    MMM-MyScoreboard
    277 Posts 60 Posters 627.3k Views 63 Watching
    • N Offline
      Noctis25 @BKeyport
      @BKeyport
      Hi BKeyport,
      That makes sense,
      We are in daylight savings for another 20 days,
      i will see if that changes after the change,
      thank you
      • BKeyportB Offline
        BKeyport Module Developer @Noctis25
        @Noctis25 One thing you could double check as you’re in England. Are you using the right clock locale (Europe/London versus GMT)? Is your clock observing DST correctly?
        Daylight savings is a horrible thing, as is timezones.
        • E Offline
          Egnos @j.e.f.f
          @j-e-f-f Thanks for fixing the module! ;-)
          I have tried your module and I believe that all the most popular football rankings do not work.
          I tried with:
          • ITA_SERIES_A
          • ESP_LALIGA
          • GER_BUNDESLIGA
          but nothing is shown.
          For example NHL League works …
          Could you help me?
          Thanks.
          • N Offline
            NSpr
            Working great with today’s games for NHL, Eng Premier & League 1; however when I set a value for rolloverHours this switches to only showing the previous days scores and doesn’t display anything for today? Assuming my formatting is correct? Just:
            rolloverHours: 12,
              SirFM
              Updated my mirror and now the module is stuck with the message “Loading…”
              I’ve updated the module since a new version came out but I still have the same problem.
              I’ve also tried deleting the MMM-MyScoreboard directory and did a new pull and install but still no success.
              In the console I get a MESA-LOADER: failed to retrieve device information. My GoogleFu failed to produce success.
                sdetweil @SirFM
                @SirFM I would open an issue in the modules GitHub to engage the author.
                how did u upgrade mm? manual or use my script?
                  SirFM @sdetweil
                  @sdetweil Manual
                    richmp95
                    i am liking this module however when inspecting it, there is a parameter mismatch in module.show: callback is not an optional parameter! showing line 392 on module.js. is this something with this module or something with the new update of MagicMirror?
                      MMRIZE @richmp95
                      @richmp95
                      MM2.24 changed some codes then showing somewhat annoying “error” message. Not related with real “error”, just ignore it.
                      • F Offline
                        Fuen
                        Hi everyone and thanks fore the MMM-MyScoreboard module who is running just fine. I’m wondering why one team disapear of the scoreboard ? During the day i can see teams i setup to be listed and the hour the game is but when its time for the game to be played then one team (MTL as for Montreal Canadiens in NHL) disapear from the scoreboard with the team the play against, that game ain’t show live stats but every other teams i can follow on screen.
                        Is there a place to look at if that team isnt’ write correctly for the live score? Or is it something else that i miss like in the setting?
                        Regards
                        • 1 Offline
                          1a2a3a
                          @j-e-f-f how do you reduce the font size of the content? i maanged to reduce them in css but then when the next game appear, the entire thing is back to default.
                          these are the 2 css i made but it seems like it doesnt port over to another game…
                          .MMM-MyScoreboard .box-score.stackedWithLogos.home-team-first .score.home {
                          left: 120px;
                          font-size: 0.8rem;
                          .MMM-MyScoreboard .box-score.stackedWithLogos.home-team-first .score.visitor {
                          left: 120px;
                          font-size: 0.8rem;
                            sdetweil @1a2a3a
                            @1a2a3a said in MMM-MyScoreboard:
                            the logic of your css selector clause is
                            elements in elements with class MMM-MyScoreboard
                            AND
                            elements with ALL classes specified on the same element
                             classes box-score **AND** stackedWithLogos **AND** home-team-first
                            AND
                                .score.visitor
                            classes  score   **AND** visitor
                            1 1 Reply Last reply Reply Quote 0
                            • 1 Offline
                              1a2a3a @sdetweil
                              @sdetweil i dont understand sam…
                              did you mean like this?
                              .MMM-MyScoreboard .box-score AND stackedWithLogos AND home-team-first .score AND visitor {
                              left: 120px;
                              font-size: 0.8rem;
                                sdetweil @1a2a3a
                                @1a2a3a I was specifying the logic of you selector clause
                                . means class
                                if there are multiple . in a string with no spaces it means
                                all these classes MUST be specified on the element explicitly
                                so you have some weak ands (with spaces)
                                .MMM-MyScoreboard (weak and) .box-score.stackedWithLogos.home-team-first (weak and) .score.visitor
                                and some ABSOLUTE ands
                                .box-score(ABSOLUTE and).stackedWithLogos(ABSOLUTE and).home-team-first
                                all these classes MUST be on the same element
                                class=“box-score stackedWithLogos home-team-first”
                                and
                                .score(ABSOLUTE and).visitor
                                class=“score visitor”
                                • 1 Offline
                                  1a2a3a @sdetweil
                                  weak? absolute?
                                    sdetweil @1a2a3a
                                    @1a2a3a
                                      <div class="MMM-MyScoreboard">
                                         <div class="box-score">
                                               <div class="stackedWithLogos home-team-first">
                                                     <div >some text </div>
                                         <div class="box-score stackedWithLogos home-team-first>hit the jackpot</div>
                                     </div>
                                    because your second part of the selector clause has no spaces,
                                    ALL THREE classes MUST appear in the class= of the element (absolute AND)
                                    so the element with ‘some text’ will NOT be selectable
                                    but element WITH all three, hit the jackpot, WILL BE selectable
                                    (selectable depending on the next 2 classes, which I didn’t show)
                                    S 1 2 Replies Last reply Reply Quote 0
                                      SirFM @sdetweil
                                      I haven’t dove into the code but do you know if the W-L record of the teams could easily be displayed?
                                      • 1 Offline
                                        1a2a3a @sdetweil
                                        @sdetweil I can’t Sam, I really can’t. Spent 3 days trying to get this and cron job for schedule on off on Wayland. Managed to get cron to work finally, but no dice on this.
                                          sdetweil @1a2a3a
                                          @1a2a3a i understand… open the developers window on the MM browser (best to use the PC browser)
                                          ctrl-shift-i
                                          select the elements tab
                                          select the pointer in the top left of the elements tab
                                          move the mouse pointer over the MM web page contents to you get to the MMM-MyScoreboard module, all the content should be highlighted
                                          click mouse
                                          in the developers window, the (selected by click) module content will be shown
                                          with all the classes and explicit attributes attached…
                                          see this topic with screen shots to help see my post here
                                          https://forum.magicmirror.builders/post/90135
                                          • 1 Offline
                                            1a2a3a
                                            anyone having issue with the module? its not showing anything now despite games being on.
                                            getting something like this in the dev mode
                                            M-MyScoreboard] Updating Scores
                                            module.js:367 Parameter mismatch in module.hide: callback is not an optional parameter!
                                            main.js:671 module tries to update the DOM without being displayed.
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 13 / 14
