    warning warning , new os images today Oct 11
    14 Posts 5 Posters 4.0k Views 5 Watching
      sdetweil @BKeyport
      @BKeyport yes, without problem, the base works. my updated scripts, in testit branch
      I have another test to do, 32 bit on pi4.
      32 & 64 on pi3,& pi0w2 are ok
      32 & 64 bit on pi4 are ok
      | pi0w works ok, had a script bug…
        sdetweil @karsten13
        @karsten13 but audio system changed too.
        • karsten13K Online
          karsten13 @sdetweil
          yes … but the biggest impact for me is wayland because my docker images don’t run on the new Bookworm release. I need to take a closer look, but it’s too late now …
            sdetweil @karsten13
            @karsten13
            interesting…
            the install of the 32 bit system on the PI4, results in a hybrid
            (pi3 is ok)
            64 bit kernel (aarch64) and 32 bit user space (armhf)
            | edit, also tested 32 bit bullseye on pi4, installer worked as expected, MM running fine, started by pm2 (also mixed env, uanme is aarch64, but runtime is 32 bit
            bugsounetB 1 Reply Last reply Reply Quote 0
              sdetweil @karsten13
              @karsten13 the buster image is still in the archives
              warning
              I am incorrect…
              they removed that image… only the bullseye image remains
              but nodejs for armv6l is discontinued after v11… so MM will no longer install or update or run on Pi0W after the 2.24 release AS LONG as you do NOT flash the OS image again… (which would wipe node 16) as node 16 is not available for armv6l devices anymore
              warning
              • bugsounetB Offline
                bugsounet Banned @sdetweil
                @sdetweil said in warning warning , new os images today Oct 11:
                @karsten13
                interesting…
                (pi3 is ok)
                This was already the case with Bulleyes since May or June 2023.
                To have a 32bit kernel just add this in /boot/config.txt :
                arm_64bit=0
                Result is:
                it’s armv7l and not aarch64 ;)
                The main problem with aarch64 is some app with compile for x64 using but we can execute it because like you says: it’s an 32bits system
                Again… like we know using x64 raspbian OS (full) with a pi it’s not really stable and can make some trouble
                So I’m agree with you: it’s complex for manage any update
                • bheplerB Offline
                  bhepler Module Developer
                  The install script worked okay on Armbian 23.8.1 (Bookworm). PM2 install worked great. Screensaver disable didn’t work the first time but after a manual configuration to auto-boot into the user and then a couple of boots it seems to be doing well.
                    sdetweil @bhepler
                    @bhepler thanks for the feedback
                    • BKeyportB Offline
                      @sdetweil so… playing with bookworm, I’m gonna officially mark it not recommended - while it works - I used your scripts…
                      if I reboot, I lose PM2, it won’t autostart - and it’s spawning as if it’s a fresh install.
                      VNC no longer works - Wayland don’t support it, and if I back off to x11, it won’t start.
                      Other misc issues here and there. I’d highly recommend staying with bullseye for production.
                        sdetweil @BKeyport
                        @BKeyport pm2 , yeh a pain in the rear
                        the command to setup auto start works when run manually but not in my script for some reason
                        pm2 startup
                        it will.output the command to execute
                        copy/,paste that hit enter
                        pm2 start all
                        pm2 save
                        VNC, yes they said so
