    MMM-Button white screen
    23 Posts 9 Posters 19.4k Views 8 Watching
      schubi
      Hello, i have the same problem. I also get a white-screen. My error-log:
      $ tail -f /home/pi/.pm2/logs/mm-error-0.log
      at Error (native)
      at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:178:20)
      at Object.Module._extensions..node (module.js:583:18)
      at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:178:20)
      at Module.load (module.js:473:32)
      at tryModuleLoad (module.js:432:12)
      at Function.Module._load (module.js:424:3)
      at Module.require (module.js:483:17)
      at require (internal/module.js:20:19)
      at bindings (/home/pi/MagicMirror/modules/MMM-Button/node_modules/bindings/bindings.js:76:44)
      Any Ideas? Thanks!
      I’ve done everything which was postet in this topic…
        dicker182
        I have the same problem. Also did everything from this thread.
          Babene1 Project Sponsor
          • N
            Nonamexp @Babene1
            @Babene1 try this
            cd ~/MagicMirror/modules/MMM-Button
            sudo npm rebuild --runtime=electron --target=1.4.6 --disturl=https://atom.io/download/atom-shell --abi=50
              now it woks, thank you very much.
              Have I made a mistake here?
              Or what is the reason?
              • F
                FlorianRD
                I have the same problem. I did perform “nmp install” and “npm install onoff” in the MMM-Button folder.
                And the fix from Nonamexp. But the screen after a reboot is white. :-(
                pi@raspberrypi:~ $ tail -f /home/pi/.pm2/logs/mm-error-0.log
                    at Error (native)
                    at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:168:20)
                    at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:168:20)
                • N
                  Nonamexp @FlorianRD
                  @FlorianRD after The Update do you have the raspberry pi restart?
                  • F
                    FlorianRD
                    Yes, even many times.
                    • F
                      FlorianRD
                      • F
                        FlorianRD
                        • F
                          FlorianRD
                          He guys. Another error log after raspberry startup. Maybe helps?
                          pi@raspberrypi:~ $ npm start dev
                          npm ERR! Linux 4.4.26-v7+
                          npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start" "dev"
                          npm ERR! node v6.9.1
                          npm ERR! npm  v3.10.8
                          npm ERR! code ENOENT
                          npm ERR! errno -2
                          npm ERR! syscall open
                          npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                          npm ERR! enoent This is most likely not a problem with npm itself
                          npm ERR! enoent and is related to npm not being able to find a file.
                          npm ERR! enoent
                          npm ERR!     /home/pi/npm-debug.log
                          • Y
                            yawns Moderator @FlorianRD
                            @FlorianRD
                            you are in the wrong directory.
                            cd MagicMirror
                            npm start dev
                            • F
                              FlorianRD
                              Okay, next try…
                              npm ERR! node v7.4.0
                              npm ERR! npm  v4.0.5
                              npm ERR! code ELIFECYCLE
                              npm ERR! magicmirror@2.0.0 start: `electron js/electron.js "dev"`
                              npm ERR! Exit status 1
                              npm ERR!
                              npm ERR! Failed at the magicmirror@2.0.0 start script 'electron js/electron.js "dev"'.
                              npm ERR! If you do, this is most likely a problem with the magicmirror package,
                              npm ERR! not with npm itself.
                              npm ERR!     electron js/electron.js "dev"
                              npm ERR!     npm bugs magicmirror
                              npm ERR! Or if that isn't available, you can get their info via:
                              npm ERR!     npm owner ls magicmirror
                              npm ERR!     /home/pi/MagicMirror/npm-debug.log
