    MMM-Button white screen
    23 Posts 9 Posters 19.7k Views 8 Watching
    • strawberry 3.141S
      code: ‘MODULE_NOT_FOUND’ sounds like you misspelled the module name in the config
        shgmongohh @strawberry 3.141
        @strawberry-3.141
        I checked the double checked the spelling. Everthing is correct.
        The screen stays white…
        I tried node serveronly
        pi@raspberrypi:~/MagicMirror $ node serveronly
        Loading config …
        Loading module helpers …
        WARNING! Could not find config. Please create one.
        Whoops! There was an uncaught exception…
        { Error: Cannot find module ‘onoff’
        at Function.Module._resolveFilename (module.js:440:15)
        at Function.Module._load (module.js:388:25)
        at Module.require (module.js:468:17)
        at require (internal/module.js:20:19)
        at Object. (/home/pi/MagicMirror/modules/MMM-Button/node_helper.j s:10:14)
        at Module._compile (module.js:541:32)
        at Object.Module._extensions…js (module.js:550:10)
        at Module.load (module.js:458:32)
        at tryModuleLoad (module.js:417:12)
        at Function.Module._load (module.js:409:3) code: ‘MODULE_NOT_FOUND’ }
        MagicMirror will not quit, but it might be a good idea to check why this happene d. Maybe no internet connection?
        If you think this really is an issue, please open an issue on GitHub: https://gi thub.com/MichMich/MagicMirror/issues
          shgmongohh
          Solved the problem…
          I hat forgotten to install onoff (pi@raspberrypi:~/MagicMirror $ npm install onoff
          • KirAsh4K
            KirAsh4 Moderator
            That tells me you didn’t read the instructions, because step 2, under Installation, it specifically says to run 'npm install' which would’ve taken care of installing onoff for you. I find it helps when I follow the author’s instructions.
            https://github.com/PtrBld/MMM-Button#installation
              shgmongohh @KirAsh4
              @KirAsh4
              I read the instruction and I executed the nmp install in the MagicMirror folder and thought that onoff would be installed automaticly.
              But I had to execute npm install onoff extra in the MagicMirror folder to get the module run.
              Maybe there should a step 3, that tells you to execute npm install onoff .
              Sebastian
              • KirAsh4K
                KirAsh4 Moderator
                No, the instructions, as written, are accurate. You missed the last bit of Step 1:
                1. Navigate into your MagicMirror’s modules folder and execute git clone https://github.com/ptrbld/MMM-Button.git.**`A new folder will appear navigate into it.`**
                2. Execute npm install to install the node dependencies.
                Had you done that last bit, you would be executing the next step from within the button module folder, not within the MagicMirror folder.
                  shgmongohh @KirAsh4
                  @KirAsh4
                  Ahhh, okay, that´s an explanation why I have sometimes problems with some modules.
                  Thank you.
                  • KirAsh4K
                    KirAsh4 Moderator
                    It can be a confusing, sometimes damn near frustrating landscape to maneuver. Glad you got it to work though.
                      schubi
                      Hello, i have the same problem. I also get a white-screen. My error-log:
                      $ tail -f /home/pi/.pm2/logs/mm-error-0.log
                      at Error (native)
                      at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:178:20)
                      at Object.Module._extensions..node (module.js:583:18)
                      at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:178:20)
                      at Module.load (module.js:473:32)
                      at tryModuleLoad (module.js:432:12)
                      at Function.Module._load (module.js:424:3)
                      at Module.require (module.js:483:17)
                      at bindings (/home/pi/MagicMirror/modules/MMM-Button/node_modules/bindings/bindings.js:76:44)
                      Any Ideas? Thanks!
                      I’ve done everything which was postet in this topic…
                        dicker182
                        I have the same problem. Also did everything from this thread.
                          Babene1 Project Sponsor
                          N 1 Reply Last reply
                          • N
                            Nonamexp @Babene1
                            @Babene1 try this
                            cd ~/MagicMirror/modules/MMM-Button
                            sudo npm rebuild --runtime=electron --target=1.4.6 --disturl=https://atom.io/download/atom-shell --abi=50
                              now it woks, thank you very much.
                              Have I made a mistake here?
                              Or what is the reason?
                              • F
                                FlorianRD
                                I have the same problem. I did perform “nmp install” and “npm install onoff” in the MMM-Button folder.
                                And the fix from Nonamexp. But the screen after a reboot is white. :-(
                                pi@raspberrypi:~ $ tail -f /home/pi/.pm2/logs/mm-error-0.log
                                    at Error (native)
                                    at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:168:20)
                                    at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:168:20)
                                • N
                                  Nonamexp @FlorianRD
                                  @FlorianRD after The Update do you have the raspberry pi restart?
                                  • F
                                    FlorianRD
                                    Yes, even many times.
                                    • F
                                      FlorianRD
                                      • F
                                        FlorianRD
                                        • F
                                          FlorianRD
                                          He guys. Another error log after raspberry startup. Maybe helps?
                                          pi@raspberrypi:~ $ npm start dev
                                          npm ERR! Linux 4.4.26-v7+
                                          npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start" "dev"
                                          npm ERR! node v6.9.1
                                          npm ERR! npm  v3.10.8
                                          npm ERR! code ENOENT
                                          npm ERR! errno -2
                                          npm ERR! syscall open
                                          npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                                          npm ERR! enoent This is most likely not a problem with npm itself
                                          npm ERR! enoent and is related to npm not being able to find a file.
                                          npm ERR! enoent
                                          npm ERR!     /home/pi/npm-debug.log
                                          yawnsY 1 Reply Last reply
                                          • yawnsY
                                            yawns Moderator @FlorianRD
                                            @FlorianRD
                                            you are in the wrong directory.
                                            cd MagicMirror
                                            npm start dev
