    MMM-CalendarExt3
    689 Posts 82 Posters 3.3m Views 86 Watching
      sdetweil @furry131
      @furry131 9/8 is along way away… maybe ext3 in month view can show that…
      default stops at 10 days I think. . actually 10 entries
      maximumEntries: 10,
      F 1 Reply Last reply
      • F
        furry131 @sdetweil
        i found something in my IOS for tomorrow. so I would think it is pulling down ok.
        either way, the soccer one is pulling down current stuff this week.
        BEGIN:VEVENT
        CREATED:20230719T035111Z
        DTEND;VALUE=DATE:20230821
        DTSTAMP:20230810T232604Z
        DTSTART;VALUE=DATE:20230819
        LAST-MODIFIED:20230810T232604Z
        SEQUENCE:1
        SUMMARY:Soccer tournament
        UID:FB687F6C-CA14-4F4D-8AAD-FBB2D21688B2
        URL;VALUE=URI:
        END:VEVENT
          sdetweil @furry131
          @furry131 ok, one does it show on default cal? does default have position set?
          does it show in ext3?
          • F
            furry131 @sdetweil
            default calendar shows on the top right. It shows entries from my IOS calendar and my soccer calendar( IOS is “meeting with alice” Soccer is “north 14 B select III”) as positioned on the config.js, (see screen shot below)
            it does not show on ext3. All I get is the header.
            • F
              furry131
              OK well this is fun. I was reading again and saw in the instructions about moving back to 1.2.6. SOOOOOO… I decided to give it a hoot. Well, now the calendar is showing up for me.
              Not sure what this means.
              just thought I would share.
              Just need to fix the formatting now.
              johnf@mm:~/MagicMirror/modules/MMM-CalendarExt3 $ git checkout snap-1.2.6
              Branch 'snap-1.2.6' set up to track remote branch 'snap-1.2.6' from 'origin'.
              Switched to a new branch 'snap-1.2.6'
              M 1 Reply Last reply
                MMRIZE @furry131
                @furry131
                It might mean;
                1. Your module was not properly installed. I think this would be the solution in your case generally.
                cd ~/MagicMirror/modules/MMM-CalendarExt3
                git checkout main
                git pull
                npm install
                git submodule update --init --recursive
                1. Or your MM (Or Chromium/Browser what you are using) is somewhat old, update it.
                • F
                  furry131 @MMRIZE
                  @MMRIZE
                  OK thanks. I just ran your suggestions and restarted MM. It is running.
                  I just installed MM last week and I used sdetweil’s install script. Also just ran the the update script he has. seems to only needing to update Node.js from v16.13.0 to v16.13.1.
                  Must have been something odd with the install of the module then.
                  Appreciate everyone’s help.
                    MMRIZE
                    UPDATE 1.5.0
                    Now, the module has a new mode, day; it could show a relatively week-like view. You can adjust the beginning of the seven-day cells from today (or relatively by dayIndex).
                    G 1 Reply Last reply
                    • G
                      gonzonia @MMRIZE
                      @MMRIZE Thank you! That’s just what I wanted!
                        bicolorbore586 @MMRIZE
                        @MMRIZE
                        Is there a way to change the height of a calendar so it’s either nothing, or very thin?
                        Using the “manipulateDateCell” I get the desired effect of having an icon in the cell header, however I’d like to not have a “blank” entry in the day view (see picture)
                          MMRIZE @bicolorbore586
                          @bicolorbore586
                          What is that ‘blank’? I cannot guess what it is pointing. Could you show me a bigger picture? and to reproduce your case, send or show me the config and css with real ical urls. (eouia0819@gmail.com)
                          • A
                            aircliff
                            Have a question I’m hoping others may have seen and resolved.
                            Currently I run my MagicMirror in server mode and have popover enabled on my calendar. When I access from a computer with a mouse and click the individual calendar events the popover comes up as expected. When I access from my tablet the popover will not come up when I touch the individual events. Other modules I have such as MMM-OnScreenMenu responds appropriately to touch on the tablets.
                            I’m hoping others may have seen this and have a recommendation for what I should look at. I’m assuming there is a setting somewhere in one of the files I need to enable or define in some specific way in the config file.
                            Everything with the module otherwise works perfectly, just the one item I’m trying to resolve with popover when using with a tablet touchscreen.
                            Thank you
                            S M 2 Replies Last reply
                              sdetweil @aircliff
                              @aircliff it’s probable that the tablet doesn’t support the right level of JavaScript for the pop-up to happen
                                MMRIZE @aircliff
                                @aircliff
                                I’m using new way to handle popover thing, the “popover” API which is suggested recently as standard, but not all the browser supports it yet.
                                https://github.com/MMRIZE/MMM-CalendarExt3/discussions/80
                                  sdetweil @MMRIZE
                                  @MMRIZE and tablets and TVs and fix devices are using fairly old browsers and don’t generally have any mechanism to upgrade them to the latest releases so it’s unlikely that the tablet will ever support the pop-up the same way as a native browser will
                                    CurlyQ12391
                                    Hello, I hope that this is the correct place to ask about this…
                                    I’ve been playing around with adding backgrounds to my CalX3 for US holidays (example of the Valentines background below):
                                    Since the CSS is applying the background to a specific month/date combo I am unsure how I can accommodate holidays that occur on the same day but different dates each year (e.g., Thanksgiving, Labor Day, etc).
                                    The below CSS is all the dates Labor Day could fall on, but this wouldn’t work unless I comment out the incorrect dates each year :/ any ideas/suggestions?
                                    /* Labor Day - First Monday in September */
                                    .CX3 .month_9.date_1,
                                    .CX3 .month_9.date_2,
                                    .CX3 .month_9.date_3,
                                    .CX3 .month_9.date_4,
                                    .CX3 .month_9.date_5,
                                    .CX3 .month_9.date_6,
                                    .CX3 .month_9.date_7,
                                    .CX3 .month_9.date_8 {
                                      background-image: url("/modules/MMM-CalendarExt3/Backgrounds/LaborDay");
                                      background-position: center center;
                                      background-size: 60%;
                                      background-repeat: no-repeat;
                                    Thank you!
                                      MMRIZE @CurlyQ12391
                                      @CurlyQ12391
                                      There is the selector “.weekday_N”(0-6). ATM I cannot remember exactly but “weekday_0” probably is “Sunday” (or Monday), anyway try it.
                                      https://github.com/MMRIZE/MMM-CalendarExt3#styling-with-css
                                      C 1 Reply Last reply
                                        CurlyQ12391 @MMRIZE
                                        @MMRIZE,
                                        That did the trick! Adding “weekday” prevented the image from populating on multiple cells :) This module is by far my favorite because of how customizable it is.
                                        .CX3 .month_9.date_1.weekday_1,
                                        .CX3 .month_9.date_2.weekday_1,
                                        .CX3 .month_9.date_3.weekday_1,
                                        .CX3 .month_9.date_4.weekday_1  {
                                        The only one I haven’t been able to figure out is Easter Sunday because it is the first between March 22 and April 25. I dont believe CSS can handle that type of logic, maybe JS but thats a little too complex for me. For now I will just leave Easter off the calendar.
                                          MMRIZE @CurlyQ12391
                                          @CurlyQ12391
                                          I think it is possible with “manipulateDateCell”. I will show example after my return from a business trip in a few days.
                                            MMRIZE @CurlyQ12391
                                            @CurlyQ12391
                                              module: "MMM-CalendarExt3",
                                              position: "bottom_bar",
                                                mode: 'month',
                                                manipulateDateCell: (dom, events) => {
                                                  let date = new Date(+dom.dataset.date)
                                                  if (date.getMonth() == 8 && date.getDate() == 2) { // specific cell by absolute date
                                                    dom.classList.add('specialHoliday')
                                                    dom.style.backgroundColor = 'red'
                                                    // do whatever you want.
                                                  if (events.some(e => e.title.search("Gelber") > -1)){ // specific cell by event
                                                    dom.classList.add('specialEvent')
                                                    dom.style.backgroundColor = 'yellow'
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 34
                                            • 35
                                            • 17 / 35
