    MMM-CalendarExt3
    689 Posts 82 Posters 3.2m Views 86 Watching
      MMRIZE @BKeyport
      @BKeyport
      What a coincidence.
      Yesterday, a user asked me how to manipulate day-cell and remove events together at the same time. It is ideally the same with your purpose.
      To reach your goal; 1) extracting an icon from an event and 2) putting it into the daycell would be needed.
      However, manipulateDayCell is executed after all events processes are done, so it cannot be achieved with CX3 alone. With manipulateDayCell, you can extract icons and inject them into the daycell, but you cannot remove original events together easily.
      With MMM-ModuleMonkeyPatch, you can remove events after rendering (before revealing)
      /* In MMM-CalendarExt3 config */
        manipulateDateCell: (cellDom, events) => {
          let body = cellDom.querySelector('.cellBody')
          Array.from(events).forEach((e) => {
            if (Array.isArray(e.symbol) && e.symbol.length > 0) {
              let icon = document.createElement('span')
              icon.className = e.symbol
              body.appendChild(icon)
              icon.style.color = e.color
        maxEventLines: 1,
      /* MMM-ModuleMonkeyPatch */
        module: "MMM-ModuleMonkeyPatch",
          patches: [
              module: "MMM-CalendarExt3",
              method: "getDom",
              patch: function (original, args) {
                let dom = original(args)
                let target = Array.from(dom.querySelectorAll('.event')) || []
                target.forEach((e) => {
                  e.style.display = 'none'
                return dom
      These codes are just concept-proof. There are many holes like overflowed events, order of events, … I bet you can improve codes for your purpose.
      BKeyportB 1 Reply Last reply
      • BKeyportB
        BKeyport Module Developer @MMRIZE
        @MMRIZE that would be perfect, yes.
        • BKeyportB
          @MMRIZE actually, I don’t need to extract - the symbols are set by default Calendar app, so I’d be using “useSymbol:True” to get them only.
          • X
            XDmToter
            I am having trouble integrating MMM-CalendarExt3 with MMM-GoogleCalendar.
            I’m not sure what else is required other than adding a “name” to the Google Calendar and then listing that in the “calendarSet” parameter in CalendarExt3.
            Can anyone point out what I am missing?
            Here is my config:
                        module: 'MMM-GoogleCalendar',
                        header: "Family Calendar",
                            maximumEntries: 4,
                            broadcastPastEvents: true,
                                symbol: "calendar-week",
                                calendarID: "XXXXXXXXXXXXXXXXXXXX@group.calendar.google.com",
                        position: "bottom_bar",
                        title: "Family Calendar",
                            mode: "week",
                            instanceId: "basicCalendar",
                            calendarSet: ['famCal'],
            I see the List view from MMM-GoogleCalendar, but I just get a blank calendar from MMM-CalendarExt3
            M 2 Replies Last reply
              MMRIZE @XDmToter
              @XDmToter
              Read this. https://github.com/MMRIZE/MMM-CalendarExt3#compatible-with-randombrainstormermmm-googlecalendar
              By the way, this is a pure question.
              Google Calendar provides iCAL format(.ics), so the default calendar module can also parse it. Why people use MMM-GoogleCalendar instead of the default calendar? Is there any special thing?
              I ask this because one of the most frequently asked issues is how to use with MMM-GoogleCalendar.
              X 1 Reply Last reply
                MMRIZE @XDmToter
                @XDmToter
                Anyway, I requested PR of MMM-GoogleCalendar to solve this incompatible broadcasting. When @randomBrainstorm adopts the PR, this issue will be solved.
                • X
                  XDmToter @MMRIZE
                  @MMRIZE Thank you for your reply. As I understand it, in order to use an ICal URL from Google Calendar, you have to make your calendar Public. Using MMM-GoogleCalendar is Authenticated using an API Token, so your calendar does Not need to be public.
                  I tried adding the “preProcessor” settings, but I still get a blank calendar. Does this get added to the “config” section, or the “module” section? I put it inside the config array.
                                  mode: "week",
                                  preProcessor: (e) => {
                                      if (e.start?.dateTime) {
                                          e.startDate = new Date(e.start.dateTime).valueOf()
                                      } else if (e.start?.date) {
                                          e.startDate = new Date(`${e.start.date}T00:00:00`).valueOf()
                                      if (e.end?.dateTime) {
                                          e.endDate = new Date(e.end.dateTime).valueOf()
                                      } else if (e.end?.date) {
                                          e.endDate = new Date(`${e.end.date}T00:00:00`).valueOf()
                                      e.title = e.summary
                                      e.fullDayEvent = (e.start?.date) ? true : false
                                      return e
                  M G 2 Replies Last reply
                    MMRIZE @XDmToter
                    @XDmToter
                    Your configuration seems all right unless you may be missing some brackets matching or commas at the end of the continuous module definitions.
                    In MM screen, Ctrl+Shift+i will open dev console. You may see suspicious error messages if they happen.
                    • G
                      gonzonia @XDmToter
                      @XDmToter
                      There’s a way to get an iCal URL without making it public. I see this in my “Settings and Sharing” section of Google Calendar. Screenshot 2023-10-11 at 2.28.40 PM.png
                      M 1 Reply Last reply
                        MMRIZE @gonzonia
                        @gonzonia @XDmToter
                        But anyway, for shared-calendar (e.g. Family calendar), MMM-GoogleCalendar is worthy. (And there would be the possibility to implement a reminder feature also.)
                        I discussed this issue with @randomBrainstorm, and I can bet the fixed version of MMM-GoogleCalendar will be released soon. At that time, the need for conversion will be gone.
                        • BKeyportB
                          @MMRIZE So, I’ve expanded my calendar larger for a DakBoard like setup, and noticed some cosmetic problems, mostly in background highlighting. Can you take a look and see what’s up?
                          Also, I’d like the icons (using the symbols from calendar) to be row flexed not column flexed.
                          Thanks.
                          https://ibb.co/VL3qnsk
                          			//disabled: true,
                          				fontSize: '31.5px',
                          				eventHeight: '36px',
                          				animationSpeed: 0,
                          				mode: "month",
                          				headerTitleOptions: {
                          					month: 'long',
                          					year: 'numeric',
                          				minimalDaysOfNewYear: 1,
                          				refreshInterval: 60000,
                          				useWeather: false,
                          				useSymbol: true,
                          				maxEventLines: 4,
                          				firstDayOfWeek: 0,
                          				calendarSet: ["Main", "Holidays", "Seahawks", "Sounders", "Bluejays", "Mariners", "Kraken", "XFL"],
                          ``` css
                          /* CalendarExt3 */
                          .CX3 {
                            --celllinecolor: #666;
                            --cellbgcolor: rgba(0, 0, 0, 0.5);
                            --cellheaderheight: 25px;
                            --cellfooterheight: 2px;
                            --defaultcolor: #FFF;
                            --eventheight: calc(var(--fontsize) + 4px);
                            --totalheight: calc(var(--eventheight) * var(--maxeventlines));
                            --displayEndTime: none;
                            --displayWeatherTemp: none;
                            font-size: var(--fontsize);
                            color: var(--defaultcolor);
                            line-height: calc(var(--eventheight));
                            min-width: 1280px;
                          .module.MMM-CalendarExt3 .module-header {
                          	color: white;
                          	background-color: green;
                          	border-radius: 8px;
                          	text-transform: unset;
                          	font-size: var(--font-size-medium);
                          	line-height: var(--font-size-small)+5;
                          	border: none;
                          .CX3 .thisMonth {
                            background-color: rgba(0, 0, 0, 0.2);
                          /* get rid of unwanted elements */
                          .CX3 .event.singleday .headline:not(.useSymbol)::before,
                          .CX3 .event.singleday .headline.useSymbol .symbol.noSymbol::before {
                            content: '⬤';
                            color: var(--calendarColor);
                            display: none;
                            padding-right: 2px;
                            font-size: 75%;
                          .CX3 .event:not(.fullday) .headline .time {
                            display: none;
                            padding-right: 2px;
                            font-size: 75%;
                            color: #EEE;
                          .CX3 .weekday_0 {
                            color: #FFF;
                          .CX3 .weekday_6 {
                            color: #FFF;
                          .CX3 .cw {
                            font-size: 80%;
                            color: goldenrod;
                            display: none;
                          .CX3 .cw::before {
                            content: 'CW '
                          .CX3 .title {
                          	display: none;
                          • X
                            XDmToter @MMRIZE
                            @MMRIZE
                            I found the issue.
                            # grep broadcastEvents modules/MMM-GoogleCalendar/MMM-GoogleCalendar.js
                                broadcastEvents: false,
                            # grep broadcastEvents modules/default/calendar/calendar.js
                            		broadcastEvents: true,
                            broadcastEvents defaults to False in MMM-GoogleCalendar.
                            There is no mention of this in your README.md You might consider adding that under your “Compatible with randomBrainstormer/MMM-GoogleCalendar” Section.
                              MMRIZE @XDmToter
                              @XDmToter
                              That is not my fault. Which is not compatible with default calendar module is MMM-GoogleCalendar, not mine.
                              As I wrote in readme, CX3 and her sibling modules don’t parse calendar files directly by themselves. They need “event provider” like default calendar module which can emit events as notification.
                              And if some module can/cannot broadcast notifications by its config; that is not CX3’s job. Read the module’s guide carefully.
                              • X
                                XDmToter @MMRIZE
                                @MMRIZE said in MMM-CalendarExt3:
                                @XDmToter
                                I understand that. I wasn’t saying it’s anything you need to fix. I was just saying that you could mention in your readme, under the “Compatible with randomBrainstormer/MMM-GoogleCalendar” section, that setting “broadcastEvents; true” in the MMM-GoogleCalendar config is also required. If you would like, I can fork your project, add this one line to the readme and submit a pull request. I just thought it would be easier for you to do it.
                                  MMRIZE @XDmToter
                                  @XDmToter
                                  Sure, feel free to contribute anytime.
                                  By the way, MMM-GoogleCalendar will be released to become compatible with the default calendar soon, and then the hotfix tip will be obsoleted. Anyway, I want you to know that always welcome.
                                    MMRIZE @BKeyport
                                    @BKeyport
                                    I’m sorry for not getting back to you sooner. I have forgotten. :)
                                    What does mean background highlighting? You can adjust --cellbgcolor value or .cell selector directly to change background color.
                                    And for the events list, I gave you a solution of conjuction. with MMM-ModuleMonkeyPatch. Without it, it could not be achieved.
                                    https://forum.magicmirror.builders/topic/16690/mmm-calendarext3/357?_=1697195312657
                                    • M MMRIZE referenced this topic on
                                      MMRIZE @BKeyport
                                      @BKeyport
                                      config (MMM-CalendarExt3)
                                          maxEventLines: 1,
                                      config (MMM-ModuleMonkeyPatch)
                                          patches: [
                                              method: "getDom",
                                                  const dt = new Date(+e.dataset.startDate)
                                                  const date = '.date_' + dt.getDate()
                                                  const month = '.month_' + (dt.getMonth() + 1)
                                                  const container = dom.querySelector(`.cell${date + month} .cellBody`)
                                                  if (container) {
                                                    e.classList.add('iconOnly')
                                                    container.appendChild(e)
                                                return dom
                                      custom.css
                                      .CX3 .eventContainer {
                                        display: none;
                                      .CX3 .cellBody {
                                        display: flex;
                                        flex-direction: row;
                                        justify-content: flex-start;
                                      .CX3 .cellBody .event.iconOnly {
                                        display: inline-flex;
                                        height: var(--eventheight);
                                      .CX3 .cellBody .event.iconOnly .symbol {
                                        justify-content: center;
                                      .CX3 .event.iconOnly :not(.headline),
                                      .CX3 .event.iconOnly .headline :not(.symbol) {
                                        display: none;
                                      .CX3 .cell {
                                        background-color: unset;
                                      (This patching is not considering overflowing events.)
                                        roth_nj
                                        is there a way to set this up to have a rolling 4 or 5 weeks (depending on how its configured) instead of the traditional only one month view. that way you can continually see a few weeks in advance?
                                        please forgive me if this has already been asked/covered. I tried to go through this thread but with 38 pages and a lot of code bits, I didn’t see it.
                                        M B 2 Replies Last reply
                                          MMRIZE @roth_nj
                                          @roth_nj
                                          You don’t have to read entire posts on this thread. Just read the README md first.
                                          And there is the feature description of what you want probably.
                                            roth_nj @hrmax23
                                            @hrmax23 said in MMM-CalendarExt3:
                                            @MMRIZE Is there a way to show a rolling 4/5 week in the month mode? Basically something like -1 week to +3 weeks rather than showing basically the current month until that month is over.
                                            Also, is there a trick to get the calendar to re-render completely on some interval? On my MM right now, it’s currently showing the current day in the 5th week (i.e. still showing April as the current month). If I restart MM, it will update to show May as current month, but doesn’t seem to do it automatically. I only have 1 scene so not using MMM-Scenes.
                                            @roth_nj
                                            i did. again, im new to all of this. i am not a programmer at all in any sense. im an ME but did have to take a c++ course like 20 years ago. my brain just doesn’t see this stuff easily. i can read through the readme’s for various modules and get the basic functions but then i have been reading through all the trouble shooting threads about them to get a better understanding on how to actually do it.
                                            at this point im guessing something on the css level with transforming or preprocessing the data?
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 34
                                            • 35
                                            • 19 / 35
