    MMM-Button white screen
    23 Posts 9 Posters 19.7k Views 8 Watching
      dicker182
      I have the same problem. Also did everything from this thread.
        Babene1 Project Sponsor
        i have the same problem.
        N 1 Reply Last reply
        • N
          Nonamexp @Babene1
          @Babene1 try this
          cd ~/MagicMirror/modules/MMM-Button
          sudo npm rebuild --runtime=electron --target=1.4.6 --disturl=https://atom.io/download/atom-shell --abi=50
            now it woks, thank you very much.
            Have I made a mistake here?
            Or what is the reason?
            • F
              FlorianRD
              I have the same problem. I did perform “nmp install” and “npm install onoff” in the MMM-Button folder.
              And the fix from Nonamexp. But the screen after a reboot is white. :-(
              pi@raspberrypi:~ $ tail -f /home/pi/.pm2/logs/mm-error-0.log
                  at Error (native)
                  at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:168:20)
                  at Object.Module._extensions..node (module.js:583:18)
                  at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:168:20)
                  at Module.load (module.js:473:32)
                  at tryModuleLoad (module.js:432:12)
                  at Function.Module._load (module.js:424:3)
                  at Module.require (module.js:483:17)
                  at require (internal/module.js:20:19)
                  at bindings (/home/pi/MagicMirror/modules/MMM-Button/node_modules/bindings/bindings.js:76:44)
              • N
                Nonamexp @FlorianRD
                @FlorianRD after The Update do you have the raspberry pi restart?
                • F
                  FlorianRD
                  Yes, even many times.
                  • F
                    FlorianRD
                    • F
                      FlorianRD
                      • F
                        FlorianRD
                        He guys. Another error log after raspberry startup. Maybe helps?
                        pi@raspberrypi:~ $ npm start dev
                        npm ERR! Linux 4.4.26-v7+
                        npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start" "dev"
                        npm ERR! node v6.9.1
                        npm ERR! npm  v3.10.8
                        npm ERR! code ENOENT
                        npm ERR! errno -2
                        npm ERR! syscall open
                        npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                        npm ERR! enoent This is most likely not a problem with npm itself
                        npm ERR! enoent and is related to npm not being able to find a file.
                        npm ERR! enoent
                        npm ERR!     /home/pi/npm-debug.log
                        yawnsY 1 Reply Last reply
                        • yawnsY
                          yawns Moderator @FlorianRD
                          @FlorianRD
                          you are in the wrong directory.
                          cd MagicMirror
                          npm start dev
                          • F
                            FlorianRD
                            Okay, next try…
                            npm ERR! node v7.4.0
                            npm ERR! npm  v4.0.5
                            npm ERR! code ELIFECYCLE
                            npm ERR! magicmirror@2.0.0 start: `electron js/electron.js "dev"`
                            npm ERR! Exit status 1
                            npm ERR!
                            npm ERR! Failed at the magicmirror@2.0.0 start script 'electron js/electron.js "dev"'.
                            npm ERR! If you do, this is most likely a problem with the magicmirror package,
                            npm ERR! not with npm itself.
                            npm ERR!     electron js/electron.js "dev"
                            npm ERR!     npm bugs magicmirror
                            npm ERR! Or if that isn't available, you can get their info via:
                            npm ERR!     npm owner ls magicmirror
                            npm ERR!     /home/pi/MagicMirror/npm-debug.log
