    MMM-Netatmo does not load
    33 Posts 13 Posters 18.5k Views 14 Watching
      cgillinger @tommys
      @tommys I have the same problem, but while I can follow instructions and edit files, your description is a bit to advanced for me.
      Could you break it down, I would really like to get the module working again!
      CFennerC 1 Reply Last reply
      • CFennerC
        CFenner @cgillinger
        @cgillinger I merged a PR from @ottolote to replace the sync-fetch. Please try if that fixes the issue for you. It work for me now, but also did before that change using mm v2.26.
        C L 2 Replies Last reply
        Reply Quote 2
          cgillinger @CFenner
          @CFenner And just to report back here as well: Now the module works for me again! Thnx!
          • L
            Laz @CFenner
            @CFenner
            Have you updated your module? Does it need to be reinstated or how to update it?
            • L
              Laz
              I have reinstalled the entire module. And everything finally worked!) Thanks to the author of the module. I really like this module.
              A huge only request to the author - add a pressure recalculation in mm Hg…!!!)))
              • CFennerC
                CFenner @Laz
                @Laz great that it works again. Sorry that is took so long. What about the RU translations, everything good?
                Will try to find some time for the transformation.
                L 3 Replies Last reply
                • L
                  Laz @CFenner
                  @CFenner Unfortunately, I now work remotely through VNC with a mirror, the resolution is not very high and all small details are not always clear. I will check the translation in April, as I will be in that city.
                  Thank you, I am waiting for a recount to other pressure units.!)
                  • L
                    Laz
                    I noticed that the module displays the wrong wind values ​ ​ from the wind sensor on the mirror. The display of speed, wind gust and wind direction is not correct… ((The display of data on the mirror from the wind sensor does not match the data in the Netatmo application and in the Netatmo personal account.
                    • L
                      Laz @CFenner
                      @CFenner
                        sil3ntstorm
                        I first used another Netatmo module, but it hasn’t been updated for 4 years. I now want to use this one, but I don’t know exactly how to create the netatmo refresh token?
                        Are there instructions for this?
                        Can someone show the module settings here so that the data is displayed exactly like this:
                        • CFennerC
                          CFenner @sil3ntstorm
                          @sil3ntstorm you get the token now directly from the developer portal, see https://github.com/CFenner/MMM-Netatmo?tab=readme-ov-file#connection-to-netatmo-service-api
                            sil3ntstorm @CFenner
                            @CFenner
                            Thanks, it seems to be working now, but I can’t find this setting so that the rooms are displayed one below the other. These are displayed one below the other, even if I enter false for horizontal:
                              module: 'netatmo',
                              position: 'bottom_left', // the location where the module should be displayed
                              header: 'Netatmo', // a header if you like one
                                clientId: 'secret123', // your app id
                                clientSecret: 'secret123', // your app secret
                                refresh_token: 'secret123', // your generated refresh token
                                refreshInterval: '3',
                                dataOrder: ["Noise","Pressure","CO2","Humidity","Temperature","Rain"],
                                design: 'bubbles',
                                horizontal: 'true',
                                showBattery: 'true',
                                showWiFi: 'true',
                                showTrend: 'true',
                                showMeasurementIcon: 'true',
                                showStationName: 'true',
                                showModuleNameOnTop: 'false',
                                fontClassModuleName: 'xsmall',
                                fontClassPrimary: 'xsmall',
                                fontClassSecondary: 'xsmall',
                                fontClassMeasurement: 'xsmall',
                                thresholdCO2Average: '1200',
                                thresholdCO2Bad: '1800',
                            L 1 Reply Last reply
                            • L
                              Laz @sil3ntstorm
                              @sil3ntstorm
                                sil3ntstorm
                                • L
                                  Laz @CFenner
                                  @CFenner Good afternoon! I am still waiting for the decision to recalculate in mm Hg.
                                  And tell me how to fix the wrong display of the wind direction?
                                  • LusbuebL
                                    Lusbueb @tommys
                                    @tommys in history the moduleOrder was like this:
                                    moduleOrder: ["Outdoor", "Regen", "Wind", "Schlafzimmer", "Wohnzimmer"]
                                    but in newer versions the code has a new variable called showStationName and as default it is set to true. Now set this to false or expand the moduleOrder like this StationName - Module
                                    moduleOrder: ["im Fritz - Outdoor","im Fritz - Regen","im Fritz - Schlafzimmer","im Fritz - Wohnzimmer"]
                                    this solved my Problem Netatmo load without errors but shows nothing (blank screen)
                                    good luck, Peter
                                      sil3ntstorm
                                      Since yesterday it hasn’t been displayed on my mirror anymore, you can only see module name Netatmo loading…
                                      I also did the module update, the problem still exists. Has anything been adjusted that I also have to change in the config so that it is displayed again?
                                      A 1 Reply Last reply
                                      • A
                                        anton2023 @sil3ntstorm
                                        @sil3ntstorm
                                        same issue here, it seems to loose the refresh token each day:
                                        i have to re create a refresh token , and copy it to the config, js, the module works.
                                        the following morning after the pi shutdown, the module isn,t working, need to re create a refresh token for it works…
                                        ? 1 Reply Last reply
                                          schrecki
                                          Hello together, same issue here. I’m using the RaymondMolenaar Fork, but the issue is the same.
                                          The generated refresh-token only works once. I can see the data, but after a refresh only the loading circle.
                                            A Former User @anton2023
                                            @anton2023 it’s not only after reboot, but after each reload of the mirror itself e.g. after changing and saving config.js.
                                            Workaround, until this gets fixed, would be
                                            1. don’t touch the configuration and
                                            2. deactivate automatic shut down/restart every night
                                            Best regards,
                                            Nico
