MMM-Button white screen
23 Posts 9 Posters 15.8k Views 8 Watching
    shgmongohh
    I have installed the MMM Button. When I restart my PI3 I only get a white screen.
    When I uncomment the butten module in the config with //, the screen is after a new start normal.
    I have also tried it with a connected and unconneted butten. Always the same.
    Has anybody an idea, why I have a white screen?
    Sebastian
      shgmongohh
      Here is the error log:
      pi@raspberrypi:~ $ tail -f /home/pi/.pm2/logs/mm-error-0.log
      at Module._resolveFilename (module.js:438:15)
      at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron-prebuilt/dist/resources/electron.asar/comm/reset-search-paths.js:35:12)
      at Function.Module._load (module.js:386:25)
      at Module.require (module.js:466:17)
      at require (internal/module.js:20:19)
      at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Button/node_helper.js:10:14)
      at Module._compile (module.js:541:32)
      at Object.Module._extensions..js (module.js:550:10)
      at Module.load (module.js:456:32)
      at tryModuleLoad (module.js:415:12) code: 'MODULE_NOT_FOUND' }
        code: ‘MODULE_NOT_FOUND’ sounds like you misspelled the module name in the config
        S 1 Reply Last reply Jul 28, 2016, 7:05 PM Reply Quote 0
          shgmongohh @strawberry 3.141
          @strawberry-3.141
          I checked the double checked the spelling. Everthing is correct.
          The screen stays white…
          I tried node serveronly
          pi@raspberrypi:~/MagicMirror $ node serveronly
          Loading config …
          Loading module helpers …
          WARNING! Could not find config. Please create one.
          Whoops! There was an uncaught exception…
          { Error: Cannot find module ‘onoff’
          at Function.Module._resolveFilename (module.js:440:15)
          at Function.Module._load (module.js:388:25)
          at Module.require (module.js:468:17)
          at Object. (/home/pi/MagicMirror/modules/MMM-Button/node_helper.j s:10:14)
          at Object.Module._extensions…js (module.js:550:10)
          at Module.load (module.js:458:32)
          at tryModuleLoad (module.js:417:12)
          at Function.Module._load (module.js:409:3) code: ‘MODULE_NOT_FOUND’ }
          MagicMirror will not quit, but it might be a good idea to check why this happene d. Maybe no internet connection?
          If you think this really is an issue, please open an issue on GitHub: https://gi thub.com/MichMich/MagicMirror/issues
            shgmongohh
            Solved the problem…
            I hat forgotten to install onoff (pi@raspberrypi:~/MagicMirror $ npm install onoff
            • K Offline
              KirAsh4 Moderator
              That tells me you didn’t read the instructions, because step 2, under Installation, it specifically says to run 'npm install' which would’ve taken care of installing onoff for you. I find it helps when I follow the author’s instructions.
              https://github.com/PtrBld/MMM-Button#installation
              S 1 Reply Last reply Jul 29, 2016, 5:24 AM Reply Quote 0
                shgmongohh @KirAsh4
                @KirAsh4
                I read the instruction and I executed the nmp install in the MagicMirror folder and thought that onoff would be installed automaticly.
                But I had to execute npm install onoff extra in the MagicMirror folder to get the module run.
                Maybe there should a step 3, that tells you to execute npm install onoff .
                Sebastian
                • K Offline
                  KirAsh4 Moderator
                  No, the instructions, as written, are accurate. You missed the last bit of Step 1:
                  1. Navigate into your MagicMirror’s modules folder and execute git clone https://github.com/ptrbld/MMM-Button.git.**`A new folder will appear navigate into it.`**
                  2. Execute npm install to install the node dependencies.
                  Had you done that last bit, you would be executing the next step from within the button module folder, not within the MagicMirror folder.
                  S 1 Reply Last reply Jul 29, 2016, 10:24 AM Reply Quote 1
                    shgmongohh @KirAsh4
                    @KirAsh4
                    Ahhh, okay, that´s an explanation why I have sometimes problems with some modules.
                    Thank you.
                    • K Offline
                      KirAsh4 Moderator
                      It can be a confusing, sometimes damn near frustrating landscape to maneuver. Glad you got it to work though.
                      1 / 3
