This forum was moved to another machine and updated to a recent version. If you are unable to login please delete your browser cookies and cache and restart your browser.A New Chapter for MagicMirror: The Community Takes the Lead
MMM-Button white screen
i have the same problem.
@Babene1 try this
cd ~/MagicMirror/modules/MMM-Button
sudo npm rebuild --runtime=electron --target=1.4.6 --disturl=https://atom.io/download/atom-shell --abi=50 -
now it woks, thank you very much.
Have I made a mistake here?
Or what is the reason? -
I have the same problem. I did perform “nmp install” and “npm install onoff” in the MMM-Button folder.
And the fix from Nonamexp. But the screen after a reboot is white. :-(pi@raspberrypi:~ $ tail -f /home/pi/.pm2/logs/mm-error-0.log at Error (native) at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:168:20) at Object.Module._extensions..node (module.js:583:18) at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:168:20) at Module.load (module.js:473:32) at tryModuleLoad (module.js:432:12) at Function.Module._load (module.js:424:3) at Module.require (module.js:483:17) at require (internal/module.js:20:19) at bindings (/home/pi/MagicMirror/modules/MMM-Button/node_modules/bindings/bindings.js:76:44)
@FlorianRD after The Update do you have the raspberry pi restart?
Yes, even many times.
This post is deleted! -
He guys. Another error log after raspberry startup. Maybe helps?
pi@raspberrypi:~ $ npm start dev npm ERR! Linux 4.4.26-v7+ npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start" "dev" npm ERR! node v6.9.1 npm ERR! npm v3.10.8 npm ERR! path /home/pi/package.json npm ERR! code ENOENT npm ERR! errno -2 npm ERR! syscall open npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json' npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json' npm ERR! enoent This is most likely not a problem with npm itself npm ERR! enoent and is related to npm not being able to find a file. npm ERR! enoent npm ERR! Please include the following file with any support request: npm ERR! /home/pi/npm-debug.log
@FlorianRD
you are in the wrong directory.cd MagicMirror npm start dev
