    MMM-CalendarExt3
    689 Posts 82 Posters 3.2m Views 86 Watching
    • K
      Kaisies 0
      Is it at all possible to alter the grid to only divide the screen into 5 sections? I was able to alter code to only show m-f, but the sat and sun sections are still there. Just completely blank. For the life of me I can’t figure out where in the code it sets this part up.
      M 2 Replies Last reply
        MMRIZE @Kaisies 0
        @Kaisies-0
          MMRIZE @Kaisies 0
          @Kaisies-0
          Anyway,
          For the firstDayOfWeek: 1 (Week starts from Monday), It could be achieved like below;
          .CX3 .weekGrid {
            grid-template-columns: repeat(5, [cell-start] 1fr [cell-end]) 0fr 0fr;
          .CX3 .weekday.weekday_6,
          .CX3 .weekday.weekday_0 {
            display: none;
          .CX3 .cell.weekday_6,
          .CX3 .cell.weekday_0 {
            display: none;
          This will work.
          But for the firstDayOfWeek:0 or another case, .weekGrid should be adjusted more heavily. And not sure side-effects.
          BKeyportB 1 Reply Last reply
          • BKeyportB
            BKeyport Module Developer @MMRIZE
            @MMRIZE I wanna do things a little different (of course) - what I’d like is to have CX3 display the calendar symbol only. No title, preferably horizontally. I can get the title out of the way, but the rest of it I’m not quite sure how - for some reason I’m having a hard time deconstructing how you build.
            Thanks!
              MMRIZE @BKeyport
              @BKeyport
              Is this what you want?
                MMRIZE @BKeyport
                @BKeyport
                What a coincidence.
                Yesterday, a user asked me how to manipulate day-cell and remove events together at the same time. It is ideally the same with your purpose.
                To reach your goal; 1) extracting an icon from an event and 2) putting it into the daycell would be needed.
                However, manipulateDayCell is executed after all events processes are done, so it cannot be achieved with CX3 alone. With manipulateDayCell, you can extract icons and inject them into the daycell, but you cannot remove original events together easily.
                With MMM-ModuleMonkeyPatch, you can remove events after rendering (before revealing)
                /* In MMM-CalendarExt3 config */
                  manipulateDateCell: (cellDom, events) => {
                    let body = cellDom.querySelector('.cellBody')
                    Array.from(events).forEach((e) => {
                      if (Array.isArray(e.symbol) && e.symbol.length > 0) {
                        let icon = document.createElement('span')
                        icon.className = e.symbol
                        body.appendChild(icon)
                        icon.style.color = e.color
                  maxEventLines: 1,
                /* MMM-ModuleMonkeyPatch */
                  module: "MMM-ModuleMonkeyPatch",
                    patches: [
                        module: "MMM-CalendarExt3",
                        method: "getDom",
                        patch: function (original, args) {
                          let dom = original(args)
                          let target = Array.from(dom.querySelectorAll('.event')) || []
                          target.forEach((e) => {
                            e.style.display = 'none'
                          return dom
                These codes are just concept-proof. There are many holes like overflowed events, order of events, … I bet you can improve codes for your purpose.
                • BKeyportB
                  @MMRIZE that would be perfect, yes.
                  • BKeyportB
                    @MMRIZE actually, I don’t need to extract - the symbols are set by default Calendar app, so I’d be using “useSymbol:True” to get them only.
                    • X
                      XDmToter
                      I am having trouble integrating MMM-CalendarExt3 with MMM-GoogleCalendar.
                      I’m not sure what else is required other than adding a “name” to the Google Calendar and then listing that in the “calendarSet” parameter in CalendarExt3.
                      Can anyone point out what I am missing?
                      Here is my config:
                                  module: 'MMM-GoogleCalendar',
                                  header: "Family Calendar",
                                      maximumEntries: 4,
                                      broadcastPastEvents: true,
                                          symbol: "calendar-week",
                                          calendarID: "XXXXXXXXXXXXXXXXXXXX@group.calendar.google.com",
                                  position: "bottom_bar",
                                  title: "Family Calendar",
                                      mode: "week",
                                      instanceId: "basicCalendar",
                                      calendarSet: ['famCal'],
                      I see the List view from MMM-GoogleCalendar, but I just get a blank calendar from MMM-CalendarExt3
                        MMRIZE @XDmToter
                        @XDmToter
                        Read this. https://github.com/MMRIZE/MMM-CalendarExt3#compatible-with-randombrainstormermmm-googlecalendar
                        By the way, this is a pure question.
                        Google Calendar provides iCAL format(.ics), so the default calendar module can also parse it. Why people use MMM-GoogleCalendar instead of the default calendar? Is there any special thing?
                        I ask this because one of the most frequently asked issues is how to use with MMM-GoogleCalendar.
                        X 1 Reply Last reply
                          MMRIZE @XDmToter
                          @XDmToter
                          Anyway, I requested PR of MMM-GoogleCalendar to solve this incompatible broadcasting. When @randomBrainstorm adopts the PR, this issue will be solved.
                          • X
                            XDmToter @MMRIZE
                            @MMRIZE Thank you for your reply. As I understand it, in order to use an ICal URL from Google Calendar, you have to make your calendar Public. Using MMM-GoogleCalendar is Authenticated using an API Token, so your calendar does Not need to be public.
                            I tried adding the “preProcessor” settings, but I still get a blank calendar. Does this get added to the “config” section, or the “module” section? I put it inside the config array.
                                            mode: "week",
                                            preProcessor: (e) => {
                                                if (e.start?.dateTime) {
                                                    e.startDate = new Date(e.start.dateTime).valueOf()
                                                } else if (e.start?.date) {
                                                    e.startDate = new Date(`${e.start.date}T00:00:00`).valueOf()
                                                if (e.end?.dateTime) {
                                                    e.endDate = new Date(e.end.dateTime).valueOf()
                                                } else if (e.end?.date) {
                                                    e.endDate = new Date(`${e.end.date}T00:00:00`).valueOf()
                                                e.title = e.summary
                                                e.fullDayEvent = (e.start?.date) ? true : false
                                                return e
                            M G 2 Replies Last reply
                              MMRIZE @XDmToter
                              @XDmToter
                              Your configuration seems all right unless you may be missing some brackets matching or commas at the end of the continuous module definitions.
                              In MM screen, Ctrl+Shift+i will open dev console. You may see suspicious error messages if they happen.
                              • G
                                gonzonia @XDmToter
                                @XDmToter
                                There’s a way to get an iCal URL without making it public. I see this in my “Settings and Sharing” section of Google Calendar. Screenshot 2023-10-11 at 2.28.40 PM.png
                                M 1 Reply Last reply
                                  MMRIZE @gonzonia
                                  @gonzonia @XDmToter
                                  But anyway, for shared-calendar (e.g. Family calendar), MMM-GoogleCalendar is worthy. (And there would be the possibility to implement a reminder feature also.)
                                  I discussed this issue with @randomBrainstorm, and I can bet the fixed version of MMM-GoogleCalendar will be released soon. At that time, the need for conversion will be gone.
                                  • BKeyportB
                                    @MMRIZE So, I’ve expanded my calendar larger for a DakBoard like setup, and noticed some cosmetic problems, mostly in background highlighting. Can you take a look and see what’s up?
                                    Also, I’d like the icons (using the symbols from calendar) to be row flexed not column flexed.
                                    Thanks.
                                    https://ibb.co/VL3qnsk
                                    			//disabled: true,
                                    				fontSize: '31.5px',
                                    				eventHeight: '36px',
                                    				animationSpeed: 0,
                                    				mode: "month",
                                    				headerTitleOptions: {
                                    					month: 'long',
                                    					year: 'numeric',
                                    				minimalDaysOfNewYear: 1,
                                    				refreshInterval: 60000,
                                    				useWeather: false,
                                    				useSymbol: true,
                                    				maxEventLines: 4,
                                    				firstDayOfWeek: 0,
                                    				calendarSet: ["Main", "Holidays", "Seahawks", "Sounders", "Bluejays", "Mariners", "Kraken", "XFL"],
                                    ``` css
                                    /* CalendarExt3 */
                                    .CX3 {
                                      --celllinecolor: #666;
                                      --cellbgcolor: rgba(0, 0, 0, 0.5);
                                      --cellheaderheight: 25px;
                                      --cellfooterheight: 2px;
                                      --defaultcolor: #FFF;
                                      --eventheight: calc(var(--fontsize) + 4px);
                                      --totalheight: calc(var(--eventheight) * var(--maxeventlines));
                                      --displayEndTime: none;
                                      --displayWeatherTemp: none;
                                      font-size: var(--fontsize);
                                      color: var(--defaultcolor);
                                      line-height: calc(var(--eventheight));
                                      min-width: 1280px;
                                    .module.MMM-CalendarExt3 .module-header {
                                    	color: white;
                                    	background-color: green;
                                    	border-radius: 8px;
                                    	text-transform: unset;
                                    	font-size: var(--font-size-medium);
                                    	line-height: var(--font-size-small)+5;
                                    	border: none;
                                    .CX3 .thisMonth {
                                      background-color: rgba(0, 0, 0, 0.2);
                                    /* get rid of unwanted elements */
                                    .CX3 .event.singleday .headline:not(.useSymbol)::before,
                                    .CX3 .event.singleday .headline.useSymbol .symbol.noSymbol::before {
                                      content: '⬤';
                                      color: var(--calendarColor);
                                      display: none;
                                      padding-right: 2px;
                                      font-size: 75%;
                                    .CX3 .event:not(.fullday) .headline .time {
                                      display: none;
                                      padding-right: 2px;
                                      font-size: 75%;
                                      color: #EEE;
                                    .CX3 .weekday_0 {
                                      color: #FFF;
                                    .CX3 .weekday_6 {
                                      color: #FFF;
                                    .CX3 .cw {
                                      font-size: 80%;
                                      color: goldenrod;
                                      display: none;
                                    .CX3 .cw::before {
                                      content: 'CW '
                                    .CX3 .title {
                                    	display: none;
                                    • X
                                      XDmToter @MMRIZE
                                      @MMRIZE
                                      I found the issue.
                                      # grep broadcastEvents modules/MMM-GoogleCalendar/MMM-GoogleCalendar.js
                                          broadcastEvents: false,
                                      # grep broadcastEvents modules/default/calendar/calendar.js
                                      		broadcastEvents: true,
                                      broadcastEvents defaults to False in MMM-GoogleCalendar.
                                      There is no mention of this in your README.md You might consider adding that under your “Compatible with randomBrainstormer/MMM-GoogleCalendar” Section.
                                        MMRIZE @XDmToter
                                        @XDmToter
                                        That is not my fault. Which is not compatible with default calendar module is MMM-GoogleCalendar, not mine.
                                        As I wrote in readme, CX3 and her sibling modules don’t parse calendar files directly by themselves. They need “event provider” like default calendar module which can emit events as notification.
                                        And if some module can/cannot broadcast notifications by its config; that is not CX3’s job. Read the module’s guide carefully.
                                        • X
                                          XDmToter @MMRIZE
                                          @MMRIZE said in MMM-CalendarExt3:
                                          @XDmToter
                                          I understand that. I wasn’t saying it’s anything you need to fix. I was just saying that you could mention in your readme, under the “Compatible with randomBrainstormer/MMM-GoogleCalendar” section, that setting “broadcastEvents; true” in the MMM-GoogleCalendar config is also required. If you would like, I can fork your project, add this one line to the readme and submit a pull request. I just thought it would be easier for you to do it.
                                            MMRIZE @XDmToter
                                            @XDmToter
                                            Sure, feel free to contribute anytime.
                                            By the way, MMM-GoogleCalendar will be released to become compatible with the default calendar soon, and then the hotfix tip will be obsoleted. Anyway, I want you to know that always welcome.
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 34
                                            • 35
                                            • 19 / 35
