    warning warning , new os images today Oct 11
    14 Posts 5 Posters 3.9k Views 5 Watching
      raspi has updated the images to bookworm today and there are a couple broken features in my install script and maybe upgrade.
      | edit. install and upgrade have been fixed for pi02w and pi3.
      hang on…
      if u need to reflash use the archive link to get the image. the raspi imager uses the new bookworm images
        see this story about the changes, live on pi4 and 5
        https://www.raspberrypi.com/news/bookworm-the-new-version-of-raspberry-pi-os/
        there are impacts on desktop, video , audio, networking
        so expect impacts
        • karsten13K Offline
          karsten13 @sdetweil
          Thanks!
          Major change is the move from X11 to Wayland.
          Legacy images are now bullseye, buster is not available anymore.
          • BKeyportB Offline
            @sdetweil so, does bookworm work at all for MM?
              sdetweil @BKeyport
              @BKeyport yes, without problem, the base works. my updated scripts, in testit branch
              I have another test to do, 32 bit on pi4.
              32 & 64 on pi3,& pi0w2 are ok
              32 & 64 bit on pi4 are ok
              | pi0w works ok, had a script bug…
                sdetweil @karsten13
                @karsten13 but audio system changed too.
                  karsten13 @sdetweil
                  yes … but the biggest impact for me is wayland because my docker images don’t run on the new Bookworm release. I need to take a closer look, but it’s too late now …
                    sdetweil @karsten13
                    @karsten13
                    interesting…
                    the install of the 32 bit system on the PI4, results in a hybrid
                    (pi3 is ok)
                    64 bit kernel (aarch64) and 32 bit user space (armhf)
                    | edit, also tested 32 bit bullseye on pi4, installer worked as expected, MM running fine, started by pm2 (also mixed env, uanme is aarch64, but runtime is 32 bit
                    bugsounetB 1 Reply Last reply Reply Quote 0
                      sdetweil @karsten13
                      @karsten13 the buster image is still in the archives
                      warning
                      I am incorrect…
                      they removed that image… only the bullseye image remains
                      but nodejs for armv6l is discontinued after v11… so MM will no longer install or update or run on Pi0W after the 2.24 release AS LONG as you do NOT flash the OS image again… (which would wipe node 16) as node 16 is not available for armv6l devices anymore
                      warning
                      • bugsounetB Offline
                        bugsounet Banned @sdetweil
                        @sdetweil said in warning warning , new os images today Oct 11:
                        @karsten13
                        interesting…
                        (pi3 is ok)
                        This was already the case with Bulleyes since May or June 2023.
                        To have a 32bit kernel just add this in /boot/config.txt :
                        arm_64bit=0
                        Result is:
                        it’s armv7l and not aarch64 ;)
                        The main problem with aarch64 is some app with compile for x64 using but we can execute it because like you says: it’s an 32bits system
                        Again… like we know using x64 raspbian OS (full) with a pi it’s not really stable and can make some trouble
                        So I’m agree with you: it’s complex for manage any update
