MMM-Netatmo does not load
33 Posts 13 Posters 7.9k Views 14 Watching
  • T Offline
    tommys
    I’m running nodejs v20.8.1 on Ubuntu 22.04 and most MagicMirror modules run fine, except for MMM-Netatmo. It seems to get stuck when fetch-ing the oauth2/token-request, though it receives a response with status 200, but then nothing seems to happen!?
    When I manually post the same request using curl from the command line, it works great and I get my access token, which I successfully can use using curl to get my api/getstationdata.
    The last thing I’m able to debug into is in the node-fetch’s worker.js file:
    process.stdin.on('end', function () {
      const input = JSON.parse(chunks.join(''))
      const request = shared.deserializeRequest(fetch, ...input)
      fetch(request)
        .then(response => response.buffer()
          .then(buffer => respond([
            buffer.toString('base64'),
            shared.serializeResponse(response)
    I can see that shared is updated with at response-header, however, I cannot see the response-body data that is supposed to contain the access-token among other things. And, for me, not being a nodejs/javascript programmer, the app seems to hang with the only thing being shown in the MMM-Netatmo widget is “Loading” forever.
    What could be causing my problems?
    Of course, I have triple checked that my config settings are correct:
        module: 'netatmo',
        position: 'top_center',
        header: 'Netatmo',
            clientId: 'xxx',
            clientSecret: 'yyy',
            refresh_token: 'zzz',
            moduleOrder: ["Inomhus","Utomhus"]
    Regards,
    /Tommy
    T 1 Reply Last reply Oct 30, 2023, 7:17 AM Reply Quote 0
    • T Offline
      tommys @tommys
      @tommys
      Replying to myself since I finally have solved the problem! Netatmo is now loading fine on the latest versions of MM and MMM-Netatmo.
      The problem was actually caused by two independent problems: the module reordering algorithm and the sync-fetch library.
      The workaround I did to solve the first problem was simply to not set the moduleOrder config property, easy as that.
      The second workaround was a bit more involved, I completely removed the usage of the sync-fetch library in netatmo.js in favor of the default async version . That is, simply remove the line: const fetch = require(‘sync-fetch’), make the authenticate, loadData and socketNotificationReceived functions async, handle the promise object returned by fetch appropriately as well as the call to json().
      S C C L 4 Replies Last reply Oct 30, 2023, 5:55 PM Reply Quote 2
      • S Away
        sdetweil @tommys
        @tommys the reason for this is fetch is built in in the node 20.8 version used by the node helper.
          CFenner @tommys
          @tommys great that you solved the issue! Would you mind contributing that back into the repository?
          T 1 Reply Last reply Nov 6, 2023, 9:52 PM Reply Quote 0
          • T Offline
            tommys @CFenner
            @CFenner normally I would say: Yes, absolutely! But… I’m not a javascript-developer and know very little about it and node.js.
            This is the first time I dipped my toe in this world (I’ve been working for 30 years as a C++ developer :grinning_face_with_sweat: ) so I just tried things until I got it working. I have probably done something non-idiomatic or worse, so I think it is better that someone more knowledgable do a proper fix. But I’m happy to answer questions if more info than I already provided is needed.
            Btw, a big thank you for your great Netatmo-module @CFenner! :folded_hands:
            • W Offline
              wwats
              Hello everybody, I have the same problem. Because I’m not an IT professional, I’m having trouble solving the problem with your instructions.
              The second workaround in particular is difficult:
              …I completely removed the usage of the sync-fetch library in netatmo.js in favor of the default async version . That is, simply remove the line: const fetch = require(‘sync-fetch’), make the authenticate, loadData and socketNotificationReceived functions async, handle the promise object returned by fetch appropriately as well as the call to json().
              • I can’t find the “const fetch” line in the netatmo.js file
              • how can I make functions asynchronous
              • the sentence “handle the promise object returned by fetch appropriately as well as the call to json().” I don’t really understand either
              Is it possible to make the instructions a bit more detailed? Or what is the best way to ensure that the great module works for me again?
              Thank you very much for your effort!
                cgillinger @tommys
                @tommys I have the same problem, but while I can follow instructions and edit files, your description is a bit to advanced for me.
                Could you break it down, I would really like to get the module working again!
                C 1 Reply Last reply Jan 3, 2024, 1:31 PM Reply Quote 0
                  CFenner @cgillinger
                  @cgillinger I merged a PR from @ottolote to replace the sync-fetch. Please try if that fixes the issue for you. It work for me now, but also did before that change using mm v2.26.
                  C L 2 Replies Last reply Jan 4, 2024, 10:17 AM Reply Quote 2
                    cgillinger @CFenner
                    @CFenner And just to report back here as well: Now the module works for me again! Thnx!
                    • L Offline
                      Laz @CFenner
                      @CFenner
                      Have you updated your module? Does it need to be reinstated or how to update it?
                      • 1 / 4
