    MMM-CalendarExt3
    689 Posts 82 Posters 3.2m Views 86 Watching
    • X
      XDmToter @MMRIZE
      @MMRIZE Thank you for your reply. As I understand it, in order to use an ICal URL from Google Calendar, you have to make your calendar Public. Using MMM-GoogleCalendar is Authenticated using an API Token, so your calendar does Not need to be public.
      I tried adding the “preProcessor” settings, but I still get a blank calendar. Does this get added to the “config” section, or the “module” section? I put it inside the config array.
                  module: "MMM-CalendarExt3",
                  position: "bottom_bar",
                  title: "Family Calendar",
                      mode: "week",
                      instanceId: "basicCalendar",
                      calendarSet: ['famCal'],
                      preProcessor: (e) => {
                          if (e.start?.dateTime) {
                              e.startDate = new Date(e.start.dateTime).valueOf()
                          } else if (e.start?.date) {
                              e.startDate = new Date(`${e.start.date}T00:00:00`).valueOf()
                          if (e.end?.dateTime) {
                              e.endDate = new Date(e.end.dateTime).valueOf()
                          } else if (e.end?.date) {
                              e.endDate = new Date(`${e.end.date}T00:00:00`).valueOf()
                          e.title = e.summary
                          e.fullDayEvent = (e.start?.date) ? true : false
                          return e
      M G 2 Replies Last reply Reply Quote 0
        MMRIZE @XDmToter
        @XDmToter
        Your configuration seems all right unless you may be missing some brackets matching or commas at the end of the continuous module definitions.
        In MM screen, Ctrl+Shift+i will open dev console. You may see suspicious error messages if they happen.
        X 1 Reply Last reply Reply Quote 0
        • G
          gonzonia @XDmToter
          @XDmToter
          There’s a way to get an iCal URL without making it public. I see this in my “Settings and Sharing” section of Google Calendar. Screenshot 2023-10-11 at 2.28.40 PM.png
            MMRIZE @gonzonia
            @gonzonia @XDmToter
            But anyway, for shared-calendar (e.g. Family calendar), MMM-GoogleCalendar is worthy. (And there would be the possibility to implement a reminder feature also.)
            I discussed this issue with @randomBrainstorm, and I can bet the fixed version of MMM-GoogleCalendar will be released soon. At that time, the need for conversion will be gone.
            • BKeyportB
              BKeyport Module Developer @MMRIZE
              @MMRIZE So, I’ve expanded my calendar larger for a DakBoard like setup, and noticed some cosmetic problems, mostly in background highlighting. Can you take a look and see what’s up?
              Also, I’d like the icons (using the symbols from calendar) to be row flexed not column flexed.
              Thanks.
              https://ibb.co/VL3qnsk
              			//disabled: true,
              				fontSize: '31.5px',
              				eventHeight: '36px',
              				animationSpeed: 0,
              				mode: "month",
              				headerTitleOptions: {
              					month: 'long',
              					year: 'numeric',
              				minimalDaysOfNewYear: 1,
              				refreshInterval: 60000,
              				useWeather: false,
              				useSymbol: true,
              				maxEventLines: 4,
              				firstDayOfWeek: 0,
              				calendarSet: ["Main", "Holidays", "Seahawks", "Sounders", "Bluejays", "Mariners", "Kraken", "XFL"],
              ``` css
              /* CalendarExt3 */
              .CX3 {
                --celllinecolor: #666;
                --cellbgcolor: rgba(0, 0, 0, 0.5);
                --cellheaderheight: 25px;
                --cellfooterheight: 2px;
                --defaultcolor: #FFF;
                --eventheight: calc(var(--fontsize) + 4px);
                --totalheight: calc(var(--eventheight) * var(--maxeventlines));
                --displayEndTime: none;
                --displayWeatherTemp: none;
                font-size: var(--fontsize);
                color: var(--defaultcolor);
                line-height: calc(var(--eventheight));
                min-width: 1280px;
              .module.MMM-CalendarExt3 .module-header {
              	color: white;
              	background-color: green;
              	border-radius: 8px;
              	text-transform: unset;
              	font-size: var(--font-size-medium);
              	line-height: var(--font-size-small)+5;
              	border: none;
              .CX3 .thisMonth {
                background-color: rgba(0, 0, 0, 0.2);
              /* get rid of unwanted elements */
              .CX3 .event.singleday .headline:not(.useSymbol)::before,
              .CX3 .event.singleday .headline.useSymbol .symbol.noSymbol::before {
                content: '⬤';
                color: var(--calendarColor);
                display: none;
                padding-right: 2px;
                font-size: 75%;
              .CX3 .event:not(.fullday) .headline .time {
                display: none;
                padding-right: 2px;
                font-size: 75%;
                color: #EEE;
              .CX3 .weekday_0 {
                color: #FFF;
              .CX3 .weekday_6 {
                color: #FFF;
              .CX3 .cw {
                font-size: 80%;
                color: goldenrod;
                display: none;
              .CX3 .cw::before {
                content: 'CW '
              .CX3 .title {
              	display: none;
              • X
                XDmToter @MMRIZE
                @MMRIZE
                I found the issue.
                # grep broadcastEvents modules/MMM-GoogleCalendar/MMM-GoogleCalendar.js
                    broadcastEvents: false,
                # grep broadcastEvents modules/default/calendar/calendar.js
                		broadcastEvents: true,
                broadcastEvents defaults to False in MMM-GoogleCalendar.
                There is no mention of this in your README.md You might consider adding that under your “Compatible with randomBrainstormer/MMM-GoogleCalendar” Section.
                  MMRIZE @XDmToter
                  @XDmToter
                  That is not my fault. Which is not compatible with default calendar module is MMM-GoogleCalendar, not mine.
                  As I wrote in readme, CX3 and her sibling modules don’t parse calendar files directly by themselves. They need “event provider” like default calendar module which can emit events as notification.
                  And if some module can/cannot broadcast notifications by its config; that is not CX3’s job. Read the module’s guide carefully.
                  • X
                    XDmToter @MMRIZE
                    @MMRIZE said in MMM-CalendarExt3:
                    @XDmToter
                    I understand that. I wasn’t saying it’s anything you need to fix. I was just saying that you could mention in your readme, under the “Compatible with randomBrainstormer/MMM-GoogleCalendar” section, that setting “broadcastEvents; true” in the MMM-GoogleCalendar config is also required. If you would like, I can fork your project, add this one line to the readme and submit a pull request. I just thought it would be easier for you to do it.
                      MMRIZE @XDmToter
                      @XDmToter
                      Sure, feel free to contribute anytime.
                      By the way, MMM-GoogleCalendar will be released to become compatible with the default calendar soon, and then the hotfix tip will be obsoleted. Anyway, I want you to know that always welcome.
                        MMRIZE @BKeyport
                        @BKeyport
                        I’m sorry for not getting back to you sooner. I have forgotten. :)
                        What does mean background highlighting? You can adjust --cellbgcolor value or .cell selector directly to change background color.
                        And for the events list, I gave you a solution of conjuction. with MMM-ModuleMonkeyPatch. Without it, it could not be achieved.
                        https://forum.magicmirror.builders/topic/16690/mmm-calendarext3/357?_=1697195312657
                        • M MMRIZE referenced this topic on
                          MMRIZE @BKeyport
                          @BKeyport
                          config (MMM-CalendarExt3)
                              maxEventLines: 1,
                          config (MMM-ModuleMonkeyPatch)
                            module: "MMM-ModuleMonkeyPatch",
                              patches: [
                                  method: "getDom",
                                  patch: function (original, args) {
                                  let dom = original(args)
                                  let target = Array.from(dom.querySelectorAll('.event')) || []
                                    target.forEach((e) => {
                                      const dt = new Date(+e.dataset.startDate)
                                      const date = '.date_' + dt.getDate()
                                      const month = '.month_' + (dt.getMonth() + 1)
                                      const container = dom.querySelector(`.cell${date + month} .cellBody`)
                                      if (container) {
                                        e.classList.add('iconOnly')
                                        container.appendChild(e)
                                    return dom
                          custom.css
                          .CX3 .eventContainer {
                            display: none;
                          .CX3 .cellBody {
                            display: flex;
                            flex-direction: row;
                            justify-content: flex-start;
                          .CX3 .cellBody .event.iconOnly {
                            display: inline-flex;
                            height: var(--eventheight);
                          .CX3 .cellBody .event.iconOnly .symbol {
                            justify-content: center;
                          .CX3 .event.iconOnly :not(.headline),
                          .CX3 .event.iconOnly .headline :not(.symbol) {
                            display: none;
                          .CX3 .cell {
                            background-color: unset;
                          (This patching is not considering overflowing events.)
                            roth_nj
                            is there a way to set this up to have a rolling 4 or 5 weeks (depending on how its configured) instead of the traditional only one month view. that way you can continually see a few weeks in advance?
                            please forgive me if this has already been asked/covered. I tried to go through this thread but with 38 pages and a lot of code bits, I didn’t see it.
                            M B 2 Replies Last reply Reply Quote 0
                              MMRIZE @roth_nj
                              @roth_nj
                              You don’t have to read entire posts on this thread. Just read the README md first.
                              And there is the feature description of what you want probably.
                                roth_nj @hrmax23
                                @hrmax23 said in MMM-CalendarExt3:
                                @MMRIZE Is there a way to show a rolling 4/5 week in the month mode? Basically something like -1 week to +3 weeks rather than showing basically the current month until that month is over.
                                Also, is there a trick to get the calendar to re-render completely on some interval? On my MM right now, it’s currently showing the current day in the 5th week (i.e. still showing April as the current month). If I restart MM, it will update to show May as current month, but doesn’t seem to do it automatically. I only have 1 scene so not using MMM-Scenes.
                                @roth_nj
                                i did. again, im new to all of this. i am not a programmer at all in any sense. im an ME but did have to take a c++ course like 20 years ago. my brain just doesn’t see this stuff easily. i can read through the readme’s for various modules and get the basic functions but then i have been reading through all the trouble shooting threads about them to get a better understanding on how to actually do it.
                                at this point im guessing something on the css level with transforming or preprocessing the data?
                                • BKeyportB
                                  @MMRIZE the background highlighting issue is shown in my screenshot. If you look at October 11 in the shot, you’ll notice the highlight is smaller than the text.
                                  Same goes for the full day event shown on Nov 2, the highlight is blocking the “2” partially.
                                  That being said, I’m gonna work on expanding my module to do a big calendar instead. I’m not getting what I want even with monkeypatch, and it’s getting too confused.
                                    bicolorbore586 @roth_nj
                                    @roth_nj in the config of the module set the ‘mode’ to week. The add the config option ‘weeksInView’ and set that to 4 or 5
                                    Here’s an extract from mine:
                                    			position: "lower_third",
                                    				mode: "week",
                                    				weekIndex: 0,
                                    				weeksInView: 5,
                                    As MMRIZE says, it’s in the readme file (under config details). The re-render, as you say is also listed in there, as one of the intervals.
                                      roth_nj @bicolorbore586
                                      @bicolorbore586 said in MMM-CalendarExt3:
                                      				mode: "week",
                                      				weekIndex: 0,
                                      				weeksInView: 5,
                                      thanks… trust me, i read all that stuff a number of times. it just didn’t click that thats what i meant. im going to go bang my head against the wall now ha ha
                                      • A
                                        aircliff
                                        Have another issue I just recently noticed. I have two different modules running, one in day view showing one week worth of calendar. The other is in month view. The day view is set with dayIndex of 0 so the current day is the first day. Day 7 on the view shows no events although they are shown for that day on the month view calendar. I could not find any similar posts with issues in this thread so hoping someone has seen and can provide some help. Here are screenshots for reference. It is always the last day in the day view, so for right now Tuesday the 24th is where the issue lies. I’ve changed weeksInView to 2 and it was always just the last day of the series.
                                        Week View:
                                        Month View:
                                          MMRIZE @aircliff
                                          @aircliff
                                          Maybe the bug. I’ll inspect it. :)
                                            MMRIZE @aircliff
                                            @aircliff
                                            I found where the bug lies on.
                                            https://github.com/MMRIZE/MMM-CalendarExt3/blob/28c3aeabfbc5b0ebc28107831dcbacd125578d0a/MMM-CalendarExt3.js#L436
                                            I’ll fix it tomorrow. :)
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 34
                                            • 35
                                            • 19 / 35
