicn.org/city/austria/laschoberstrasse--ostlich-kreisverkehr-ruster-strasse/
            I only see “wait”.
              Miller
              I cannot take credit for building the module, I only redesigned it a bit.
              As for the Air Quality, took me some figuring out as well.
              However, as a location, put the string in behind city, so in your case it would be:
              location: "austria/laschoberstrasse--ostlich-kreisverkehr-ruster-strasse",
              • T Offline
                Tribun @Miller
                @Miller thanks for your help and the great design. ;)
                • FoziF Offline
                  Fozi Project Sponsor
                  Just came across this post and tried out your fork immediatelly …and it is fantastic. It’s just the way I always wanted! Thanks a lot!
                    joffe
                    Hello
                    Is it possible to remove Air Quality completely?
                      Aardal1
                      Thanks for all the great work with this module!
                      Is there is a way to add some air between the different elements?
                      Its a lot of information in a small space.
                      I made this example in ps:
                      Also, is there a way to remove the update interval text at the bottom?
                      I could not find this in the description.
                      Tried the “hideLoadTimer: true,” with no success.
                      • K Offline
                        kj3rra
                        @miller
                        Hi, I happen to have 3 base stations (home and two cabins) and I wonder if its possible to differentiate between the base station, so I can choose which one to display? It looks to me as if Netatmo have a “hierarchy” on the base stations, where the station you first added will have priority no.1 and the one showing in this module. Removing all base stations and shuffle the hierarchy isnt an option as I have 3 mirrors where I want to display each of the 3 base stations separately.
                        Any thoughts anyone?
                          MajorC Project Sponsor
                          @aardal1 is there a good custom-css style available, to get more space between all the data, like shown in the picture?
                          • FoziF Offline
                            Fozi Project Sponsor @kj3rra
                            @kj3rra I’m a bit late to the party but I found a fork of the MMM-Netatmo module which allows to differentiate between several base stations. I recently had the same problem and I solved it that way.
                            https://github.com/MariusEng/MMM-Netatmo
                            There is an option called
                            deviceNumber
                            which you can adress in your config. Works flawlessly!
                              I think, this will effect the MMM-Netatmo?
                              Dear Netatmo developer,
                              To improve the security of our products, we inform you that the Client Credentials grant type method will be completely removed. It will no longer be possible to authenticate with the username and password of the user.
                              The effective date of this update is October 2022.
                              How can you authenticate with Netatmo API ?
                              From this date, the OAuth2 authorization code flow must be followed for authentication.
                              You can find details on this method on our website:
                              Netatmo Connect | Authentication
                              For tests, you can also get an Access Token from our developper portal.
                              Netatmo Developer Portal
                              Log in
                              Go on your account
                              Select the application for your test
                              Click on "Generate a Token"
                              You can now use this Access Token for 3 hours.
                              • L Offline
                                Laz
                                Good afternoon! I am from Russia, so the translator works.
                                I set up the CFenner author’s Netatmo module. Created an application on the Netatmo website and received an ID and key.
                                Everything works, but the author does not have English everywhere.
                                I liked your module more.
                                I tried to set it up. Unfortunately, I could not get the token through the cURL command line (I inserted my login, password, ID and key into the line. But an error is issued. Then I made a token on the application page. I inserted it into your module, but unfortunately the module does not show anything… ((I have the names of the sensors in the station settings in Russian. I entered them in config.js.
                                L 1 Reply Last reply Reply Quote -1
                                • L Offline
                                  Laz @Laz
                                  @Laz The module CFenner stopped working, apparently the problem is authorization (Netatmo developers have changed the method of authorization). How to log in now?
                                  • K Offline
                                    kasperinline @Laz
                                    @Laz
                                    Did you find a solution?
                                    I’ve got the same problem :-(
                                    • T Offline
                                      Tribun @kasperinline
                                      @kasperinline Have you tried to create new credentials via the Netatmo web portal?
                                      https://dev.netatmo.com/ I am using a fork of this module and have clientId,
                                      clientSecret, accessToken, new
                                      created. With this, the query of the Netatmo data works again.
                                      • L Offline
                                        Laz @Tribun
                                        @Tribun
                                        Are you using a module from CFenner?
                                        There is no accessToken input in this module. Only clientId and clientSecret are entered.
                                        Have you made regenerate your client id and client secret in your application on the Netatmo website?
                                        And entered new data into the module settings and everything worked?
                                        (In addition to the problem with authorization in the Netatmo module in the Magic mirror, I have the same problem with authorization in the RainMachine auto-watering device. There, too, the login\password and client id and client secret are entered. Creating a new application on the Netatmo website and entering new data in the RainMachine settings did not help with authorization…)
                                        • T Offline
                                          Tribun @Laz
                                          @Laz Sorry, I got the module wrong, I used RaymondMolenaar’s module. There it was enough to recreate the module data on the Netatmo developer homepage and to exchange the data in config.js. A few months ago I recreated the access data because the module was no longer working properly, something was probably wrong with the API at the time Netatmo changed.
                                          I have the new data "clientId: "
                                          "clientSecret: "
                                          “refreshToken:”
                                          “accessToken:”
                                          inserted into the config and the module works again.
                                          • L Offline
                                            Laz @Tribun
                                            @Tribun
                                            Thank you
                                            Did you create an app on the https://dev.netatmo.com/apps/ website?
                                            I tried to put the RaymondMolenaar module once.
                                            Here above (September 27, 2022) I wrote about my problem…
                                            How did you get token ?
                                            On the Netatmo application page, it is not clear which token should be used… ((Screenshot_19.png
                                            • 2 / 3
