    MMM-CalendarExt3
    689 Posts 82 Posters 3.0m Views 86 Watching
    • F Offline
      furry131 @sdetweil
      i found something in my IOS for tomorrow. so I would think it is pulling down ok.
      either way, the soccer one is pulling down current stuff this week.
      BEGIN:VEVENT
      CREATED:20230719T035111Z
      DTEND;VALUE=DATE:20230821
      DTSTAMP:20230810T232604Z
      DTSTART;VALUE=DATE:20230819
      LAST-MODIFIED:20230810T232604Z
      SEQUENCE:1
      SUMMARY:Soccer tournament
      UID:FB687F6C-CA14-4F4D-8AAD-FBB2D21688B2
      URL;VALUE=URI:
      END:VEVENT
        sdetweil @furry131
        @furry131 ok, one does it show on default cal? does default have position set?
        does it show in ext3?
        • F Offline
          furry131 @sdetweil
          default calendar shows on the top right. It shows entries from my IOS calendar and my soccer calendar( IOS is “meeting with alice” Soccer is “north 14 B select III”) as positioned on the config.js, (see screen shot below)
          it does not show on ext3. All I get is the header.
          • F Offline
            furry131
            OK well this is fun. I was reading again and saw in the instructions about moving back to 1.2.6. SOOOOOO… I decided to give it a hoot. Well, now the calendar is showing up for me.
            Not sure what this means.
            just thought I would share.
            Just need to fix the formatting now.
            johnf@mm:~/MagicMirror/modules/MMM-CalendarExt3 $ git checkout snap-1.2.6
            Branch 'snap-1.2.6' set up to track remote branch 'snap-1.2.6' from 'origin'.
            Switched to a new branch 'snap-1.2.6'
              MMRIZE @furry131
              @furry131
              It might mean;
              1. Your module was not properly installed. I think this would be the solution in your case generally.
              cd ~/MagicMirror/modules/MMM-CalendarExt3
              git checkout main
              git pull
              npm install
              git submodule update --init --recursive
              1. Or your MM (Or Chromium/Browser what you are using) is somewhat old, update it.
              • F Offline
                furry131 @MMRIZE
                @MMRIZE
                OK thanks. I just ran your suggestions and restarted MM. It is running.
                I just installed MM last week and I used sdetweil’s install script. Also just ran the the update script he has. seems to only needing to update Node.js from v16.13.0 to v16.13.1.
                Must have been something odd with the install of the module then.
                Appreciate everyone’s help.
                  MMRIZE
                  UPDATE 1.5.0
                  Now, the module has a new mode, day; it could show a relatively week-like view. You can adjust the beginning of the seven-day cells from today (or relatively by dayIndex).
                  • G Offline
                    gonzonia @MMRIZE
                    @MMRIZE Thank you! That’s just what I wanted!
                      bicolorbore586 @MMRIZE
                      @MMRIZE
                      Is there a way to change the height of a calendar so it’s either nothing, or very thin?
                      Using the “manipulateDateCell” I get the desired effect of having an icon in the cell header, however I’d like to not have a “blank” entry in the day view (see picture)
                        MMRIZE @bicolorbore586
                        @bicolorbore586
                        What is that ‘blank’? I cannot guess what it is pointing. Could you show me a bigger picture? and to reproduce your case, send or show me the config and css with real ical urls. (eouia0819@gmail.com)
                          aircliff
                          Have a question I’m hoping others may have seen and resolved.
                          Currently I run my MagicMirror in server mode and have popover enabled on my calendar. When I access from a computer with a mouse and click the individual calendar events the popover comes up as expected. When I access from my tablet the popover will not come up when I touch the individual events. Other modules I have such as MMM-OnScreenMenu responds appropriately to touch on the tablets.
                          I’m hoping others may have seen this and have a recommendation for what I should look at. I’m assuming there is a setting somewhere in one of the files I need to enable or define in some specific way in the config file.
                          Everything with the module otherwise works perfectly, just the one item I’m trying to resolve with popover when using with a tablet touchscreen.
                          Thank you
                            sdetweil @aircliff
                            @aircliff it’s probable that the tablet doesn’t support the right level of JavaScript for the pop-up to happen
                              MMRIZE @aircliff
                              @aircliff
                              I’m using new way to handle popover thing, the “popover” API which is suggested recently as standard, but not all the browser supports it yet.
                              https://github.com/MMRIZE/MMM-CalendarExt3/discussions/80
                                sdetweil @MMRIZE
                                @MMRIZE and tablets and TVs and fix devices are using fairly old browsers and don’t generally have any mechanism to upgrade them to the latest releases so it’s unlikely that the tablet will ever support the pop-up the same way as a native browser will
                                  CurlyQ12391
                                  Hello, I hope that this is the correct place to ask about this…
                                  I’ve been playing around with adding backgrounds to my CalX3 for US holidays (example of the Valentines background below):
                                  Since the CSS is applying the background to a specific month/date combo I am unsure how I can accommodate holidays that occur on the same day but different dates each year (e.g., Thanksgiving, Labor Day, etc).
                                  The below CSS is all the dates Labor Day could fall on, but this wouldn’t work unless I comment out the incorrect dates each year :/ any ideas/suggestions?
                                  /* Labor Day - First Monday in September */
                                  .CX3 .month_9.date_1,
                                  .CX3 .month_9.date_2,
                                  .CX3 .month_9.date_3,
                                  .CX3 .month_9.date_4,
                                  .CX3 .month_9.date_5,
                                  .CX3 .month_9.date_6,
                                  .CX3 .month_9.date_7,
                                  .CX3 .month_9.date_8 {
                                    background-image: url("/modules/MMM-CalendarExt3/Backgrounds/LaborDay");
                                    background-position: center center;
                                    background-size: 60%;
                                    background-repeat: no-repeat;
                                  Thank you!
                                    MMRIZE @CurlyQ12391
                                    @CurlyQ12391
                                    There is the selector “.weekday_N”(0-6). ATM I cannot remember exactly but “weekday_0” probably is “Sunday” (or Monday), anyway try it.
                                    https://github.com/MMRIZE/MMM-CalendarExt3#styling-with-css
                                      CurlyQ12391 @MMRIZE
                                      @MMRIZE,
                                      That did the trick! Adding “weekday” prevented the image from populating on multiple cells :) This module is by far my favorite because of how customizable it is.
                                      .CX3 .month_9.date_1.weekday_1,
                                      .CX3 .month_9.date_2.weekday_1,
                                      .CX3 .month_9.date_3.weekday_1,
                                      .CX3 .month_9.date_4.weekday_1  {
                                      The only one I haven’t been able to figure out is Easter Sunday because it is the first between March 22 and April 25. I dont believe CSS can handle that type of logic, maybe JS but thats a little too complex for me. For now I will just leave Easter off the calendar.
                                        MMRIZE @CurlyQ12391
                                        @CurlyQ12391
                                        I think it is possible with “manipulateDateCell”. I will show example after my return from a business trip in a few days.
                                          MMRIZE @CurlyQ12391
                                          @CurlyQ12391
                                            module: "MMM-CalendarExt3",
                                            position: "bottom_bar",
                                              mode: 'month',
                                              manipulateDateCell: (dom, events) => {
                                                let date = new Date(+dom.dataset.date)
                                                if (date.getMonth() == 8 && date.getDate() == 2) { // specific cell by absolute date
                                                  dom.classList.add('specialHoliday')
                                                  dom.style.backgroundColor = 'red'
                                                  // do whatever you want.
                                                if (events.some(e => e.title.search("Gelber") > -1)){ // specific cell by event
                                                  dom.classList.add('specialEvent')
                                                  dom.style.backgroundColor = 'yellow'
                                          • N Offline
                                            nekreg9
                                            How can I delay the start of the MMM-CalendarExt3 module? I have the default calendar module showing and I can see the 3 calendars load events into it. The problem is CalendarExt3 starts while the calendars are still loading. I changed the refreshInterval to more frequent to deal with that, but really a delay start would be more efficient.
                                            I supposed this would only be a problem while I am troubleshooting.
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 34
                                            • 35
                                            • 17 / 35
