    Introducing MMM-YouTubeWebView Module
    youtubewebviewembed
    7 Posts 4 Posters 3.4k Views 5 Watching
    • doctorwhenD Offline
      doctorwhen
      I have released the initial version of the MMM-YouTubeWebView MagicMirror module at https://gitlab.com/doctorfree/MMM-YouTubeWebView
      This module allows embedding of YouTube videos, either singly or as a list of YouTube video IDs, or as a public YouTube playlist ID. The module uses the Electron webview tag rather than an iframe in an attempt to avert YouTube blocking the requested video for any of several reasons.
      The webview tag is used to embed ‘guest’ content in the MagicMirror Electron app. The guest content is contained within the webview container. An embedded page within MagicMirror controls how the guest content is laid out and rendered.
      Unlike an iframe, the webview runs in a separate process than MagicMirror. It doesn’t have the same permissions and all interactions between MagicMirror and embedded content will be asynchronous. This keeps MagicMirror safe from the embedded content.
      Under the hood webview is implemented with Out-of-Process iframes (OOPIFs).
      The webview tag is essentially a custom element using shadow DOM to wrap an
      iframe element inside it. So the behavior of webview is very similar to a
      cross-domain iframe. As such, it can be used to safely avoid cross-domain
      policy restrictions that may prevent access to web content.
      This module is based upon both the MMM-WebView module and the MMM-EmbedYoutube module with added functionality. There are some limitations to embedding with webview. These are detailed in the README. There may be a better way to do what I have done here. Possibly I should be using the Electron BrowserView instead. I would be open to suggestion. However, this release does accomplish what I set out to do - I can play my YouTube playlists and lists of YouTube videos without YouTube telling me the video is unavailable which is what I was seeing when using an iframe.
      This is the initial release so I expect there will be significant changes in the near term. I’ve thoroughly tested it but expect issues will arise. The module is a work-in-progress and in active development.
      Any feedback will be greatly appreciated.
      KristjanESPERANTOK M 2 Replies Last reply Reply Quote 5
      • KristjanESPERANTOK Offline
        KristjanESPERANTO Module Developer @doctorwhen
        Hi @doctorwhen! Thanks for this module! :-)
        I tried to get it to run, but it just doesn’t. I don’t get an error message, just a black screen. I am using node version 18 and the latest version of MagicMirror.
        Does the module work for you (or for someone else) with current versions?
        That’s my config:
            module: "MMM-YouTubeWebView",
            position: "middle_center",
              video_id: "w3jLJU7DT5E",
              video_list: [
                "CtVyl402W5s",
                "wmUVy43tqw4",
                "J_TxPQKcG7w",
                "avWZsKyuRVE",
                "IpkIGGJMHBA",
                "B9zgwx6mhrk",
                "6KvTDeHlIfI"
              autoplay: true,
              controls: true,
              loop: true,
              modestbranding: true,
              width: "800px",
              height: "450px"
          sdetweil @KristjanESPERANTO
          @KristjanESPERANTO if you open the developers window console tab view,
          do you see any errors. this module is all in browser
            if you open the developers window console tab view, do you see any errors. this module is all in browser
            Unfortunately, I can’t see any errors there.
            Initializing MagicMirror².
            translator.js:122 Loading core translation file: translations/en.json
            VM4 sandbox_bundle:2 Electron Security Warning (Insecure Content-Security-Policy) This renderer process has either no Content Security
              Policy set or a policy with "unsafe-eval" enabled. This exposes users of
              this app to unnecessary security risks.
            For more information and help, consult
            https://electronjs.org/docs/tutorial/security.
            This warning will not show up
            once the app is packaged.
            warnAboutInsecureCSP @ VM4 sandbox_bundle:2
            translator.js:138 Loading core translation fallback file: translations/en.json
            loader.js:165 Load script: modules/default/clock/clock.js
            module.js:484 Module registered: clock
            loader.js:138 Bootstrapping module: clock
            loader.js:165 Load script: vendor/node_modules/moment/min/moment-with-locales.js
            loader.js:165 Load script: vendor/node_modules/moment-timezone/builds/moment-timezone-with-data.js
            loader.js:165 Load script: vendor/node_modules/suncalc/suncalc.js
            loader.js:142 Scripts loaded for: clock
            loader.js:180 Load stylesheet: modules/default/clock/clock_styles.css
            loader.js:145 Styles loaded for: clock
            loader.js:148 Translations loaded for: clock
            loader.js:165 Load script: modules/MMM-YouTubeWebView/MMM-YouTubeWebView.js
            module.js:484 Module registered: MMM-YouTubeWebView
            loader.js:138 Bootstrapping module: MMM-YouTubeWebView
            loader.js:142 Scripts loaded for: MMM-YouTubeWebView
            loader.js:145 Styles loaded for: MMM-YouTubeWebView
            loader.js:148 Translations loaded for: MMM-YouTubeWebView
            loader.js:180 Load stylesheet: css/custom.css
            clock.js:49 Starting module: clock
            module.js:45 Starting module: MMM-YouTubeWebView
            main.js:608 All modules started!
              mmmmh Project Sponsor @doctorwhen
              @doctorwhen Is there a way to control a video’s volume? I embedded the ISS’s livestream and I would like to mute it since every once in a while some radio chatter is on the audio channel. When I have the module hidden it is kinda eerie.
                KristjanESPERANTO Module Developer @mmmmh
                @mmmmh MMM-ISS-Live has a mute option.
                  mmmmh Project Sponsor @KristjanESPERANTO
                  @KristjanESPERANTO Now that’s a whole new approach. Thanks, it works!
