    MMM-Button white screen
    23 Posts 9 Posters 19.4k Views 8 Watching
    • K
      KirAsh4 Moderator
      That tells me you didn’t read the instructions, because step 2, under Installation, it specifically says to run 'npm install' which would’ve taken care of installing onoff for you. I find it helps when I follow the author’s instructions.
      https://github.com/PtrBld/MMM-Button#installation
        shgmongohh @KirAsh4
        @KirAsh4
        I read the instruction and I executed the nmp install in the MagicMirror folder and thought that onoff would be installed automaticly.
        But I had to execute npm install onoff extra in the MagicMirror folder to get the module run.
        Maybe there should a step 3, that tells you to execute npm install onoff .
        Sebastian
        • K
          KirAsh4 Moderator
          No, the instructions, as written, are accurate. You missed the last bit of Step 1:
          1. Navigate into your MagicMirror’s modules folder and execute git clone https://github.com/ptrbld/MMM-Button.git.**`A new folder will appear navigate into it.`**
          2. Execute npm install to install the node dependencies.
          Had you done that last bit, you would be executing the next step from within the button module folder, not within the MagicMirror folder.
            shgmongohh @KirAsh4
            @KirAsh4
            Ahhh, okay, that´s an explanation why I have sometimes problems with some modules.
            Thank you.
            • K
              KirAsh4 Moderator
              It can be a confusing, sometimes damn near frustrating landscape to maneuver. Glad you got it to work though.
                schubi
                Hello, i have the same problem. I also get a white-screen. My error-log:
                $ tail -f /home/pi/.pm2/logs/mm-error-0.log
                at Error (native)
                at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:178:20)
                at Object.Module._extensions..node (module.js:583:18)
                at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:178:20)
                at Module.load (module.js:473:32)
                at tryModuleLoad (module.js:432:12)
                at Function.Module._load (module.js:424:3)
                at Module.require (module.js:483:17)
                at require (internal/module.js:20:19)
                at bindings (/home/pi/MagicMirror/modules/MMM-Button/node_modules/bindings/bindings.js:76:44)
                Any Ideas? Thanks!
                I’ve done everything which was postet in this topic…
                  dicker182
                  I have the same problem. Also did everything from this thread.
                    Babene1 Project Sponsor
                    • N
                      Nonamexp @Babene1
                      @Babene1 try this
                      cd ~/MagicMirror/modules/MMM-Button
                      sudo npm rebuild --runtime=electron --target=1.4.6 --disturl=https://atom.io/download/atom-shell --abi=50
                        now it woks, thank you very much.
                        Have I made a mistake here?
                        Or what is the reason?
                        • F
                          FlorianRD
                          I have the same problem. I did perform “nmp install” and “npm install onoff” in the MMM-Button folder.
                          And the fix from Nonamexp. But the screen after a reboot is white. :-(
                          pi@raspberrypi:~ $ tail -f /home/pi/.pm2/logs/mm-error-0.log
                              at Error (native)
                              at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:168:20)
                              at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:168:20)
                          • N
                            Nonamexp @FlorianRD
                            @FlorianRD after The Update do you have the raspberry pi restart?
                            • F
                              FlorianRD
                              Yes, even many times.
                              • F
                                FlorianRD
                                • F
                                  FlorianRD
                                  • F
                                    FlorianRD
                                    He guys. Another error log after raspberry startup. Maybe helps?
                                    pi@raspberrypi:~ $ npm start dev
                                    npm ERR! Linux 4.4.26-v7+
                                    npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start" "dev"
                                    npm ERR! node v6.9.1
                                    npm ERR! npm  v3.10.8
                                    npm ERR! code ENOENT
                                    npm ERR! errno -2
                                    npm ERR! syscall open
                                    npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                                    npm ERR! enoent This is most likely not a problem with npm itself
                                    npm ERR! enoent and is related to npm not being able to find a file.
                                    npm ERR! enoent
                                    npm ERR!     /home/pi/npm-debug.log
                                    • Y
                                      yawns Moderator @FlorianRD
                                      @FlorianRD
                                      you are in the wrong directory.
                                      cd MagicMirror
                                      npm start dev
                                      • F
                                        FlorianRD
                                        Okay, next try…
                                        npm ERR! node v7.4.0
                                        npm ERR! npm  v4.0.5
                                        npm ERR! code ELIFECYCLE
                                        npm ERR! magicmirror@2.0.0 start: `electron js/electron.js "dev"`
                                        npm ERR! Exit status 1
                                        npm ERR!
                                        npm ERR! Failed at the magicmirror@2.0.0 start script 'electron js/electron.js "dev"'.
                                        npm ERR! If you do, this is most likely a problem with the magicmirror package,
                                        npm ERR! not with npm itself.
                                        npm ERR!     electron js/electron.js "dev"
                                        npm ERR!     npm bugs magicmirror
                                        npm ERR! Or if that isn't available, you can get their info via:
                                        npm ERR!     npm owner ls magicmirror
                                        npm ERR!     /home/pi/MagicMirror/npm-debug.log
